Old 11-15-2007, 11:58 AM   #1
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
Question NEED HELP with enginuity logger!
SInce Enginuity is down, I can't find any instructions on how to use the program.
I managed to get it connected/reading the ECU, and I ofund the boxes to check for each parameter to log.
HERE's the probs:
1) There does not seem to be a "knock correction" or "learned knock correction" selection.
2) Several other parameters don't seem to show, only manif pressure, RPM, pedal angle,engine load, and vehicle speed, as well as cylinder roughness, and a few other fields.
3) HOW DO I SAVE THE LOGS? I wnet out last night, and nearly broke every law in Texas getting logs. The car registered min and max readings for each field I selected, but I saw no history, etc. for the logs I did (yes, I have "use defogger swith to start/stop logging selected).
PLEASE HELP! If someone has detailed instructions for this program, let me know!
Thanks
SOTC
saab-on-the-cobb is offline   Reply With Quote
Old 11-15-2007, 12:22 PM   #2
Airboy
Member#: 72829
2006 WRX
2015 WRX
You may not have the current revision of the definition file that allows logging of the KC value for '07 cars.
Try this test release:
http://www.yourfilelink.com/get.php?fid=423084
unzip it into a folder on your desktop and run "logger.bat" to fire up the logger.
You can set the location of the saved log files in Settings-->Log File Output Location.
Your old log files are probably in C:\Documents and Settings\<your user name>
Airboy is online now   Reply With Quote
Old 11-15-2007, 02:40 PM   #3
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
AWESOME! You found 'em!
I-O-U-1.
SOTC
Anyone need help with an install? RubbleDTD Mid Atlantic Impreza Club -- MAIC 0 06-03-2010 05:23 AM
HELP with Romraider's logger-opensource tuning wrecker83 Open Source Reflashes 5 01-17-2010 03:36 PM
Help With Enginuity And Lc1 Logging stretchedk7 Open Source Reflashes 3 09-23-2008 01:13 AM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
Help! I need help with turbo 99 HOK Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-16-2001 08:05 AM
