Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 11-15-2007, 06:03 PM   #1
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
Default Enginuity Knock load range
I wanted to see if I should scale up my fine and rough correction load range in enginuity. They are currently set around 2g/rev, I see up to 2.7g/rev so far so should I scale them to somewhere around 3 or leave them where they are?
clemsonteg is offline   Reply With Quote
Old 11-15-2007, 07:01 PM   #2
Freon
Member#: 88322
2009 BMW 135i
I suggest setting the upper load of both fine and coarse correction above your peak load.
You might also shift the fine correction load columns up a tad.
Freon is offline   Reply With Quote
Old 11-15-2007, 07:11 PM   #3
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
Cool, I actually looked at an 02 sti map and saw that the max load on the timing and fuel was 2.8, and the max load on the fine and coarse was 2.7, so I assumed that it should be taken up
What does coarse correction do? I have seen the fine correction in action, not sure on the coarse correction though
Old 11-15-2007, 07:25 PM   #4
Freon
Member#: 88322
2009 BMW 135i
Coarse is your advance multiplier.
Acceptable ohmes range for a knock sensor test ronniesox Service & Maintenance 3 10-14-2009 12:04 AM
2004 STi - Vibration in Narrow RPM range and a knock during 2nd gear pull STiBlammo Service & Maintenance 8 03-04-2009 01:39 AM
loud knock from block, all rpm range, all the time. Quix Service & Maintenance 6 07-16-2007 08:08 PM
knock count = 17, knock count = 4 no UTEC timing, no load!!! K2Skier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-03-2005 08:32 PM
utec load/rpm range question nhluhr Engine Management & Tuning 17 03-22-2004 03:04 PM
