#1 |
Member#: 111248
E. Canada
Vehicle:2004 WRX PSM |
Does anyone know if I should be able to read/flash JDM ECU's? The two I am trying to read are:
MY01/02 Impreza 2.0 STI Type RA (JDM) [AG970] MY03 Impreza 2.0 STI (JDM)[AH190-3771] ECUFlash 1.32 seems to recognise it, but the DENSO SSM2 can't start.. I can see the live data with ecuExplorer, just can't pull the maps or flash (even when in diagnostics mode).. Any suggestions, Thanks!
#2 |
Member#: 56321
NESIC
Vehicle:2008 Lexus IS-F |
I'm using it 1.33 without any problem on an AF481 ECU.
Have you tried that version? |
#3 |
Member#: 111248
E. Canada
#4 |
Member#: 56321
NESIC
Good luck.
If it works, would you mind emailing me the ag970 ROM? I've never seen an RA one posted before. I'd be interested in looking at the tune on it (assuming it's a stock ECU). Thanks! Mike |
#5 |
Member#: 111248
E. Canada
No problem. It's not totally stock, but I think the only changes that have been made are to make it run on our 94 octane nicely. I'll try and get em this weekend. Thanks for the help.
#6 |
Member#: 56321
NESIC
That's good enough!
Thanks- please let me know if you hit any problems. Mike |
#7 |
Member#: 103136
#8 |
Member#: 111248
E. Canada
It didn't work...
The one that was 'tuned' wasn't with ECUTek. Any suggestions? |
#9 |
Member#: 56321
NESIC
WHat is the message you are getting?
#10 |
Member#: 111248
E. Canada
I get something like 5 lines of denso02_bootloader_cmd_start then it doesn't work and says to see log.
Could these be wired wrong? The OBDII works for sure, and the car was in test mode when I tried... Thanks! |
#11 |
Member#: 111248
E. Canada
Bump.. any ideas?
#12 |
Member#: 103136
read through each these carefully:
http://www.scoobypedia.co.uk/index.p...shingFAQ#toc12 |
| Thread Tools | |
| Display Modes | |
| 2002 wrx ecu, jdm ecu | hybridpatient95 | Engine/Power/Exhaust | 2 | 04-22-2008 04:53 PM |
| 2002 wrx ecu, jdm ecu | hybridpatient95 | Engine/Power/Exhaust | 0 | 04-20-2008 12:56 PM |
| JDM ECU paired with US ECU - pro & cons | cjfike | Engine Management & Tuning | 12 | 01-28-2006 12:12 AM |
| how do I pull ECU codes from '97 JDM ecu?? | Pacobeagle | Engine Management & Tuning | 5 | 05-31-2005 01:10 PM |
| JDM ECU for EJ20 (Yes I have done a search) | markus | Normally Aspirated Powertrain | 9 | 02-25-2001 12:48 AM |
