Old 06-24-2012, 02:59 PM   #5526
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Originally Posted by DirknJirkn13 View Post
How is the quality of the mic? I also have a Pioneer HU and tried mounting it where you did, but people on the other end of the call complained that is sounded terrible. I have it mounted on the dash now above the gauges, but still the same stuff.
My pioneer mic is mouted right inside guage cluster and with windows up works great.
BWX is offline   Reply With Quote
Old 06-24-2012, 04:09 PM   #5527
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Originally Posted by daigledangle8
I believe it does but I am not 100% positive
Judging from pictures it should be a direct fit. But instead of a coin holder in between the cup holders and the shifter, it's got slots where the SI drive is.
fancyfootwork15 is offline   Reply With Quote
Old 06-24-2012, 06:27 PM   #5528
Daniel208
Member#: 318639
2010 Impreza 2.5i
Spark Silver
I haven't tried it with the windows down yet, but it still has a-lot of static but the person on the other line can still hear me. I'm gonna look around and see if I can find a better mic for a good price and try mounting it by the front light in the headliner.
Daniel208 is offline   Reply With Quote
Old 06-24-2012, 06:39 PM   #5529
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
I needed to replace my tail lights anyways and I saw that these were cheaper than OEM replacements so I asked my girlfriend to pick them up for me for my birthday. So far I have zero complaints with them. I will confirm that they are sealed properly after the first rainfall tonight.
http://www.ebay.com/itm/DEPO-08-11-S...#ht_5472wt_954
Shoulda jumped the gun on that. Needed to replace my tails cuz some doucher clipped the passenger side tail and chipped off two pieces and a quote from the stealership was 465.89 for only one piece! So I cheaped out and super glued the pieces back together and vinyl tint wrapped it
BSP671 is offline   Reply With Quote
Old 06-25-2012, 09:55 AM   #5530
theoutbackdream
Member#: 301179
2013 WRX Limited
Originally Posted by fancyfootwork15 View Post
Any of you guys know if the 09 Sti center console will fit in a sedan 2.5?
if your talking about the center panel for the stereo and the vents, ill get back to you. Found one in japan for $10.
theoutbackdream is offline   Reply With Quote
Old 06-25-2012, 10:28 AM   #5531
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Post Deleted
Last edited by Ogden; 06-25-2012 at 12:32 PM. Reason: Everyone else already pointed out what I was going to say.
Ogden is offline   Reply With Quote
Old 06-25-2012, 12:36 PM   #5532
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
The roll-top center console will fit, but it mounts a bit differently, so you may need to do some fabricating. I dont' have the detials but somene over on 3gwrx.com did the conversion a while back. THe STI console also has different heated seat switches (if you have heated seats) that are not compatible, so you can't just swap the 2.5i ones for the STI ones.
The previous gen Legacy consoles may also fit. They had the roll-top cup holder as well. I have one, but haven't had a chance to really play with it yet to see. The Legacy console also has incompatible heated seat switches. This is part of the reason that I haven't installed it yet. I need to fabricate some sort of panel to mount the swithces to.
Old 06-25-2012, 01:11 PM   #5533
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Awesome thanks for the info. I'll have to do a test fit.
Old 06-25-2012, 04:25 PM   #5534
RyanChadwick
Member#: 319509
2008 Impreza 2.5i
I have the. 08 2.5i with about 40k on it. The check engine light went on and stayed on so I brought it to the local parts shop and tested it. It's telling me it's miss firing on all 4 cylinders. Any ideas guys?
RyanChadwick is offline   Reply With Quote
Old 06-25-2012, 05:18 PM   #5535
bradyarz
Member#: 272381
2008 Impreza OBS
Possible things to check:
Coils
Plugs
Wires
It's highly unlikely you have 4 bad plugs, but who knows - stranger things have happened. My grandfather once went back and forth to the parts store with plugs for his old v8 olds. He found at least one bad plug in 7 packs. He returned each set until he finally found 8 good plugs in the 8th pack.
bradyarz is offline   Reply With Quote
Old 06-25-2012, 05:36 PM   #5536
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
RyanChadwick take it to a mechanic... that have real tools.
-oh, ad check fuel filler tube cap.
Old 06-25-2012, 05:46 PM   #5537
RyanChadwick
Member#: 319509
2008 Impreza 2.5i
I'm bringing it in this Friday. I just figured I'd check and see if any one has had similar problems before I pay to figure it out.
