Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 11-14-2007, 01:55 AM   #1
MaxSTi05
Member#: 110957
05 STi Stg 2 Cobb
HBspeed, Autopower, KW
At the Track RPF-1 17x9 +45 clear Brembos?
Any proof of this, or simply will not fit? No spacers will be used, tracked STi.
MaxSTi05 is offline   Reply With Quote
Old 11-14-2007, 02:04 AM   #2
MaxSTi05
Member#: 110957
05 STi Stg 2 Cobb
Well, after a little more searching, I don't think they will fit. Someone confirm?
http://www.iwsti.com/forums/tires-wh...ml#post1472443
"nope, the RPF1s that fit are
17x8 +45mm
18x8 +45mm (5x100 only)
17x8.5 +40mm (5x114.3 only)
all other RPF1s have the wrong disk and cause caliper issues."
and
http://www.iwsti.com/forums/tires-wh...ml#post1069960
"Yea I wish they made the ear a bit different, but for most wheels it's not a problem. I also test fitted a set of enkei rpf1's 17x9 et 45. They fit in the rear, but would need like a 20mm spacer in front to clear the caliper. This was a japanese spec wheel with a concave face made for an rx7."
Old 11-14-2007, 04:02 AM   #3
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
all the 9"+ RPF1 has the special "concave" face which has very little caliper clearance, so no they wont clear.
ommmjido is offline   Reply With Quote
Old 11-14-2007, 10:19 AM   #4
STFU STi
Member#: 39528
2005 STi
Black and TiC Cows
They do not clear, a vendor on my other forum (RX-7club) was doing a group-buy oin these wheels.. and test fitted a wheel on a friends STi.
confirmed NON fitment.
STFU STi is offline   Reply With Quote
Old 12-05-2007, 02:59 PM   #5
Wrinkleboi
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
do you know how much of a spacer would be required? just curious...
i have the 17x8.5 +40... they sit nice and wide and have a ton of clearance
Wrinkleboi is offline   Reply With Quote
Old 01-13-2008, 03:47 PM   #6
DELTA_Rotary
Member#: 56718
2005 STi
What about the 17x9s with the e35? Let me say that this is for autox with coilovers and agressive camber.
DELTA_Rotary is offline   Reply With Quote
Old 01-13-2008, 05:02 PM   #7
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
^ nope Id look in to the nt03+m they fit.
scby rex is offline   Reply With Quote
Old 01-14-2008, 08:06 PM   #8
DELTA_Rotary
Member#: 56718
2005 STi
Too heavy. Im looking at the 17x9 +41 SSR Type C RS now.
Old 01-14-2008, 10:02 PM   #9
scby rex
Member#: 104878
02 wrxbastardchild
too heavy? 19 lbs for a 18x9.5? and 289 ea.
Old 01-15-2008, 04:29 AM   #10
nexus sw21
Member#: 139711
2004 sti
psm
how bout 17x8 +35 on a 04 sti.?
nexus sw21 is offline   Reply With Quote
Old 01-15-2008, 04:30 AM   #11
ommmjido
Member#: 35746
08 White GRB
that will clear
Old 01-15-2008, 06:51 PM   #12
EarlQHan
Member#: 90215
I've personally test fitted this wheel. You need around a 15mm spacer to clear the brembos. The rear might need a spacer depending on your coilovers. A 17x9 +35 is supposed to clear with a 5mm spacer or something like small in the front.
EarlQHan is offline   Reply With Quote
Old 06-23-2013, 05:38 AM   #13
Dat8687
Member#: 243261
2004 WRX
Java black pearl
will they clear stock 04 wrx brakes though? what about struts
Dat8687 is offline   Reply With Quote
Old 06-23-2013, 12:17 PM   #14
sc00by4life
Member#: 97135
Keep your posts to one bumped thread.
Jesus Christ, rpf1's are one of the most common wheels. NO they won't interfere with the struts....I have no clue where people get these ideas.
Old 06-24-2013, 02:26 PM   #15
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Seriously how old are you 2? lmao do you act like this when people ask you the same questions in life .. I was worried because as of right now with the wheels I have that are 17x7.5 I can barely fit 2 fingers between the strut and wheel.. I thought maybe the wheel or tire would rub on the inside.. I am not gonna run some lame azz negative camber to get them to fit.. I will roll the fenders but not pull them.
But thanks odin... Sincerely.. NOBAMA
jk.. have fun
And trust me I have searched and searched the forums.. And I see contradictory statements throughout with different subarus on here.. Even people saying they had to have spacers to clear in the front and rear depending on the year/model
Old 06-24-2013, 04:48 PM   #16
sc00by4life
Member#: 97135
jk.. have fun
Dude. All we ask is you keep questions confined to one area instead of asking in multiple threads at the same time.
Forum etiquette goes a long way around here.
And no, you aren't getting contradictory posts unless someone is doing something extremely stupid.
Old 06-25-2013, 04:28 PM   #17
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
2 fingers between the strut and wheel is a LOT, well over an inch unless you have super skinny fingers. You need about a credit card worth there.
So 2 fingers means that 2 inches more wheel can comfortably fit at the same offset.
Concillian is offline   Reply With Quote
WTB: Enkei RPF-1 17x8 +45 5x114.3 mrxant Private 'Wanted' Classifieds 1 05-09-2009 06:32 AM
GOLD Enkie Rpf-1 17x8 +45 w/ Falken RT-615 245/45/17 paulsaidhi SCIC Private Classifieds 9 02-12-2009 02:53 AM
17x9 +38 clear brembos? Su||y Tire & Wheel 7 10-30-2008 04:50 PM
NJ: Enkei RPF-1 5x100 45 Gold KIDREX Wheels/Tires 8 11-14-2007 06:54 AM
FS IL: Brand new Enkei RPF-1 17x9! 5x114 +45 + MORE! EarlQHan Wheels/Tires 5 04-03-2007 12:11 AM
