Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 10-14-2012, 08:14 PM   #6951
theoutbackdream
Member#: 301179
2013 WRX Limited
Originally Posted by bradyarz View Post
I thought I had read where Mobil 1 syn 30 weight is actually made from a 20 weight, and thus shears (I think that's the right word) faster, leading to a situation where you could burn more oil.
Can anyone confirm?
Never heard of this...
Who told you this?
theoutbackdream is offline   Reply With Quote
Old 10-14-2012, 09:55 PM   #6952
bradyarz
Member#: 272381
2008 Impreza OBS
Who told you this?
Read it somewhere here on nasioc (yeah, yeah, I know )
I'll see if I can find it again, but I won't make any promises.
Edit: I just did a google search for Mobil 1 shearing in a Subaru application, and plenty of stuff comes up. That said, I didn't find much in the way of technical data, mostly hearsay. There are a few oil analyses that do pop up in the search results, but I don't know enough about reading them to tell you what they mean.
Reasons to worry:
1) If the oil is in fact shearing from a 5w30 to something approaching a 5w20, that's bad, especially with a horizontally opposed engine. Increased engine wear is pretty much the guaranteed result (if this is in fact the case).
Reasons to tell me to go pound sand:
1) This is apparently an issue mostly with Mobil 1 syn 5w30. Their 0w40 is thought to be ok.
2) Most of the threads where this pops up as an issue are turbo related. The oil temps in a turbo car are much higher, and thus harder on the oil. I can't say it will be a non-issue for the N/A crowd (without technical data), but it may be worth a second look.
Also, The Shell Rotella Syn is highly regarded.
Now, having said all that, I still use cheap dino oil in my car and just keep up with the changes. I'll likely get an oil analysis someday, but I'm not too worried yet.
bradyarz is offline   Reply With Quote
Old 10-15-2012, 03:03 AM   #6953
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Originally Posted by BWX View Post
28,000 miles and no oil burnt. I drive 90+ mph at times too. When I really thrash it- like up a steep hill or something, I smell what smells like burning oil, or something just really hot. Not always though.
edit
Always used Mobil 1 syn.. but changed over to Subaru synthetic a few oil changed ago.
I get the same thing too. Mobil 1 has been good for me though. I do check my oil often as well as change it. Surprisingly, I see no oil loss nor do i have to add.
BSP671 is online now   Reply With Quote
Old 10-16-2012, 06:55 PM   #6954
DirknJirkn13
Member#: 249696
2010 Outback Sport
Bayson R STI hatch spoilers are in stock on eBay if anyone is interested. $240 shipped.
http://goo.gl/Cih49
DirknJirkn13 is offline   Reply With Quote
Old 10-16-2012, 07:00 PM   #6955
theoutbackdream
Member#: 301179
2013 WRX Limited
Hey people with the Tsudo N1...
I put the tip silencer into the exhaust for the cold mornings, but noticed a LOT less people have noticed me around and almost got hit twice because I was in their blind spot...
Only issue is, I cant get the silencer out!!! I've tried driving hard without a bolt... Nothing. Tried using WD40 to loosen it, and drive hard... Nothing.. I tried yanking on it too.. Nothing!
What should I do??
Old 10-16-2012, 07:31 PM   #6956
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Have you tried pulling it out while cold? If not that get something with a hook on the end?
Also, not to sound like a dick, but maybe it's a good idea to NOT drive in someone's blind spot?
JourdanWithaU is online now   Reply With Quote
Old 10-16-2012, 07:33 PM   #6957
theoutbackdream
Member#: 301179
2013 WRX Limited
Ill try tomorrow morning. Im trying to find a hook, but most are too brittle (plastic), or are too big to fit in the silencer hole.
I wasn't trying to. Traffic was building up, so I was surrounded. couldn't do much.
Old 10-16-2012, 07:36 PM   #6958
bidaci
Member#: 291519
2011 OBS
Bend a metal coat hanger into a hook and use some vice grips as a handle.
bidaci is offline   Reply With Quote
Old 10-16-2012, 07:38 PM   #6959
theoutbackdream
Member#: 301179
2013 WRX Limited
Tried this, not strong enough as it bends back as you start pulling.
