Old 11-05-2012, 12:14 PM   #7251
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Originally Posted by Cmac13
Will these headers bolt up direct to the stock pipe?
Correct 100%, headers are also shipped with new class 8 bolts as well.
Sellars21 is offline   Reply With Quote
Old 11-05-2012, 01:10 PM   #7252
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Originally Posted by Digital Dillon View Post
Anyone know if we can fit a 15" wheel?
Wanna go for that rally look during the winter haha
I believe our brakes are the same as 98-01 RS & they clear 15" wheels.
I tried 15" steelies from 02-04 TS & they fit.
Fendyman is offline   Reply With Quote
Old 11-05-2012, 01:13 PM   #7253
DirknJirkn13
Member#: 249696
2010 Outback Sport
Originally Posted by Sellars21
Is that the sti or wrx wing? Looks great by the way. It's the only thing I told the gf that I wanted for Xmas haha
And might I also ask where you guys got it from. I was looking at subaru genuine parts, but the price for unpainted is outrageous.
08+ STI or 09+ WRX wing, they are the same. Got mine unpainted from eBay for less than half the price of Subaru genuine parts.
Had it painted at a local shop for a total cost less than the unpainted price of SGP.
DirknJirkn13 is offline   Reply With Quote
Old 11-05-2012, 03:09 PM   #7254
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Sweet! Look for an 8.5 wide with an offset of 35+ You should be able to fit those with a 235 tire, without modding the fenders.
Im currently on a 17x8 +48 with 235 tire and im rubbing alot in the front only. Fenders mildy rolled and pulled. I would get an 8.5 but the rim I want only comes in an 8" and 9" widths .
Slow Scoobie is offline   Reply With Quote
Old 11-05-2012, 03:18 PM   #7255
lazyimpreza
Member#: 319024
hi 2.5i ers
I've been trying to remove the bounciness of my 2011 2.5i, I've read alot about the spring and oem strut combos, and how they will wear out the OEM struts faster. I get that. But I want to know how the ride quality is after the upgrade of springs (eibach prokit , swift ) on oem shocks is. I do not track the car, it is a daily driver and the roads where I am are not bumpy at all. Can anyone chime in on personal experience on... Eibach Spring and OEM strut...OR...swift spring and OEM strut...OR rceblack and OEM strut?
the Blistein combo or coil over setups are out of the question because theyre out of my budget.
IF any one can give me other suggestions, that would be great.
lazyimpreza is offline   Reply With Quote
Old 11-05-2012, 03:53 PM   #7256
MoLiu
Member#: 319114
the sti and wrx spoiler are the same. I bought mine from an sti owner and got it repainted for only $120
MoLiu is offline   Reply With Quote
Old 11-05-2012, 03:57 PM   #7257
MoLiu
Member#: 319114
Originally Posted by lazyimpreza View Post
hi 2.5i ers
I got the eibach pro kit on my car and the ride quality is pretty good. Not too stiff, not too soft, and not too bumpy. Personally, I'd go with coilovers, the wheel gap on my car is about 1.5" finger gap in the front and 1" finger gap in the back and i want it to be .5"
Old 11-05-2012, 04:37 PM   #7258
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
hi 2.5i ers
If you can't afford new struts/springs or coils then try upgrading to 09+ Wrx suspension, both struts and springs. Relatively cheap, the struts are valved to match the stiffer springs that came on the 09+ models. They are definitely better than your stock setup which has the softer springs that came with the 08wrx's. To answer your question the aftermarket springs will help but keep in mind your stock struts are not valved to match the higher spring rates of aftermarket and will eventually blow (you already know). So on smaller bumps they will feel good but anything like big potholes, you will still get a "bouncyness" feel. I have not put aftermarket springs on my stock struts but with my koni/Rce yellow spring setup on full soft, I get the simulation of what I just described. Hope this helps, goodluck.
KartRacer3 is offline   Reply With Quote
Old 11-05-2012, 04:51 PM   #7259
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Get an alignment? I had -1.5* of camber with 17x9 +38 with 245/40 and never rubbed
What's your next wheel?!