Old 06-25-2012, 06:48 PM   #5538
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Did you have all the 30k mile maintenance done?
It could be just a failed sensor, and the scan tool at parts shop is BS.
Misfire on all four? Doubtful, and I never saw a ''code'' that was a ''misfire on all cylinders''.
He should have given you an actual code that usually have several possibilities, that you can look up and test. I'd call BS on parts store diagnostics and start from scratch.
Check gas cap.
Old 06-25-2012, 07:01 PM   #5539
RyanChadwick
Member#: 319509
2008 Impreza 2.5i
It said miss fire on cylinder 1, misfire on cylinder 2, so on and so forth. I did it my self.
Old 06-25-2012, 07:02 PM   #5540
RyanChadwick
Member#: 319509
2008 Impreza 2.5i
As far as 30k maintenance I'm not sure I bought it at 32k so I'm assuming the Subaru dealer would know and did it. But i can figure it out.
Old 06-25-2012, 07:03 PM   #5541
howtypical
Member#: 310053
2008 Impreza 2.5i
Dark Gray Metallic
May or may not have ruined my trunk light trying to wire in some LEDs.
howtypical is offline   Reply With Quote
Old 06-25-2012, 10:45 PM   #5542
DirknJirkn13
Member#: 249696
2010 Outback Sport
How so?
DirknJirkn13 is offline   Reply With Quote
Old 06-26-2012, 12:13 AM   #5543
howtypical
Member#: 310053
2008 Impreza 2.5i
Dark Gray Metallic
How so?
Well, I went with my best friend (whose into wiring and electronics and such) to Advance to buy some LEDs to replace my dome light with. Long story short, to put them in turned into a "thing", so we tried to do it with the light in the hatch. That too turned into a "thing". We pulled out the little plastic piece that holds the bulb, and removed it, figuring that if we could get the metal parts that actually hold the bulb in place out (in a safe, non-destructive fashion) we could just pop this light in and call it a day. We got one of the metal doo-dads out, but the other wouldn't budge - then it started pouring out of no where. So I put it all back together and popped it back in, but the light wouldn't work. I'm thinking (hoping, really) that we just put something in backwards. Any other thoughts? I'll try to take pictures or something tomorrow.
Old 06-26-2012, 12:16 AM   #5544
theoutbackdream
Member#: 301179
2013 WRX Limited
did you leave the battery connected? I suspect it could be a short too... needing a new fuse. I had my battery disconnected and I had touched both +/- side very easily.
BTW, what started pouring?
Old 06-26-2012, 12:22 AM   #5545
howtypical
Member#: 310053
2008 Impreza 2.5i
Dark Gray Metallic
Haha the rain sir; it was on and off all day.
I was thinking it could be a short too. We did leave the batter connected. Was that a stupid thing? How would a get a new fuse and where would I install it? I'm clueless about wiring. I figured putting in some LEDs would be something quick and easy.
Old 06-26-2012, 12:27 AM   #5546
theoutbackdream
Member#: 301179
2013 WRX Limited
I see.
Yes, it was a "dumb" thing to do, but hey we all make mistakes. Just go to your local auto store and they should have a fuse to replace. You would put it in your fuse box...??????????
Old 06-26-2012, 12:27 AM   #5547
howtypical
Member#: 310053
2008 Impreza 2.5i
Dark Gray Metallic
I see.
Sorry, noob here. Thanks man.
Old 06-26-2012, 01:16 AM   #5548
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Shoulda just bought the dome light led replacements....plug and play for less than 20 bucks lol
Old 06-26-2012, 02:40 AM   #5549
theoutbackdream
Member#: 301179
2013 WRX Limited
^now that you say that, i wonder what kind of LEDs he bought. :shocked:
Old 06-26-2012, 12:48 PM   #5550
howtypical
Member#: 310053
2008 Impreza 2.5i
Dark Gray Metallic
That's exactly what these were marketed as at the store. They're plug and play, and were exactly 20 bucks. Problem is though that they look like crap. They plug in using a "mock bulb" that sends the power to this panel of LEDs. The only place to stick the panel is off the center, and it just doesn't look very good; kinda ricey. I'm gonna see if I can return them today, as well as fix that blown fuse. I thought I was saving money by a cheapo LED set from advance, but for cheaper I could have bought these: http://store.ijdmtoy.com/DE3175-DE30...-1-25-s/38.htm
They fit right in like the regular bulb.
Live and learn, I suppose. Right?
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
