Old 06-30-2012, 06:38 PM   #5626
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Never had rough idle, but it couldn't hurt!
BWX is offline   Reply With Quote
Old 06-30-2012, 08:42 PM   #5627
RyanChadwick
Member#: 319509
2008 Impreza 2.5i
Okay I just drove 300 miles away from home to Hampton beach in new Hampshire. **** off my car went and checked into my hotel. Went back out to park my car and it won't rev over 2.5k rpm's. What do i do? Lol
RyanChadwick is offline   Reply With Quote
Old 06-30-2012, 09:43 PM   #5628
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Is it in 'safe mode' or w/e and running a CEL?
Digital Dillon is offline   Reply With Quote
Old 06-30-2012, 10:12 PM   #5629
RyanChadwick
Member#: 319509
2008 Impreza 2.5i
Idk what safe mode is in it or how to tell but the check engine light is on.
Old 06-30-2012, 10:24 PM   #5630
ozunadel
Member#: 313772
1992 Skyline r32
work in progress
Well something must have happened. I would check your gas cap.
ozunadel is offline   Reply With Quote
Old 06-30-2012, 10:38 PM   #5631
theoutbackdream
Member#: 301179
2013 WRX Limited
safe made is check engine light on.. Lol Your cruise control should also be flashing meaning its disabled to prevent any unnessecary damage.
As said, check your gas cap. If you had a valet parking, your answer could be right there.. someone drove it last night and then filled it back up.
theoutbackdream is offline   Reply With Quote
Old 06-30-2012, 10:59 PM   #5632
subi2.5i
Member#: 236778
08 Impreza
If you have time try undoing a battery terminal for a couple minutes and reconnect it, mabe it will get rid of it :-/
subi2.5i is offline   Reply With Quote
Old 07-01-2012, 11:43 AM   #5633
bidaci
Member#: 291519
2011 OBS
Originally Posted by Digital Dillon View Post
A lot of people are running the Nameless Performance axlebacks on their cars!
I picked up a Nameless axle back (with magnaflox muffler) yesterday and bolted it up today. Locks great and I love the sound. I just need to make up a plate to get a better seal at the flanges.
bidaci is offline   Reply With Quote
Old 07-01-2012, 12:39 PM   #5634
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
Picked up a STI rear sway bar..cant wait to put it on!
Want some advice from you guys. My next/ last big purchase for this car will be lowering it. I can't make up my mind between a strut/ spring combo or coils. I daily drive this car and I do not plan on slamming it. I like the idea of adjusting the height of the car but I'm not sure how much the handling will change.
My options (open to other ideas too)
konis/ rce springs
or
bc coils
daigledangle8 is offline   Reply With Quote
Old 07-01-2012, 12:46 PM   #5635
howtypical
Member#: 310053
2008 Impreza 2.5i
Dark Gray Metallic
Originally Posted by scoobymatt93 View Post
FINALLY got some new wheels! My car's almost exactly where I want it. Rallisport UEL headers are on the way, Tsudo N1 is sitting in the garage, and coilivers are the last purchase on the list. She's coming along perfectly
Holy crap that's sexy.
howtypical is offline   Reply With Quote
Old 07-01-2012, 01:09 PM   #5636
theoutbackdream
Member#: 301179
2013 WRX Limited
I thought STI rear sway bars dont fit because they use a wider mounting point...??? Right???
Old 07-01-2012, 01:12 PM   #5637
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Thought it was the fronts that don't fit?
fancyfootwork15 is offline   Reply With Quote
Old 07-01-2012, 01:33 PM   #5638
theoutbackdream
Member#: 301179
2013 WRX Limited
fronts dont fit for sure because of the exhaust layout, but i thought the Rear was only inter-changable with the WRX due to the STI's wider track layout. I may be wrong though.
Old 07-01-2012, 01:35 PM   #5639
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
i think it will fit, its just you will be mounting it on the outside of the endlinks
Navysesal is offline   Reply With Quote
Old 07-01-2012, 01:37 PM   #5640
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
http://forums.nasioc.com/forums/show....php?t=2170778
http://forums.nasioc.com/forums/show....php?t=2149899
Old 07-01-2012, 01:49 PM   #5641
Eric91Z
Member#: 216858
2009 Impreza OBSlow
Steel Silver/Spark Silver
konis/ rce springs
or
bc coils
I understand your questions as I keep going back and forth. But the Koni had not been an option since it is just an insert for stock strut/shock body.
It would either be the Bilstein/RCE springs or BC Coils based on budget I have set. I have read a lot of positive reviews of the BC coils and one local friend has them and her likes then for daily diving, road trips, and autocross. Pretty sure I will be going with the BC BR series Coilovers, personally...
Eric91Z is offline   Reply With Quote
Old 07-01-2012, 01:54 PM   #5642
ozunadel
Member#: 313772
1992 Skyline r32
work in progress
I have the BC coilovers on my 2011 impreza. try are actually pretty good for daily driving and they have the adjustable dampners which are nice
Old 07-01-2012, 01:57 PM   #5643
Eric91Z
Member#: 216858
2009 Impreza OBSlow
Oh, the other thing about the BC that I like is complete setup. Unbolt and remove stock spring/strut together and bolt in the coilovers. And then you have the stock setup all together if you ever need to reinstall one day...
Old 07-01-2012, 02:14 PM   #5644
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
It would either be the Bilstein/RCE springs or BC Coils based on budget I have set..
Do you still want to keep your oem struts then? If so, why don't you get a donor set of struts for the koni inserts? If you can find some donor struts for the right price it can be cheaper than the bilstein setup.Yes it is a little more work, but if you are on a budget it adds up
Not saying bc's or bilsteins are bad or anything because they are both actually pretty good for the price.
@Daigledangle, you just need to outweigh what you want most, since you mentioned you don't really want togo super low, I think either the koni or bilstein setup is the way to go. Bilstein is direct Bolt on, a little more expensive, you cant really adjust the height that I know of, and you may have to wait for ever to get it. Koni's have have freedom to choose springs, adjustable dampening, can be cheaper, usually are available, and they are yellow too! Sorry if I'm a little biased lol
KartRacer3 is offline   Reply With Quote
Old 07-01-2012, 02:33 PM   #5645
premier00000
Member#: 251060
2008 Impreza Outback
What's your budget that you have for suspension? I like my k-sport coilovers
premier00000 is offline   Reply With Quote
Old 07-01-2012, 10:39 PM   #5646
Eric91Z
Member#: 216858
2009 Impreza OBSlow
I would like to be in the $1000-$1200 range as spending little more to go with the Whiteline front and rear adjustable sway bars and Whiteline HD endlinks.
Old 07-02-2012, 12:44 AM   #5647
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
You could also save some money by getting rallitek sway bars as well-they are solid tubing not hollow like cheaper brands (whitelines are solid as well), just a word of advice.
Old 07-02-2012, 01:14 AM   #5648
NineBreaker
Member#: 237756
2011 2.5i Sedan
Are those the 18's?
NineBreaker is offline   Reply With Quote
Old 07-02-2012, 09:46 AM   #5649
Eric91Z
Member#: 216858
2009 Impreza OBSlow
Planning on going with bigger sway bars than what RalliTEK offers. I think there's is a great option at a good price, but I want bigger bars and also looking at going 22mm/22mm adjustable for front and rear...
Old 07-02-2012, 12:29 PM   #5650
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Glad to see you did your research then
I too want a 22mm for the back but it's a little spendy IMO.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