Digital Dillon is offline   Reply With Quote
Old 11-05-2012, 04:54 PM   #7260
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
+1, that's weird. I'm at 17x8+35 with 245/45, around the same camber and I rarely rub with a full car.
Old 11-05-2012, 05:19 PM   #7261
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Well im currently on Rota G-forces and I know some people will see this as a downgrade but I really want the xxr 522 17x9 +35 for the concave look. Also where do you get your alignments done? Are they to your custom specs? Or does the alignment shop just do their thing. Btw Tires are michelin pilot sport plus 235/45/17 with only 2k miles so that why I want to reuse them.
Old 11-05-2012, 07:22 PM   #7262
theoutbackdream
Member#: 301179
2013 WRX Limited
hi 2.5i ers
For cheap, you could get the STI pinks, which are much stiffer and replace the stock springs.. They also give your ride about an 1-1.5" drop.
theoutbackdream is offline   Reply With Quote
Old 11-05-2012, 08:20 PM   #7263
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Just cut the springs
Navysesal is offline   Reply With Quote
Old 11-05-2012, 08:22 PM   #7264
theoutbackdream
Member#: 301179
2013 WRX Limited
This.
Old 11-05-2012, 08:32 PM   #7265
lazyimpreza
Member#: 319024
might look into the 09+ wrx shocks.......+ upgraded springs? now im just getting fancy.
really, cutting the springs work?
appreciate all the input
Old 11-05-2012, 08:33 PM   #7266
Sellars21
Member#: 304055
Do these work on our cars stock shocks? I have a set of Epic Engineering lowing springs on but have already had to put saggy butt spacers on to compensate for some drop.
Old 11-05-2012, 08:36 PM   #7267
theoutbackdream
Member#: 301179
2013 WRX Limited
Lol No, we're kidding. hahaha
Im not 100% sure, but another guy with an OBS used the STI pinks on his, stock OBS shocks, by just switching out the springs and it worked.
Old 11-05-2012, 11:14 PM   #7268
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Read this if you are upgrading brakes lol. I'm in the process of buying the rears now after reading this
http://www.turnfast.com/tech_brakes/brakes_balancing2
Old 11-06-2012, 12:14 AM   #7269
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
nice article, I specifically like how their is calculations with some examples as well. When you mean buying rears, are you referring to upgrading from drum to disc brakes?
I 100% agree that the tires will significantly help in reducing braking distance.
That article makes me want to buy some sti brembo's even more now
Old 11-06-2012, 01:25 AM   #7270
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Lol, my rears are disks I believe. I'm upgrading my rear pads, so it's all EBC red stuff.
Well I've read that brembo upgrades have no improvements. Even track ppl run our brakes systems so they can put track rims on. brembos are mainly for looks, and heat dissapation, correct me if I'm wrong tho; still learning about brake systems
Old 11-06-2012, 01:42 AM   #7271
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Ohh I gotcha. The main reason I want them is I would be upgrading both the front and rear so it shouldnt mess up the brake bias. As well as the overall piston area is larger than ours form what I remember so heat dissipation is much better as you stated. Also the pad selection is much better than ours just like the 06/07 wrx 4/2 pot setups. However the subaru 4/2pot setups are for more pedal feel and the overall piston area is less than stock believe it or not.
Old 11-06-2012, 03:42 AM   #7272
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
ohh i see i see, yeah i get what your saying. right now i'm not feeling much brake bias as i've been reading so much about, but i decided to change out the rear pads too since it was stated in the link that i lose 200lb of braking force. If i ever take a big guy in my car; i would like to have that
Old 11-06-2012, 04:15 AM   #7273
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Are you talking about THIS? If yes, they aren't cheap at all.
Old 11-06-2012, 10:19 AM   #7274
czeckson
Member#: 309412
2010 Impr. 2.0 Sedan
Finally got time to take a picture of the current look,
before dressing in winter-boots.
Intrax HDA coilovers are waiting for installment, too.
czeckson is offline   Reply With Quote
Old 11-06-2012, 10:29 AM   #7275
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
It's still cheaper than the most basic coilovers on the market which are like $500...Also those are for the STI, they have separate springs for the obs/impreza that are called "STI pinks".
Czechson-is a that a 2liter engine??
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
