Old 07-19-2012, 02:17 PM   #5826
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
For 30k mile service check manual.
BWX is offline   Reply With Quote
Old 07-19-2012, 02:20 PM   #5827
subi2.5i
Member#: 236778
08 Impreza
Any of you guys running brembos or a 4/2 pot set up. Just wondering where I find the brackets for the calipers.
subi2.5i is offline   Reply With Quote
Old 07-19-2012, 02:21 PM   #5828
ozunadel
Member#: 313772
1992 Skyline r32
work in progress
Or search DIY: 30k service for naturally aspirated engines
ozunadel is offline   Reply With Quote
Old 07-19-2012, 02:23 PM   #5829
DirknJirkn13
Member#: 249696
2010 Outback Sport
Originally Posted by theoutbackdream View Post
How's your throttle body plate? Navysesal cleaned his and i think he got good results. I did the same but the results weren't too different as my tbp wasn't too dirty but i did feel it.
I'll check it when I get some time. Thanks!
Originally Posted by ozunadel View Post
It honestly could just be the weather all in all. And for my 30k I did oil change 4 spark plugs cleaned the MAF and IACV change tranny and rear diff fluid runs like a champ
If nothing comes out of it, I'll blame it on the weather . Did you do everything yourself, or have the dealer do it?
Thanks
DirknJirkn13 is offline   Reply With Quote
Old 07-19-2012, 02:23 PM   #5830
ozunadel
Member#: 313772
1992 Skyline r32
work in progress
Originally Posted by Hotsho111
After doing tons of searching and not finding much information for naturally aspirated Imprezas I figured I would write up a 30k DIY.
From left to right:
1/2" Ratchet (for rear diff)
3/8" Ratchet with T-70 bit - $3.99 at Autozone for the T-70
Deep socket with extension for PCV valve and spark plugs
OEM PCV Valve - $16.83 PCV Valve Subaru Part #11810AA040
CRC MAF Cleaner - $6-8 at Autozone (can't remember)
Subaru Cooling System Conditioner - $2.75 (1 x 125mL) from Subaru
1 Gallon of Subaru Long Life Engine Coolant (Unmixed)* - $22.64 from Subaru
NGK Spark Plug Wires** - $41 Subaru Part #SOA430Q124
NGK FR5AP-11 (.38-.42 gap) - $25 Subaru Part #22401AA65A
5 Quarts of Subaru Extra S 75W/90 - $63 shipped
Purolator PureONE Oil filter (not pictured) - $8 at Advanced Auto Parts
5 quarts Amsoil 5W-30 Full Synthetic (not pictured) - $43
Total: $233.21
*I mixed it 50/50 with diluted water myself you can also buy premixed stuff but it would be more expensive because you would need 2 gallons instead of 1
**I ended up not replacing the spark plug wires after purchasing 2 sets that were OEM replacements that didn't fit and didn't want to spend $80 at a dealership. They are easy to replace and if you have any questions about it feel free to ask. For those wondering the pictures of the spark plug wires with that part number are generally these:
THESE ARE NOT THE CORRECT WIRES. The end that connects to the ignition coil are right angled.
Proper wires can be found here: http://www.kingsbornewires.com/produ...&productId=518
Transmission Fluid Change
The first thing to do is to move the intake out of the way. Remove the two screws and disconnect the hoses and you can move the air box out of the way (I left it on the intake manifold)
This is what it looks like with the airbox out of the way
Remove the rest of the intake system. The top is held on by two clips. Also unhook the cable from the MAF sensor (put this aside, we will get back to it later)
Here you can see the tranny fill hole
Next get under the car and use the T-70 bit to drain the tranny reservoir
Here you can see the tranny fill hole. The front of the car is to the left in this picture. If you look above the exhaust you can see the inner ring of the wheel and tire so you can get an idea of where it is.
The plug has a magnet on it to keep metal scrapings away from moving parts. This is what mine looked like when I took it out (I couldn't get a clear picture of it)
and after cleaning it...
Screw the plug back in and put about 3.25 quarts of tranny fluid into the fill hole and check the fill level. Add the appropriate amount to reach the full fill level. The fill level is 3.7 quarts but you probably won't be able to drain it all so you will probably put in a little less.
Rear Differential Fluid Change
Using the 1/2" ratchet unscrew the diff plugs. NOTE: Unscrew the top plug first!! If you unscrew the bottom plug and can't get the top plug out you will be left with a rear diff with no fluid in it, which is bad. I'm tall so I put the ratchet in the plug and used my leg, with me on the side of the car and my knee near the tire, to get the plugs started because I couldn't do anything else to get any leverage.
Here it is
Old 07-19-2012, 02:27 PM   #5831
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
definitely clean the throttle body and the MAF. That already made a big difference in the sluggishness. I also have a hybrid intake, so IDK if that made a difference at all. I also put some cheveron injector cleaner but it didn't make a whole lot of difference, just made the lag a little less. I would say it might be the spark plugs, but i heard the more modern ones clean themselves at like 5000 degrees or something?
but its definitely the weather, it seems from my experience our cars like to run in the 65ish degrees area. But for some reason around 2 when i get off work the throttle and clutch stiffens up and makes it more fun to drive
outbackdream, you cleaned it too didn't you?
how did it go for you?
