Old 11-12-2007, 10:43 AM   #1
xrw1
Member#: 159772
06 WRX
obp
Default Tire size
I have a 06 wrx and planning to buy new rim size 17 X 7.5 I was wondering would 215/45/17 tires would fit on that rim or i need bigger 225/45/17 on them. thank you very much
xrw1 is offline   Reply With Quote
Old 11-12-2007, 01:02 PM   #2
waktasz
Member#: 86356
2015 s1000r
wheelie monster
FYI, you can find that information on either the vendor's site or on the tire manufacturers site. (teach a man to fish, etc)
see below for an example (note the rim width range)
waktasz is offline   Reply With Quote
Old 11-12-2007, 01:03 PM   #3
mikeythejew
Member#: 141672
215/45/17 can use a rim from 7"-8" wide. Info is found via the tirerack under tire specs as said above. BTW, you raise your car about 1/4" when going to the 225/45/17. Not sure thats something I would want.
mikeythejew is offline   Reply With Quote
Old 11-13-2007, 11:11 AM   #4
xrw1
Member#: 159772
06 WRX
obp
thank you for the feed back. I was just wondering how a wider tire 225 would incease the height of the car by 1/4 if the only thing changing is the width?
Old 11-13-2007, 11:20 AM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
The width is NOT the only thing changing if you go to a wider tire of the same aspect ratio
Have a read here [howstuffworks.com] or google 'tire aspect ratio'
UkNuck is offline   Reply With Quote
Old 11-13-2007, 11:23 AM   #6
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Basically the height of the sidewall is 225*45%. So a 215/45 and a 225/45 have different heights. The difference isn't enough to worry about though.
Old 11-13-2007, 09:11 PM   #7
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
u can also go 235-40-17, if you want slightly better gearing for acceleration.
might be a stretch on a 7" wide wheel tho.
Samirr76 is offline   Reply With Quote
Old 11-14-2007, 08:10 AM   #8
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
....WILL be....it is a stretch on a 7.5" wheel and I would NOT put a 235/40 on a 7" wheel.
To the OP.....do yourself a favor and NOT get a 17 x 7.5.....DO get a 17 x 8" and be done with it
Sticky for Rim sizes and tire sizes? TomsSound Brakes, Steering & Suspension 8 02-01-2012 09:30 PM
Tire sizes and speaker sizes... samtheblur Legacy Forum 9 06-03-2005 08:04 PM
Racing Tire Size to Street Tire Size mav1c Brakes, Steering & Suspension 0 11-18-2002 03:16 PM
Interesting Tire Size/Contact Patch Size/Shape Info - aka why I don't have 18" wheels rao Brakes, Steering & Suspension 6 06-19-2001 04:08 PM
Here is tire sizes chart. No more tire size Qs? Yeah, right! 25psi Brakes, Steering & Suspension 18 04-18-2001 03:29 PM
