Old 09-24-2012, 08:53 PM   #6576
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Ok so I had a 2012 wrx rear swaybar on my 09 2.5i and today I picked up a 2012 sti rear sway bar...and it doesn't fit. I dont get it I though the rsb was interchangeable.
Slow Scoobie is offline   Reply With Quote
Old 09-24-2012, 08:55 PM   #6577
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Yes it does fit.
Digital Dillon is offline   Reply With Quote
Old 09-24-2012, 09:05 PM   #6578
theoutbackdream
Member#: 301179
2013 WRX Limited
how doesnt it fit, exactly?
theoutbackdream is offline   Reply With Quote
Old 09-24-2012, 09:09 PM   #6579
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Ill post pictures soon im still under the car trying to see whats going on
the D bracket becomes unaligned when i put the endlink bolt into the end of the swaybar.
When i line up the d bracket the swaybar sits to low to fit onto the endlink bolt.
Old 09-24-2012, 10:31 PM   #6580
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Originally Posted by theoutbackdream View Post
Just curious, would there be a downside to too-much powersteering fluid?
Overflow. The level changes depending on the engine temperature. The level goes up as the engine gets warmer.
Is the car on level ground? The alignment problems you're seeing could be because the suspension on one side is compressed more than the other.
JourdanWithaU is offline   Reply With Quote
Old 09-24-2012, 10:51 PM   #6581
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
@JourdanWithaU Yea the car is on my drive way(perfectly flat) and i have both sides of the car jacked up with both rear wheels off the ground. Its weird because o can push the bar down and make it fit...but i don't feel comfortable leaving it like that, like im gonna be putting extra strain on it or somthing.
Old 09-24-2012, 11:07 PM   #6582
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Take the car off the jack and you need to force the bar and links into place. Especially if one side is already in tight.
fancyfootwork15 is offline   Reply With Quote
Old 09-24-2012, 11:09 PM   #6583
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
are you tightening one side at a time? Your suppose to put all the bolts on loosely then you tighten them all together
Navysesal is offline   Reply With Quote
Old 09-25-2012, 01:17 AM   #6584
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
I didnt have any bolts actually tightend just loosely screwed in to keep the bar in place. I finally forced the bar on, but now I get a creeking sound when I corner going under 20mph.
Old 09-25-2012, 01:28 AM   #6585
theoutbackdream
Member#: 301179
2013 WRX Limited
did you apply grease on the bushings in/out?
Old 09-25-2012, 03:02 AM   #6586
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Just force it together. It's a piece of spring steel, it's going to be fine.
Old 09-25-2012, 04:27 AM   #6587
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
you have to over grease it like crazy, i didn't grease it enough last time and it started to rub the paint off the bar
Old 09-25-2012, 08:27 AM   #6588
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Yea I just greased it this morning and the creeking stopped. Thanks everyone for your input.
Old 09-25-2012, 10:23 AM   #6589
d.o.b 2.5i
Member#: 268284
2008 2.5i impreza
spark silver
suspension upgrade, need new struts. Who makes strong lasting struts?
d.o.b 2.5i is offline   Reply With Quote
Old 09-25-2012, 10:27 AM   #6590
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
I got koni with h&r springs slight drop GREAT handling improvement for an everyday car
Silver08Waggs is offline   Reply With Quote
Old 09-25-2012, 10:48 AM   #6591
d.o.b 2.5i
Member#: 268284
2008 2.5i impreza
spark silver
What website did you order from?
Old 09-25-2012, 11:35 AM   #6592
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Same thing except I got RCE yellow's. On full soft it feels a lot firmer than stock but is still comfortable for rough roads in the city. The yellow's also drop your car slightly less than the H&R springs.
If you contact boston motorsports ( a vendor here on nasioc) Im sure they could get a combo deal for you
KartRacer3 is offline   Reply With Quote
Old 09-25-2012, 12:29 PM   #6593
KevinKe
Member#: 283593
2008 Impreza 2.5i
Red
Here's some pics of some of the things I've been doing to my 2.5i over the last couple of weeks:
Painted over the beige center console with Rust-Oleum Satin black (made for any surface) - Added a shift knob to match.
Haven't decided what I'm going to do with the brake boot yet.
Used a black Plasti-dip on the hatch door panel. I wanted this darker because equipment I haul was scuffing the light beige up really bad.
Replaced the stock radio head unit with a JVC. This one has bluetooth and lets me make calls through my phone + stream pandora/mp3's.
Also, my stock HU didn't have AUX and CD-player stopped reading CD's. It's mated with a Scosch double-din adapter specifically for 2008 Impreza.
The JVC HU really brought the stock speakers to life - the sound quality and bass is x10 better now - might blow them? I don't care.
I'm working on some other projects at the moment and will post updates.
Adding Hella High/Low Supertones - should be here by end of week
Replacing front Grill - blacking it out/removing badge?
Blacking out rear chrome trim - possibly badge removal - haven't decided
Experimenting with plasti-dip and stock steelies (they're rusting up pretty nicely and need something to make them look a bit nicer )
KevinKe is offline   Reply With Quote
Old 09-25-2012, 01:25 PM   #6594
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
I like what youve done with your preza you should plasti drip your head unit surround and dashboard trim to match the shifter trim. I painted my steelies white(was thinking yellow if I get a bit funky) but theyre my winter wheels set so.
Old 09-25-2012, 01:31 PM   #6595
Tjmac
Member#: 331465
I'd love to do my console too- what's the pluses and minuses : paint vs plastidip?
Tjmac is offline   Reply With Quote
Old 09-25-2012, 01:43 PM   #6596
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
You could always rip the dip off. That's why I dipped most of my interior. Can you post pictures from the phone app?
Old 09-25-2012, 02:13 PM   #6597
KevinKe
Member#: 283593
2008 Impreza 2.5i
Red
I'm most likely going to paint over the dash trim at some point - right now I'm waiting to see how the black paint on the center console holds up. It's been a few weeks without any flaking or scratches removing paint. So far so good.
If/when I do it, I'll probably use the same black paint I used on the center console instead of plastidip.
I like using plastidip on pieces I'm unsure of - as it can be removed extremely easily if needed (just tear it off).
Plastidip is pretty durable from what I've seen so far; although, if anything hard or sharp drags across it, it may tear up a bit.
I applied it to my rear chrome trim - not sure how much I like it yet, as I may want something a bit darker/shinier.
Old 09-25-2012, 02:15 PM   #6598
09subi2.5i
Member#: 331636
09 impreza
paprika
Anybody tried either the volo performance chip or the avo controller for our cars? May not be the right thread but I wanna hear from the 2.5i
09subi2.5i is offline   Reply With Quote
Old 09-25-2012, 02:42 PM   #6599
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
KevinKe,
You should just get your hatch trim paint matched. Overall I think the paint match would look much better than stock or plastidip. But for the mean time the plastidip seems okay
Old 09-25-2012, 04:32 PM   #6600
KevinKe
Member#: 283593
2008 Impreza 2.5i
Red
Plastidip steelie - I like it a lot more than with the hubcaps.
Originally Posted by KartRacer3 View Post
KevinKe,
I know that'd be great. I wonder how pricey it is?
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