Navysesal is offline   Reply With Quote
Old 07-19-2012, 02:31 PM   #5832
ozunadel
Member#: 313772
1992 Skyline r32
work in progress
Dirk, I did every thjng myself. Much cheaper that way and that post I posted there is about 2 more pages but if you search you'll find it. That's what I followed when I did mine
Old 07-19-2012, 02:36 PM   #5833
DirknJirkn13
Member#: 249696
2010 Outback Sport
Thanks a bunch, will definitely come in handy.
Old 07-19-2012, 03:31 PM   #5834
theoutbackdream
Member#: 301179
2013 WRX Limited
Yup i did, I did feel results, but the difference wasnt too big, due to the tbh not being so dirty.
theoutbackdream is offline   Reply With Quote
Old 07-19-2012, 08:20 PM   #5835
NineBreaker
Member#: 237756
2011 2.5i Sedan
Here it is
plugs and wires at 30k... isn't that a little excessive?
NineBreaker is offline   Reply With Quote
Old 07-19-2012, 11:33 PM   #5836
2point5 09i
Member#: 262188
2009 2.5i
Hey, theoutbackdream are you still running without the snorkus? if so any effects?
2point5 09i is offline   Reply With Quote
Old 07-19-2012, 11:50 PM   #5837
theoutbackdream
Member#: 301179
2013 WRX Limited
nope not at the moment. And when i did have it on, louder at WOT, but the throttle response went down. Overall performance went down.
Old 07-20-2012, 12:04 AM   #5838
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
If your looking for the sound or for a slight increase in hp for cheap, I would recommend a hybrid intake ;D
Old 07-20-2012, 05:37 PM   #5839
sixstr37
Member#: 293491
Default 08 Impreza Halo DRL!
sixstr37 is offline   Reply With Quote
Old 07-20-2012, 10:21 PM   #5840
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Originally Posted by sixstr37 View Post
Not bad.. That's what I was thinking about doing instead of practically useless stock fogs. I like it!
Old 07-20-2012, 11:40 PM   #5841
theoutbackdream
Member#: 301179
2013 WRX Limited
Looks Sick!
Im glad you didnt go for that cheapo ebay led stuff that every one wants on their car.
Old 07-21-2012, 10:41 AM   #5842
Grimdajow06
Member#: 324758
2015 WRX
ISM
Wow those are nice, where did u get them ?
Grimdajow06 is offline   Reply With Quote
Old 07-21-2012, 05:02 PM   #5843
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I want to know exactly how sixstr37 did it. Although I might change some things, it'd be a good start.
I want to have it so they come on with the DTR light, but also with regular lows and highs, but a switch to turn them off in the cabin. So auto on with car, but with a kill switch. Shouldn't be too difficult.
Also, more importantly, where did you buy them? How did you install them into the cut-outs?
Old 07-21-2012, 11:31 PM   #5844
theoutbackdream
Member#: 301179
2013 WRX Limited
Alright so i just did an oil change today, and at 3k using synthetic oil, (why because i drove in really dirty/dusty areas on my trip around the states), I had Lost almost all my oil and there was only oil alittle bit above the low circle mark. There is no leaks, so what could it be?
This is the first time ive had it eat this much oil. prior, at 3k, oil would be down to about half.
Thanks
Old 07-22-2012, 12:30 AM   #5845
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
my new wheels
drag dr-31 17x9 +38 tires are kuhmo 245/40/17
thegonz is offline   Reply With Quote
Old 07-22-2012, 01:47 AM   #5846
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Thanks
Happened to be when I used 10w30. (i didnt put the oil in) >.> my sis BF got it fpr my birthday a whole ago
Old 07-22-2012, 11:22 AM   #5847
OgBL6
Member#: 306368
2011 Impreza 2.5i
Originally Posted by thegonz View Post
my new wheels
look's good man.
suspension?
OgBL6 is offline   Reply With Quote
Old 07-23-2012, 01:38 PM   #5848
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Installed the relatively new style, dba 4000 t3 slotted series front rotors with **wrx caliper brackets** and some dba 4000 slotted rotors in the rear over the weekend. Should have some pictures up a little later. Also had a chance to install the whiteline gearbox positive shift kit and wow! worlds of a difference. I recall a few of you saying that when you had teh A/c on, the car would decelerate in gear very harshly and this helps a lot with that feeling along with any harsh downshifting/upshifting slop from the transmission. I'd definitely recommend it since its relatively cheap (I got mine for $35shipped from the classifieds) and makes a big improvement. Also, you might as well replace the transmission mount while you are still down their as well. Below I have links as to the parts I used. Happy modding monday!
http://www.rallysportdirect.com/Whit...tive-Shift-Kit
http://www.rallysportdirect.com/DBA-...ed-Front-Rotor
http://www.fastwrx.com/dbarotors1.html - they no longer make these but if you can find them, Im sure you can get a good deal on them!
KartRacer3 is offline   Reply With Quote
Old 07-23-2012, 08:00 PM   #5849
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
Posted this in the tire fitment thread but I was hoping to get a more direct answer in this thread, hopefully someone can help me out.
Wheel size/offset: 17x8.25 35offset
Tire brand/model: Dunlop Star Specs
Tire size: 235/40/17
Suspension: Stock for right now (Epic Springs?)
Fender Mods: rolled rear fenders (for now?)
Planning on picking up some Epic Springs with 09 WRX struts. Will I need to roll my front fenders? Thank you.
daigledangle8 is offline   Reply With Quote
Old 07-23-2012, 08:13 PM   #5850
subi2.5i
Member#: 236778
08 Impreza
You will have more than enough room
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 03:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 12:57 PM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 10:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 03:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 03:35 PM
