Old 07-23-2012, 08:23 PM   #5851
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
Originally Posted by OgBL6 View Post
look's good man.
suspension?
megan coilovers
cobb 22mm front sway bar
perrin rear 19mm adj. sway
rallitek f/r endlinks
cusco fron strut bar
ebay rear strut bar
idk if you want my whole list but i gave it to you ha
thegonz is offline   Reply With Quote
Old 07-23-2012, 09:52 PM   #5852
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Originally Posted by daigledangle8
Posted this in the tire fitment thread but I was hoping to get a more direct answer in this thread, hopefully someone can help me out.
Wheel size/offset: 17x8.25 35offset
Tire brand/model: Dunlop Star Specs
Tire size: 235/40/17
Suspension: Stock for right now (Epic Springs?)
Fender Mods: rolled rear fenders (for now?)
Planning on picking up some Epic Springs with 09 WRX struts. Will I need to roll my front fenders? Thank you.
I also think you will be fine. Unless you decided to put some 255's on their haha.
KartRacer3 is offline   Reply With Quote
Old 07-24-2012, 05:32 AM   #5853
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
Originally Posted by subi2.5i View Post
You will have more than enough room
Okay, thank you for the help guys! Springs should be going on this Friday. I will have pics posted soon!
daigledangle8 is offline   Reply With Quote
Old 07-24-2012, 12:48 PM   #5854
EBzspeed3
Member#: 284233
2009 Impreza 2.5i
sunlight gold opal
My headlights have sort of a haze to them. It is not on the outside though. Do you guys think the seal is broken? It looks like dust
Opinions are much appreciated.
Thanks
-EB
EBzspeed3 is offline   Reply With Quote
Old 07-24-2012, 12:59 PM   #5855
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Thanks
-EB
Seal may be broken. I have the same exact haze on my headlights, although when I installed my Hid's I had to modify the oem housing and I think that's where its coming from. However when I got a clean microfiber and rubbed the outside surface very hard with some windex it actually removed some of it which made me realize it could just be oxidation on the outside so Im confused...
Anyone have a solution to this problem?
Old 07-24-2012, 01:42 PM   #5856
theoutbackdream
Member#: 301179
2013 WRX Limited
I believe kartracer is right. The seal looks broken and causing a bit of condensation in the headlight.
theoutbackdream is offline   Reply With Quote
Old 07-24-2012, 03:16 PM   #5857
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
From this past Sunday...
JourdanWithaU is offline   Reply With Quote
Old 07-24-2012, 03:22 PM   #5858
EBzspeed3
Member#: 284233
2009 Impreza 2.5i
sunlight gold opal
Alright then the seal is definately broken. I actually used a kit on my headlights to reduce oxidation and it didnt do anything at all, so it has to be inside, in my situation atleast.
Old 07-24-2012, 03:26 PM   #5859
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
How often do you drive with the headlights on?
The heat from the lights could be the cause.
Old 07-24-2012, 03:32 PM   #5860
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
you have free time to autox on sundays now?
Navysesal is offline   Reply With Quote
Old 07-24-2012, 03:35 PM   #5861
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Yeah, my schedule changed. AutoX is also bit more fun than hard parking.
Old 07-24-2012, 03:59 PM   #5862
EBzspeed3
Member#: 284233
2009 Impreza 2.5i
sunlight gold opal
Usually only at night. How would the heat cause it?
Old 07-24-2012, 04:03 PM   #5863
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Thanks
-EB
Get the meguires plastix headlight restore and a micro towel.looks to be just outside I'd it doesn't work them It's inside. I've pulled my headlights apart and after doin that passion I don't see how the seal can just break.it's not like a gasket .is super tacky adhesive you have to heat it up in your oven to get it to pull apart
krzywhtboi82 is offline   Reply With Quote
Old 07-24-2012, 04:03 PM   #5864
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
How often do you drive at night?
Heat from the bulbs can oxidize the plastic the same way the sun does it during the day. It usually doesn't matter, but if you're driving with your lights on a lot, it can speed up the oxidation process.
The PlastX stuff works great.
Old 07-24-2012, 04:05 PM   #5865
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
But then as with the sun it would be on the inside. I do allot of night driving and it doesn't do it to mine
Old 07-24-2012, 04:15 PM   #5866
EBzspeed3
Member#: 284233
2009 Impreza 2.5i
sunlight gold opal
So its possibly oxidation on the inside of the headlight from having the headlights on alot.
Just to make sure, there is no way of opening the headlight to clean the inside correct?
Old 07-24-2012, 04:19 PM   #5867
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Sun on the outside, headlamp on the inside.
The headlight can be opened.
http://www.3gwrx.com/forum/index.php/topic,9323.0.html
It's tricky, but it can be done.
Old 07-24-2012, 04:35 PM   #5868
EBzspeed3
Member#: 284233
2009 Impreza 2.5i
sunlight gold opal
I considered it til it said put your headlight in the oven haha. Thanks though
Old 07-24-2012, 04:59 PM   #5869
ozunadel
Member#: 313772
1992 Skyline r32
work in progress
It's not as bad or hard as it seems
ozunadel is offline   Reply With Quote
Old 07-24-2012, 05:38 PM   #5870
OgBL6
Member#: 306368
2011 Impreza 2.5i
Originally Posted by thegonz View Post
megan coilovers
ebay rear strut bar
haha its all good
i was looking into getting the megan's as well.
how are you liking them on them so far?
OgBL6 is offline   Reply With Quote
Old 07-24-2012, 06:22 PM   #5871
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Thanks
-EB
I personally do not think your seal is broken, I think people are seeing and talking about two different things.
When I haven't hand washed and waxed my car for a while, like over winter, the outside of my lights get a slight haze of road grime that doesn't come completely off even when hand washing.
I just put a coat of wax on my headlights and it's like new again for a while. Once you do that or use some other product similar, you won't see that haze on the outside for quite a while.
The pic above I think is condensation on the inside surface of the polycarbonate outer cover which happens only under certain conditions such as when you wash your car with cold water when the car is still hot from the sun (or heat of day), then temperature drops outside so the condensation doesn't evaporate until your headlights's heat evaporates it after they've been on for a while.
I see the same thing once in a while, but only under certain conditions, and I have no leak.
It is not a vacuum inside our headlights- and air has moisture in in it. Under certain conditions water condensates out of that air in the headlight and collects on inside surface, that does not mean you have a leak, necessarily. Solution, leave on headlights to heat up air in your headlights, and moisture will evaporate.
BWX is offline   Reply With Quote
Old 07-24-2012, 06:52 PM   #5872
Mammoth48
Member#: 316074
10 Months now with mine 2010 2.5i. best purchase ive made in a while.
Mammoth48 is offline   Reply With Quote
Old 07-24-2012, 07:34 PM   #5873
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
You headlights don't oxidizer the inside. Never seen it done especially on that new. Four guys at work(a auto parts store) have done it and two you couldn't even see the bulb they were so bad used the stuff on outside and they looked brand new. I'm saying this from experience I've had I don't claim to kno all cars but to the guy with the prob do outside before you open them
Old 07-24-2012, 11:36 PM   #5874
theoutbackdream
Member#: 301179
2013 WRX Limited
Painted my front grill since i got sick of the chrome and made it look ugly. Lol
Done,about 7layers painted on.
Old 07-24-2012, 11:40 PM   #5875
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
You know, you could have removed the pieces you wanted to paint instead of masking off the whole front end of the car...
Looks good though.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
