Old 09-08-2011, 08:49 PM   #2501
AlexU
Member#: 212486
2009 Imperza
Dark Grey
Default Suspension upgrades thoughts?
Hey guys. I was looking to do a little more to my 2009 2.5i sedan suspension. Right now I have rallitek front and rear sway bars and upgraded end-links all around, they really took out a lot of body roll but I still wish it would handle better at high-way speeds. I've been researching the strut and springs out there, and there aren't that many options out there and I was curious if anyone had opinions, experiences ect.
I really only see 2 upgraded strut options out there:
09-10 WRX Struts (maybe with springs)
Koni Sport
Spring wise there are a bunch more choices I found
Epic Engineering
H & R
Subaru SPT Springs
I was leaning towards the Koni inserts and the epic eningeering springs.
Does anyone have experience's or thoughts on any of these?
The other thing was for the koni's and springs it would be >$1000. At that point would it just be a better choice to get coil-overs? (like H&R's are $1250)
Also, if I picked up stock wrx struts and springs will there be a big difference? Are the wry spring rates really that much higher?
Any help would be great, thanks guys!!!!
-Alex
AlexU is offline   Reply With Quote
Old 09-08-2011, 10:54 PM   #2502
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
There is also the Bilstein RCE combo.
What are you trying to achieve exactly? Just a firmer ride?
JourdanWithaU is offline   Reply With Quote
Old 09-08-2011, 11:09 PM   #2503
jonl
Member#: 275841
[quote=AlexU;35067193]Hey guys. I was looking to do a little more to my 2009 2.5i sedan suspension. Right now I have rallitek front and rear sway bars and upgraded end-links all around, they really took out a lot of body roll but I still wish it would handle better at high-way speeds. I've been researching the strut and springs out there, and there aren't that many options out there and I was curious if anyone had opinions, experiences ect.
Koni Sport
Epic Engineering
H & R
Subaru SPT Springs
I put H&R Springs on my 2011 obs with wry struts, not ruff at all! Looks great and handles great fro DD
jonl is offline   Reply With Quote
Old 09-09-2011, 02:21 AM   #2504
Tmangt650
Member#: 277258
2008 Hatch 2.5i
Koni Sport
Epic Engineering
H & R
Subaru SPT Springs
-Alex
As Jourdan said, it all depends on what you are trying to achieve. There are alot of different opinions out there, some bias some not. Read some FAQS about which set up (or use) you are looking for and take it from there.
Im using mine as a DD, and really just want to lower it, yet be able to take it to the snow as well. In my case, the coils sound to be the deal, but i haven't quite decided that yet.
Let us know what you choose.
Tmangt650 is offline   Reply With Quote
Old 09-09-2011, 08:31 AM   #2505
AlexU
Member#: 212486
2009 Imperza
Dark Grey
Hey thanks for the help. I really just wanted my DD to handle better, I wasn't all that concerned about dropping it.
Old 09-09-2011, 11:25 AM   #2506
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
If you just want it to handle better and don't care about a drop, then I would go with the 09+ WRX struts and a decent spring. You are going to get a bit of a drop with pretty much any spring you change to, but coilovers seem like a big expense to me if you don't need the adjustability.
Ogden is offline   Reply With Quote
Old 09-10-2011, 08:39 PM   #2507
ccalsubi
Member#: 264596
2008 Impreza 2.5i
obp
ccalsubi is offline   Reply With Quote
Old 09-10-2011, 10:03 PM   #2508
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
I picked up oem WRX uel headers for $40! I'll post a video in here once installed.
Digital Dillon is offline   Reply With Quote
Old 09-11-2011, 07:03 AM   #2509
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Originally Posted by ccalsubi View Post
Ok...
Looking forward to it.
Let us know how you went about cutting it.
Old 09-11-2011, 05:13 PM   #2510
ccalsubi
Member#: 264596
2008 Impreza 2.5i
obp
Originally Posted by JourdanWithaU View Post
Ok...
It comes with the cat section as well
Old 09-11-2011, 08:36 PM   #2511
Digital Dillon
Member#: 288727
2008 WRX premium
It's an uppipe and our cars have no need for it. A shop may be able to use the cat and weld new flanges on so you have 2 cats with an uel header set up.
