Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 11-14-2007, 10:10 PM   #1
prometheum
Member#: 92003
04 bicycle!
Default dyno readings...how different dynos stack up against each other
at the risk of starting a giant pissing contest here it goes
how do different type of dynos compare to each other...all things being equal
but i always here mustang and dynapack dynos read high
prometheum is offline   Reply With Quote
Old 11-14-2007, 10:13 PM   #2
MattPersman
Member#: 139385
I think you mean mustang and dynapacks read lower typically.
the tuner or owner can make a dyno read 550 whp or 390 whp on the same car.
MattPersman is offline   Reply With Quote
Old 11-14-2007, 10:52 PM   #3
norexyet
Member#: 39149
11 elantra
yea i said elantra
mustangs are usually low. Dynapacks are usually higher end on numbers
norexyet is offline   Reply With Quote
Old 11-14-2007, 11:10 PM   #4
cbourbs
Member#: 117749
lowest to highest
dyno dynamics, then mustang, then dynojet, then dynapack
cbourbs is offline   Reply With Quote
Old 11-14-2007, 11:14 PM   #5
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
And all of this depends on the settings on the dyno. The software, and many other things like location of the dyno.
If only this subject were a dead horse.
parker/slc/gc8fan is offline   Reply With Quote
Old 11-14-2007, 11:16 PM   #6
norexyet
Member#: 39149
11 elantra
yea i said elantra
yea it is all in settings really. I made very similar numbers on a dynojet as i did on a dyno dynamics.
Old 11-14-2007, 11:31 PM   #7
Earl
Member#: 95044
Best et 12.07
Best trap 116.1 mph
Would love to see what dyno queen #s i put down on higher reading dynos (none available in nor-cal). But i manage to run 12.1-2s with just 290 on GST's 'heartbreak' mustang dyno. I believe 315-320 will break 11's on a mustang.
Earl is offline   Reply With Quote
Old 11-14-2007, 11:56 PM   #8
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
460whp on the DynoDynamic with no correction and I trapped [email protected]/8 and 126 up top.. 510whp trapped [email protected]/8th...
Junior2JZ is offline   Reply With Quote
Old 11-15-2007, 09:53 AM   #9
The Head
Member#: 98143
04 Cayenne TT
05 SL65, 03 GSXR1000
I can compare two (sort of). Similar weather and no changes to the car. The Engine Logics Dyno Dynamics dyno read 333whp and the MZM's Mustang dyno read 332whp. At that power I was trapping 114-115mph in the 1/4 mile in mid 90 degree temps with about 90% humidity at roughly sea level.
Last edited by The Head; 11-15-2007 at 11:49 AM. Reason: I had the wrong numbers in there.
The Head is offline   Reply With Quote
Old 11-15-2007, 12:48 PM   #10
Jhovany
Member#: 137317
2006 STI
Rally Blue
Originally Posted by cbourbs View Post
lowest to highest
I have heard in this order......
Mustang, dynodynamics, dynapack, then dynojet
Jhovany is offline   Reply With Quote
Old 11-15-2007, 12:51 PM   #11
Jhovany
Member#: 137317
2006 STI
Rally Blue
Mustang dynos ARE for sure the LOWEST reading dynos out there!!! That is all I am sure of
Old 11-15-2007, 01:44 PM   #12
karl750
Member#: 100977
2004 VF30 WRX
[email protected] 1.84 60'
Dynos are good for seeing power gains between mods, assuming you're using the same dyno. I think trap speed is a decent indicator too, though driving ability can play a roll there.
karl750 is offline   Reply With Quote
Old 11-15-2007, 07:29 PM   #13
CynicX
Member#: 48199
06 WRX
Actually some of the lowest numbers I've seen have been on a MAHA dyno...
Also keep in mind all things are not equal. Like the dynapack, its connected to the hubs so you dont have the rotational weight of the wheels, while a Mustang dyno uses rollers....
I prefer the dynapack since there is no chance of wheel slippage to throw off readings and of course the results are pretty . Its funny/scary watching people sit on the fenders of a high horsepower Honda on a roller dyno to prevent wheel slippage....
CynicX is offline   Reply With Quote
Old 11-16-2007, 01:02 PM   #14
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
It is all in the setup of the dyno. The owner can make the dyno read anything. An honest shop will use the same settings for every car so you can compare run to run on the same dyno. You cannot compare run to run across different dynos, even of the same brand.
gabedude is offline   Reply With Quote
Old 11-16-2007, 01:41 PM   #15
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
I think I am qualified to answer this question since I have tuned on multiple machines of each type across this country. The lowest is the mustang by far. The Dynodynamics reads the same as the Dynojet in most cases. If its set to stock specs about 15 lower. The Dynapack typicaly reads the highest. On Avg the Mustang will read 40 to 50whp lower then the Dyanpack. 30 lower then the dynojet and dynodynamics. Of course all the machines are adjustable in some respects so your results may vary.
Clark
AZScoobie is offline   Reply With Quote
Old 11-16-2007, 01:43 PM   #16
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
452 whp on a dynapack with no drivetrain loss correction (just SAE) and I trapped best of 98 in the 1/8th and 127.7 in the quarter.
Typical was 96-97 and 124-125 respectively.
def
dug-e-fresh is offline   Reply With Quote
Old 11-17-2007, 12:59 AM   #17
socalLGT
Member#: 89752
08 STI
Clark
Seems right on the money to me. If you want to include two less common dynos, the Maha will occupy the lowest reading spot and the DTS will take over the highest reading spot.
socalLGT is offline   Reply With Quote
Old 11-17-2007, 01:03 AM   #18
godfather2112
Papi Chulo
Member#: 53794
2005 BMW M3 - 6spd
2007 Denali Land Yacht
All a dyno is good for is a tuning tool. Hell if the tuner wants he can make it so your stock sti read 500whp. Or 1 hp.
Elevation also has a factor on readout, same with climate or temperature
godfather2112 is offline   Reply With Quote
Old 11-17-2007, 01:08 AM   #19
socalLGT
Member#: 89752
08 STI
It's pretty difficult to significantly fudge the numbers from a Dynojet. Short of putting the weather station in an oven or machining out weight from the rollers, there isn't much you can do. Well, I guess you can input a much higher altitude... The other dynos all have user adjustable "correction factors" which make it really easy to make the dyno spit out just about whatever numbers the operator wants it to.
Old 11-17-2007, 07:12 AM   #20
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
This is one of the main reasons that Dyno Dynamics have the "Shootout" mode. It locks all the settings and disables all power and torque corrections to give reproducible results between runs. This is the dyno most commonly used in Dyno shootouts in Australia.
The biggest problem with the DD though, is in the strapping down of the vehicle. Too tight and you get low numbers, too loose and you get slippage and low numbers. In most cases, strapping the car down is the most crucial element of most dynos of this type.
Anyhoo, I've always stated, and many will agree, dynos are for tuning.
wrxsti.l is offline   Reply With Quote
Eibach springs rubbing against each other ill_nometry Brakes, Steering & Suspension 3 09-12-2008 09:59 PM
will different year ecus plug into each other turbocolin Engine Management & Tuning 6 03-01-2005 11:18 PM
Do the STi and Evo compete against each other? Chris02WRX Off-Topic 20 08-06-2003 10:39 AM
1/4mi ET, how does this stack up? MMBOOST Proven Power Bragging 8 09-20-2002 07:43 PM
How does Subaru stacks up in Japan? Gambit General Forum Archive 18 03-09-2001 12:44 AM