Old 10-16-2012, 09:41 PM   #6960
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Idk how far in the silencer is but maybe a large Allen wrench?
KartRacer3 is offline   Reply With Quote
Old 10-16-2012, 09:43 PM   #6961
DirknJirkn13
Member#: 249696
2010 Outback Sport
I used to cross my hands and put two fingers on each side of the inner part of the silencer and pull out as hard as I could.
Old 10-16-2012, 10:02 PM   #6962
KevinKe
Member#: 283593
2008 Impreza 2.5i
Red
I called up my local muffler shop and they said they use all flowmaster. I think I'm going to have them install a dbx muffler within the next two months.
Anyone have experience with any other flowmaster products?
Hit it with a wrench
KevinKe is offline   Reply With Quote
Old 10-16-2012, 10:14 PM   #6963
theoutbackdream
Member#: 301179
2013 WRX Limited
I dont think it can. But ill try. LOL
Ill try that tomrrrow morning.
Old 10-17-2012, 01:00 AM   #6964
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Originally Posted by fancyfootwork15 View Post
Sounds like your clutch.
How would hot smell going 90+ mph or fast up a hill at high rpm be a clutch problem? My clutch is like new, I have 28,000 miles. It doesn't slip or do anything weird.
I had a '85 Honda Prelude 2.0si back in the day that had 89k miles when I got it, and 155k miles when I sold it, with original clutch, and I drove that harder than I ever drive this Impreza.
I think it's just what it smells like when it gets hot- or it may be burning a little oil, but not enough to see the difference on the dipstick. Edit* -Or maybe oil burning off something down there from when guy at Subaru dealer spills oil when changing it, that only gets hot enough to burn the oil if I really run the thing hard.. That's possible too.
My car is hardly just broken in.
BWX is offline   Reply With Quote
Old 10-17-2012, 06:22 AM   #6965
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
You made it sound like you ride it hard in 1st and 2nd on hills.
fancyfootwork15 is online now   Reply With Quote
Old 10-17-2012, 07:58 AM   #6966
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Cant be the clutch cuz i have the same thing with my 4eat. Pretty sure its something to do with the fluids.
Old 10-17-2012, 08:08 AM   #6967
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
OIC.. Yeah I was talking about just going up a hill at medium or high rpm..
It is weird though.. it used to worry me, but not anymore. Happens to quite a few people.
Old 10-17-2012, 01:48 PM   #6968
bidaci
Member#: 291519
2011 OBS
If you bent the coat hanger into a V at the end and it is straightening out you are really stuck. As a desperate try you could always use a large dent puller with either the hook end or a long bolt attached to the nut from a butterfly bolt (like they use on drywall). Maybe the sharp banging will loosen it up enough.
Old 10-17-2012, 03:24 PM   #6969
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Maybe a slide hammer set. U can rent a set from AutoZone that has a 3 jaw puller with it
krzywhtboi82 is offline   Reply With Quote
Old 10-17-2012, 04:11 PM   #6970
theoutbackdream
Member#: 301179
2013 WRX Limited
crap.......
lol
Ill try that too.
I read up on that, but was really confused how that slide hammer worked.. Ill see if i can get one
Old 10-17-2012, 05:27 PM   #6971
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Im getting 20% tint soon. Now to get a detector to keep the popo away.
Slow Scoobie is offline   Reply With Quote
Old 10-17-2012, 05:34 PM   #6972
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Haha I've never been hassled for my 20% but, only across the rear 5 widows
Digital Dillon is offline   Reply With Quote
Old 10-17-2012, 05:58 PM   #6973
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Neither have I, it's not really dark enough to be noticable enough by the police
Navysesal is offline   Reply With Quote
Old 10-17-2012, 06:59 PM   #6974
Digital Dillon
Member#: 288727
2008 WRX premium
I've had an inspector say my widows are dark and friends have also said the same but, I think it's the perfect percent. It provides ample privacy without being too dark to see out of at night.
Old 10-17-2012, 07:09 PM   #6975
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Its just that in the wonderful state of NJ any tint on the front windows is illegal back can be as dark as i want. I mean the 5% strip i put on my windshield is illegal... its 11"s though.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