Old 09-11-2011, 09:44 PM   #2512
ccalsubi
Member#: 264596
2008 Impreza 2.5i
obp
they just call it an uppipe. someone with an 06 bought it and is going to install it. there's a thread
http://www.rs25.com/forums/f5/164567...headers-4.html
Old 09-11-2011, 10:49 PM   #2513
Digital Dillon
Member#: 288727
2008 WRX premium
after looking at it... That's definitely not an uppipe at all. It's a midpipe! Seems like a great deal.
Old 09-11-2011, 11:40 PM   #2514
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
It's a cat pipe, and it is not going to fit without modification.
Old 09-12-2011, 12:35 AM   #2515
sevenones12
Member#: 291985
2008 Impreza 2.5i
Hey guys. I just got a 2008 Wagon DGM 2.5i a few weeks ago and have been browsing around here reading up. So far I've thrown in a new Pioneer double din and my 10" Alpine type-R, put on yellow fog light layovers, Rally Armour mudflaps and debadged it. I'm starting to really like the car.
There's a couple things bugging me though. I've read that it's "normal" (is it though?)for the Subarus to automatically rev up the engine when the clutch and brake are pressed and it's still in gear, and hang a bit while changing gears... But if it is normal, is there a way to turn this stuff off? I've only had standard cars, sure this might help some people, but I find it obnoxious at times..
Also, I'm getting some weird vibration from the engine bay at about 3K RPMs. Sounds like, "VVVRrrrnn", and louder than the rest of the engine. Seeing as that's where I primarily shift, and the RPM hang while shifting, it doesn't sound good. I'll look into it more soon, maybe get a sound clip, but maybe someone knew what that was..
Anyways, I'll get some pics soon, and I look forward to joining the Subby community.
sevenones12 is offline   Reply With Quote
Old 09-12-2011, 12:40 AM   #2516
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Installed some new front speakers today. Huge improvement over the crappy stockers! Heres a guide/install I wrote..
http://forums.nasioc.com/forums/show....php?t=2239999
I also picked up some Kartboy front and rear shifter bushings which will be going on soon and a Perrin shorty antenna.
fancyfootwork15 is offline   Reply With Quote
Old 09-12-2011, 03:33 AM   #2517
ccalsubi
Member#: 264596
2008 Impreza 2.5i
obp
what modifications would be needed for it to fit?
Old 09-12-2011, 04:53 AM   #2518
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
The pipe needs to be extended and the flange needs to be rotated.
Old 09-12-2011, 06:28 PM   #2519
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Hey guys I've had my 10' 2.5i Impreza sedan for about a year now and i totally love this car. I figured i should eventually sign up on the forums.
Steve2.5i is offline   Reply With Quote
Old 09-12-2011, 06:55 PM   #2520
SUBIESROCKUKNOW
Member#: 214464
2008 Impreza 2.5i
Satin white pearl
Looks good I like that color.. needs sum tint n black out the chrome on the mustache
SUBIESROCKUKNOW is offline   Reply With Quote
Old 09-12-2011, 06:56 PM   #2521
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
cant decide how much to tint it lol
Old 09-12-2011, 07:57 PM   #2522
imp2.5wag
Member#: 290211
2009 impreza 2.5i
SSM
so i traded my steelies with some 09 oem impreza rims and now my tire pressure light is on? I checked all my tires and the pressure is right on what it should be. what could be causing this can you reset it by any chance?
imp2.5wag is offline   Reply With Quote
Old 09-12-2011, 08:38 PM   #2523
Stiman1
Member#: 87043
2006 sti
Aw/gold
1. you need to make sure the new wheels have TPMS sensors
2. you have to go to a dealer to link the TPMS sensors with your car's computer (
Stiman1 is offline   Reply With Quote
Old 09-12-2011, 09:53 PM   #2524
imp2.5wag
Member#: 290211
2009 impreza 2.5i
SSM
What do they look like and how would I locate the sensor thanks for the response
Old 09-13-2011, 04:26 AM   #2525
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
They are attached to the base of the valve stems. You're not going to see them unless you dismount the tires.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
