Old 11-16-2007, 12:34 AM   #1
shqipo
Member#: 79118
Question Questions about upgrading tires, wheels and brakes
It's time for me to get new tires (still running stock 16s ones on my 03). I don't have room to store two sets of tires, so I'm going to have to find one set for both winter and summer. Conti Extremes look pretty decent and not expensive - or do you have anything else you can recommend?
My questions:
1. do 17 inch wheels/tires add anything to car's performance or is it just "bling?"
2. I did my research here about brakes and I understand how a couple of ppl think it's the tires not the size of the breaks. I'd think both are important. I don't take my car to the track, but I do break a little hard on the street, going into corners, etc. Car and driver says even hawk pads are better than the stock ones. I have semi-ceramic pads on mine now. If I'm going to upgrade to 17 inch, i think I may just go ahead and upgrade br akestoo. Is this worth it http://www.subydude.com/osc/product_...86f9ee7506199e
shqipo is offline   Reply With Quote
Old 11-20-2007, 04:19 PM   #2
shqipo
Member#: 79118
^^bump^^
Old 11-20-2007, 04:49 PM   #3
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Wheels & Tires:
Wheels can definitely be bling. The point here is to upgrade and gain more benefit from a larger wheel.
If you go from a 16" to a 17" wheel, the tire's size will have to change to maintain the same overall diameter. What this does is it effectively keeps the speedometer reading the same plus it virtually eliminates any possiblity of interference with the suspension or body.
A smaller sidewall on a 17" tire is stiffer than a taller sidewall on the 16" tire. The problem comes in when you go to a 17" wheel/tire combo from a previous 16" set-up, but the suspension is the same. Now the 17" tires are doing more work and the suspension has a harder time keeping up.
The opposite is true when say one beefs up the suspension, but does not upgrade the tire or tire/wheel combo to compensate.
In short, an upgrade to a 17" wheel/tire combo can be beneficial with respect to handling.
Brakes:
Better pads can do a better job in stopping the car.
Repeated braking (i.e. as in racing) are better handled by better pads and/or better rotors (slotted; cross-drilled; or a combination of the two). The better pads can handle more brake fade. The better rotors handle more heat dissipation.
Larger rotors and matching pads (and of course, bigger calipers) will do a better job because they have more braking surface area to do the job and bigger brakes overall will contribute to better heat dissipation and thus less of a chance for brake fade.
If again you're doing moto-x, track, etc. then a step up from stock pads may be in order and/or better rotors (slotted; cross-drilled; or a combination of the two).
Changing the brake fluid to one that has a higher boiling point and/or is for street/track will also contribute to better braking.
Changing the brake hoses to stainless steel braided reinforced lines will also help. These do so by eliminating some of the flex in the hose that occurs as a result of the braking action. Less flex means more stopping power to the calipers.
In addition, a better tire will also aide in stopping a car, whether it's a better tire overall (construction / purpose) and/or a wider tire for more surface area to contact the road -- but you can only go so wide before you have interference with the suspension and/or body.
Big-E is online now   Reply With Quote
Old 11-20-2007, 04:58 PM   #4
waktasz
Member#: 86356
2015 s1000r
wheelie monster
The biggest thing you will gain going to 17s is that (hopefully) you get much wider 17s which in turn can fit wider tires.
waktasz is online now   Reply With Quote
Old 11-20-2007, 06:58 PM   #5
hjerez
Member#: 164786
Lightbulb A follow up question
I am thinking of putting 17 inch tires to my new impreza 08 that comes with the 16 inch ones. I am hopping to get more ground clearance. Is this feasible without affecting the speedometer? what combination would you suggest? do you know anything about ASA wheels? are they good? thanks in advance for any help
hjerez is offline   Reply With Quote
Old 11-20-2007, 09:27 PM   #6
waktasz
Member#: 86356
2015 s1000r
wheelie monster
If you want more ground clearance you need taller tires, the wheel size doesn't matter. Doing so will affect the speedo and odo, again, the wheels don't matter, it's the total tire diameter that matters there.
Old 11-20-2007, 09:49 PM   #7
hjerez
Member#: 164786
So basically the taller tires will affect the speedometer reading. Any recommendation on taller tires? wont taller tires create rubbing though?
Question about offset, tire size, wheel width... wgr73 Tire & Wheel 7 01-27-2010 03:15 PM
Question about flat tires and Subies AWD setup scramjett Transmission (AT/MT) & Driveline 2 01-25-2009 05:17 PM
Questions about upgrading to STi brakes bouncing_soulz Brakes, Steering & Suspension 6 10-10-2008 11:19 AM
Questions about upgrading my rotors and pads rudyWRX Brakes, Steering & Suspension 4 08-24-2006 07:05 PM
16 comp wheels and brake upgrades Russ B Brakes, Steering & Suspension 2 03-10-2002 08:00 AM
