Old 11-14-2007, 11:44 AM   #1
dukeduster
Member#: 95789
2002 WRX PTE
6262, hydra, 1100 FIC
Default 02 usdm ej205 to early ej207 swap questions
Hi everyone.
I now finnaly got my ej207 which i thought was supposed to be a ej20k. I think its from a 99-00 sti ej207. I have searched and found a lot of info for v7 and v8 swaps but not really any info on like a v5,v6 ej207. I belive all i need to do is swap my usdm wiring harness over, swap throttle bodies and tune it. Am I correct?
dukeduster is offline   Reply With Quote
Old 11-14-2007, 10:29 PM   #2
dukeduster
Member#: 95789
2002 WRX PTE
So far so good. I am switching over the usdm engine harness and I noticed a few things. Firstly the knock sensor has a different connection on it so it must be changed to usdm sensor , secondly the power steering pump also has a different connection on it so I am gonna take my usdm pump and bolt it on there. thats how far I am so far other than that all the other sensors plug right in. will post more results tommorow when i get more time!
Old 11-17-2007, 09:18 AM   #3
dukeduster
Member#: 95789
2002 WRX PTE
Heres the progress report. The A/C compressor and bracket must be changed over, The P/S Pump and Brack must also be changed over from jdm to usdm. The reason why is that because the P/S pump wont plug in, and the A/C lines wont line up. Oh and another thing dont use the 4 bolts from the jdm A/C bracket to hold on the compressor cause the threads are different. So thats the progress thus far. got the accy's swaped over and new plugs installed and also I have the coil packs bolted on the heads. should be lonmg till she is fired up. I just need to swap out knock sensors now so the usdm engine harness will plug into it.
Old 11-17-2007, 09:18 AM   #4
dukeduster
Member#: 95789
2002 WRX PTE
Oh and this is a V5 Sti swap over for future reference! Oh and I almost forgot I also had to break off a lil knub on the top of the side feed injector connectors so the usdm harness would plug in.
Old 11-20-2007, 02:04 PM   #5
dukeduster
Member#: 95789
2002 WRX PTE
well after trying to use the stock ej207 v5 manifold I rant into the problem that swapping out the throttle body would cleaner correctly. So what I did was swap the usdm manifold and throttle body onto the ej207 v5 engine. should work fine. I got the engine ready to drop in and will post results soon.
Ej205 to jdm Ej207 swap question. Wrx1234 Subaru Conversions 19 03-19-2007 12:37 AM
tips for USDM EJ205 to JDM EJ205 swap? Chuck H Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-16-2005 08:37 PM
02 wrx tranny to sti tranny swap bjonga Transmission (AT/MT) & Driveline 3 04-26-2005 06:29 AM
FXT To STi Suspension Swap Questions SoyRacer Forester Forum 12 06-30-2004 07:30 PM
5-MT to 4-EAT swap questions Depeche Transmission (AT/MT) & Driveline 20 03-20-2003 11:58 AM
