Old 11-06-2012, 11:26 AM   #7276
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Originally Posted by KartRacer3
It's still cheaper than the most basic coilovers on the market which are like $500...Also those are for the STI, they have separate springs for the obs/impreza that are called "STI pinks".
Czechson-is a that a 2liter engine??
Coilovers include the entire strut assembly, the rubber boot, top hats, and everything pre-assembled.
...for an extra $100 you can get Raceland coils which a few people can chime in on that like them.
Digital Dillon is offline   Reply With Quote
Old 11-06-2012, 12:20 PM   #7277
czeckson
Member#: 309412
2010 Impr. 2.0 Sedan
@KartRacer3:
YES, you´re right: 2.0 R
czeckson is offline   Reply With Quote
Old 11-06-2012, 12:37 PM   #7278
theoutbackdream
Member#: 301179
2013 WRX Limited
Originally Posted by Fendyman
Are you talking about THIS? If yes, they aren't cheap at all.
Yes. Buy them used and it Will be cheap.
theoutbackdream is offline   Reply With Quote
Old 11-06-2012, 12:38 PM   #7279
theoutbackdream
Member#: 301179
2013 WRX Limited
Well, someone on here replaced the stock obs springs with the sti pinks and it worked out for him.
Old 11-06-2012, 12:39 PM   #7280
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
I've also heard that if you get them from england you'll be better off.
Race lands are like the lowest quality coils imo. If your gonna go for coils then I would suggest saving up. Ive heard they can't stand any sort of spirited driving
But I suggest spring strut combo if you dont plan on racing or ever changing the height or dampner set; itll save you loads of money
Navysesal is offline   Reply With Quote
Old 11-06-2012, 01:39 PM   #7281
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
I was referring to the racelands sorry if I wasnt clear.
Originally Posted by czeckson View Post
@KartRacer3:
Thats awesome! Do you know what engine series you have and how does the "R" model differ from the base model?
That's pretty interesting. I wonder if the only difference is the spring rate...If anyone actually knows, let us know!
Yes and YES!
KartRacer3 is offline   Reply With Quote
Old 11-06-2012, 03:41 PM   #7282
Digital Dillon
Member#: 288727
2008 WRX premium
Yes and YES!
I meant I'd recommend Racelands over STi pinks on OEM struts :P
Old 11-06-2012, 04:02 PM   #7283
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
well why didn't you say that before , definitely a good upgrade from it
i think a cheaper option might be 09 struts with springs? or was it inserts? lol
Old 11-06-2012, 04:16 PM   #7284
Digital Dillon
Member#: 288727
2008 WRX premium
I think a cheaper option might be 09 struts with springs? or was it inserts? lol
Sorry 09+ struts can be had for real cheap an springs are $200. The Koni inserts are awesome but I don't know how much they cost? $600 I think?
Old 11-06-2012, 04:17 PM   #7285
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Lol okay.
Old 11-06-2012, 06:12 PM   #7286
.HaVoK.
Member#: 229726
'09 2.Slow
Sandy...
.HaVoK. is offline   Reply With Quote
Old 11-06-2012, 09:25 PM   #7287
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
To my understanding, there are 2 versions STI pinks: 1 for STI & the other 1 for WRX/2.5i/OBS. Both versions will most likely blow our OEM struts/shocks in no time.
For cheap, you could get the STI pinks, which are much stiffer and replace the stock springs.. They also give your ride about an 1-1.5" drop.
I'm not sure the spring rate for STI ones, but according to THIS they are PRETTY stiff. As for WRX/2.5i/OBS ones, they are 187.5 lbs/in F & 172.5 lbs/in R... they are stiffer than 2.5i/OBS & 08 WRX but softer than 09+ WRX.
Also, they don't lower THAT much at all... 10mm (about 0.4").
Most of the used ones I see for sale are for WRX/2.5i/OBS. I haven't really seen the used STI ones for sale.
I think the better option is to get used 08-10 STI springs (similar to 09+ WRX) but the fronts are about 0.5" lower than 09+ WRX so BETTER stance. Probably a good idea to match them w/ 09+ WRX struts/shocks.
Fendyman is offline   Reply With Quote
Old 11-06-2012, 11:12 PM   #7288
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
What u think a set up like that would go for.
Edit.... I can get eibach and kyb's for 600 roughly. I had that on my supra and it was a really good ride and stance. I also had front and rear strut bars and f/r sway bars
krzywhtboi82 is offline   Reply With Quote
Old 11-06-2012, 11:30 PM   #7289
lazyimpreza
Member#: 319024
couldnt find this info anywhere, see if u guys know..
09+ wrx struts are direct fit on 09+ 2.5i but are the wrx struts more stiff than the 2.5i? or theyre actually the same stifness
lazyimpreza is offline   Reply With Quote
Old 11-06-2012, 11:34 PM   #7290
Digital Dillon
Member#: 288727
2008 WRX premium
Yes 100% direct fit. 2008 is the same and 09+ they beefed it up for a sportier ride.
Old 11-06-2012, 11:37 PM   #7291
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Yes, direct fit. 09+ WRX struts/shocks are stiffer (similar as 08-10 STI). Just make sure NOT to get 08 WRX struts/shocks... they are the same as 2.5i ones.
Old 11-06-2012, 11:39 PM   #7292
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Damn... you beat me
Old 11-07-2012, 01:21 AM   #7293
Digital Dillon
Member#: 288727
2008 WRX premium
Damn... you beat me
:lol
Old 11-07-2012, 10:46 AM   #7294
gbkallday2.5i
Member#: 329199
2010 Impreza 2.5
what are some easy modifications that I could do to my car?
exhaust : check
and not much else...
gbkallday2.5i is offline   Reply With Quote
Old 11-07-2012, 10:55 AM   #7295
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Easy being installation difficulty? Suspension upgrades are fairly straightforward. Cosmetics and lighting are some as well.
BSP671 is offline   Reply With Quote
Old 11-07-2012, 10:55 AM   #7296
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
exhaust : check
Tires
Rims
Suspension
Tint
Grill
Wing/spoiler
Dyno-mat
Hids <-- a must!!
New shift knob
Short throw shifter
Double din aftermarket nav unit
Upgraded stereo
Brakes, pads and rotors
And when all else fails, avo has a kit you might want to look into haha
Sellars21 is offline   Reply With Quote
Old 11-07-2012, 10:58 AM   #7297
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Where do you lowered guys get your alignments? I was turned down yesterday because they couldn't get my car on the alignment rack.
Slow Scoobie is offline   Reply With Quote
Old 11-07-2012, 11:03 AM   #7298
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Try taking off the front bumper cover lol
Old 11-07-2012, 11:04 AM   #7299
Sellars21
Member#: 304055
Yes, as quick at possible if you can. After lowing my car it looked alright so I drove for a bit, maybe 350kms. When I brought it in the alignment guy said my tires were toe in, and wouldn't have lasted much more than a few months.
Old 11-07-2012, 11:24 AM   #7300
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
I've thought about it but i'm hesitant. I got pulled over for no rear bumper a few months ago. NJ cops are super anal. Buddy of mine got ticketed for 50% tint on his si. What im asking though is where you get your alignments done, Or do them yourself?
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
