Old 09-22-2012, 03:54 AM   #6526
theoutbackdream
Member#: 301179
2013 WRX Limited
Im getting this weird grinding sound from the front axle when I make a left turn on power. Doesnt happen on right turns though... any ideas?
theoutbackdream is offline   Reply With Quote
Old 09-22-2012, 05:00 AM   #6527
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Dang it seems all our cars are having problems at the same time LOL
Navysesal is offline   Reply With Quote
Old 09-22-2012, 08:10 AM   #6528
premier00000
Member#: 251060
2008 Impreza Outback
A left turn on power? I don't get it.
premier00000 is offline   Reply With Quote
Old 09-22-2012, 10:22 AM   #6529
bradyarz
Member#: 272381
Franky the Forester
left turn with the right pedal to the metal.
bradyarz is online now   Reply With Quote
Old 09-22-2012, 12:55 PM   #6530
Dirtyimp.
Member#: 332963
I second heat shield
Dirtyimp. is offline   Reply With Quote
Old 09-22-2012, 01:02 PM   #6531
aceofskies05
Member#: 326539
2008 Impreza 2.5
newport blue
Could it be your tire rubbing on some plastic?
aceofskies05 is offline   Reply With Quote
Old 09-22-2012, 02:03 PM   #6532
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Because NASCAR? J/K... Lol
Fendyman is offline   Reply With Quote
Old 09-22-2012, 02:10 PM   #6533
theoutbackdream
Member#: 301179
2013 WRX Limited
Like when getting off a stop light to make a u turn or making a left turn into another street while giving the car some gas.
I doubt it, im on stock suspension and the turns taken wouldnt be enough to make the wheel rub compared to the more spirited driving i have done.
Old 09-22-2012, 02:12 PM   #6534
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Get under the car to check it. It there any chance the boot might of come off? And are you sure it's not the power steering pump making sounds?
Old 09-22-2012, 02:14 PM   #6535
theoutbackdream
Member#: 301179
2013 WRX Limited
Ill check the boot. I don't think its the power steering pump. It sounds like a loud gear grinding sort of like if your shifting wrong and you grind on your shifts, instead of the high pitch whine from the power steering.
Old 09-22-2012, 02:58 PM   #6536
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
My right brake light went out and my fog light switch isn't working 100% lol
Steve2.5i is offline   Reply With Quote
Old 09-22-2012, 04:10 PM   #6537
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Maybe the CV joint's are worn out? I know those are a problem on higher mileage subaru's but your's has to be less than 80K right?
KartRacer3 is offline   Reply With Quote
Old 09-22-2012, 05:12 PM   #6538
theoutbackdream
Member#: 301179
2013 WRX Limited
maybe, but yea, im at 43k.....
Old 09-22-2012, 07:31 PM   #6539
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Hmm do a little more research and/or maybe get it checked out by a good mechanic. The fact that your car has a salvage title makes me wonder where/who did the work to fix it, ya know?
Old 09-22-2012, 10:35 PM   #6540
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
So my sway bar bushings broke....
Old 09-22-2012, 11:13 PM   #6541
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Random tip of the day - for those who want a cheap, minimal exhaust change, a 08-10 WRX catback is a bolt-on option (flanges match with NO difference or adjustment).
The WRX midpipe is 2.5 instead of 2.25, and the resonator is much smaller. Exhaust pipe after the muffler is also larger. There is barely any difference in sound, a hint of very deep bass at idle, . Probably (to be measured) better flow at high RPM. Given the cost of cheap OEM WRX catbacks and the ease of installing it, it's recommended.
Old 09-23-2012, 12:19 AM   #6542
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Glad to hear everything went smoothly Ian's that you like it but this has been gone over before
Old 09-23-2012, 12:20 AM   #6543
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Time to upgrade
Old 09-23-2012, 01:29 AM   #6544
bradyarz
Member#: 272381
Franky the Forester
Depends on your definition. I've been looking for a 08-10 wrx hatch catback for a year and a half. I can count on one hand the number of times I've found one. They're never near by, and they're never cheap.
Old 09-23-2012, 02:13 AM   #6545
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Lol I live in San Diego n there's always guys trying to get rid of stock wrx catbacks. Seen em go for as cheap as 50 bucks
Old 09-23-2012, 03:49 AM   #6546
theoutbackdream
Member#: 301179
2013 WRX Limited
IMO, not worth the $60 (i spent).. My friend who is a sound freak, couldn't even tell from inside the cabin, and has an annoying drone to it on the freeway.
Idle you are getting is weird, because the sound should be roughly the same and loudness is almost the same.
Old 09-23-2012, 12:05 PM   #6547
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Time to upgrade
Haha, yeah so my mechanic told me I've been cornering too hard on stock bushings haha so hes hooking me up with stronger bushings
Old 09-23-2012, 12:38 PM   #6548
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Mine was free from some guy on the forums.
Digital Dillon is offline   Reply With Quote
Old 09-23-2012, 01:45 PM   #6549
theoutbackdream
Member#: 301179
2013 WRX Limited
Get into your regional forum, make some friends, and get the word out you want a WRX catback cheap. It's likely enough someone will sell you their WRX catback.
I even got a STI quad tip exhaust free for doing that.
Old 09-23-2012, 08:53 PM   #6550
SecondnatureBMX
Member#: 286841
2011 2.5i
Dark Metallic gray
Ok so I promise you guys that I searched for this on here for like a half hour before posting. What thread did you guys use for your snorkus delete / DIY CAI install. Do you guys have any advice on what to buy? Any help would be greatly appreciated.
SecondnatureBMX is offline   Reply With Quote
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 03:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 12:57 PM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 10:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 03:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 03:35 PM
