Old 12-18-2012, 04:33 AM   #8051
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Pics? Lucky you get supplies from your work...things stuck in my warehouse are at least 3ft. or wider so it'd be weird to have my boss see me lug things to the car lol
BSP671 is offline   Reply With Quote
Old 12-18-2012, 07:56 AM   #8052
Tafkars
Member#: 305650
2008 Impreza 2.5i-T
Originally Posted by KartRacer3 View Post
Under the Grimmspeed pulley review thread a guy with an 08+ 2.5i (forget the year) mentioned the car ran much smoother and even a slight increase in gas mileage. I mean less rotational mass is always good no matter it's location lol.
I've had my Agency Power LW pulley in since I got the car two years ago. I don't tell anybody I have it because everyone and their mother will just say that it's bad for the engine because it disrupts timing or some other BS. Our cars have a learning ECU, do not listen to them. When you rove the stock one you'll be shocked at how much less mass you'll have to move. I'm not so sure about MPGs, but it's throttle response is significantly better. I would recommend it, but then again I've only had my 08 for two years, maybe there truly are long term affects that I have yet to see.
TL;DR
Do it!
Tafkars is offline   Reply With Quote
Old 12-18-2012, 09:19 AM   #8053
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
TL;DR
Do it!
If the pulley is the same size as factory I wouldn't worry but, I've herd of people having issues with smaller in size aftermarket replacements.
Digital Dillon is offline   Reply With Quote
Old 12-18-2012, 09:31 AM   #8054
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
Originally Posted by theoutbackdream View Post
For those with the 4EAT, is there anyway to make the auto shift faster in Drive?
I feel like when im driving around, and use "D", instead of sport mode, the gears seem to hold on, and don't want to shift to the next gear. It's quite annoying as this alone usualy makes the car shift at 4-5k...
Is there anyway to make the system shift faster?
The 4EAT is definitely archaic, albeit reliable. "D" is the more 'economical' mode, so it shouldn't hold the gears longer, not sure why yours does.
A tune won't alter the way the TCU behaves directly, which is frustrating, I would love to be able to change the shift points to use more of the rpm range. There was a thread where someone worked with a tuner to and a piggyback system (I think) which was able to tweak things, but the end conclusion was that for a DD it wasn't worth it.
I know that in Romraider you can now log some TCU values, and IIRC you can perform a TCU reset, that might help.
Originally Posted by fancyfootwork15 View Post
I talked with a local tuner about tuning my car and he said it is basically pointless. Our cars (manuals at least) have a very good power curve already.
For an unmodified N/A motor this is generally true, you can probably make a few minimal gains in places but that's it. However, you can drastically improve the factory throttle mapping, a tune could be worth it just for that. Also, even with the stock intake, my MAF sensor benefitted from a rescale.
Originally Posted by 09subi2.5i View Post
But why do people run higher octane fuels? What can that accomplish with our cars? Other than a bigger hole in my pocket lol.
In theory, with higher octane fuel you can run more timing and be less prone to knock (someone correct me if i'm wrong here). Personally, I noticed the car ran smoother with 89 or 91 vs 87, even when it was stock. I wouldn't claim any increase in power, but smoother definitely, the low rpm 'lumpiness' went away.
Originally Posted by ajracerfan View Post
The most worthwhile thing you can do with the car is suspension mods; sping upgrades, sway bars, etc. If you want more actual power, then trade it in for a wrx before you do something detrimental. I know a few have learned that one the hard way.
Or if you want to spend the money on an N/A car, and do the modifications right with a decent tune, you can have a real fun reliable car with gobs of low down torque and no turbo lag
NH8991 is offline   Reply With Quote
Old 12-18-2012, 10:30 AM   #8055
theoutbackdream
Member#: 301179
2013 WRX Limited
Originally Posted by NH8991 View Post
The 4EAT is definitely archaic, albeit reliable. "D" is the more 'economical' mode, so it should hold the gears longer, not sure why yours doesn't.
If it is economical, why would It hold the gears longer till roughly 4500rpm?
Mine does stay in gear longer, not wanting to up shift.... ?????
theoutbackdream is offline   Reply With Quote
Old 12-18-2012, 10:40 AM   #8056
Tafkars
Member#: 305650
2008 Impreza 2.5i-T
Lol that last one is me
Old 12-18-2012, 11:27 AM   #8057
09subi2.5i
Member#: 331636
09 impreza
paprika
What mods do you have?
09subi2.5i is offline   Reply With Quote
Old 12-18-2012, 11:40 AM   #8058
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
It might be your transmission itself or maybe your fluids low. maybe even the filter for it
Navysesal is offline   Reply With Quote
Old 12-18-2012, 12:18 PM   #8059
Aredilla
Member#: 292162
2010 impreza 2.5i
paprika
Which one do you think looks better?
Aredilla is offline   Reply With Quote
Old 12-18-2012, 12:19 PM   #8060
theoutbackdream
Member#: 301179
2013 WRX Limited
I checked... Im right at full.. Fluid is clear though... ?????
Old 12-18-2012, 12:19 PM   #8061
theoutbackdream
Member#: 301179
2013 WRX Limited
1st one.
Old 12-18-2012, 12:38 PM   #8062
Digital Dillon
Member#: 288727
2008 WRX premium
^^ +1
Old 12-18-2012, 12:46 PM   #8063
NH8991
Member#: 197937
2016 Golf R
It was a little early in the AM to be typing, I contradicted myself
No idea why yours is like that, unless you're at WOT everywhere
Old 12-18-2012, 12:50 PM   #8064
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
I've read a few articles saying that staying above 2,500 (correct me if I'm wrong) is more fuel-efficient than staying below or at idle. So maybe that might give you peace of mind lol Although I wouldn't believe it.
Forgot my point but maybe it does that to be more efficient?? Anywho it wasn't like that until after using sport mode.
Old 12-18-2012, 01:43 PM   #8065
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
TL;DR
Do it!
Thanks for the response and most of the aftermarket pulleys state it won't mess with the harmonic balancer or whatever. Two years is plenty of time, especially if you do a mixture of driving (both highway and city driving). Ill do some more researching though.
NH8991- someone bored at work/home? , very well written response though (slow clap).
Navy seal-idk where you bought your sockets but (even though I don't prefer them) harbor freight has a of tools for really cheap prices lol.
KartRacer3 is offline   Reply With Quote
Old 12-18-2012, 02:03 PM   #8066
NH8991
Member#: 197937
2016 Golf R
NH8991- someone bored at work/home? ,...
Yep, bored at home! Off work with bronchitis
Forgot to chime in about LW pulleys, i've had a Group A LW crank pulley on the car for maybe 3.5 years now, no issues (so far).....
Old 12-18-2012, 02:35 PM   #8067
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Sucks to hear man, I had that once. Best of luck on recovering!
I would recommend not being on the forums too long, otherwise you will only be tempting yourself to buy more goodies for your car (ask me how I know)
Old 12-18-2012, 04:22 PM   #8068
Cmac13
Member#: 312011
2009 impreza 2.5i
white
So I found a oem used front bumper in perfect shape for 120 bucks is it worth it just to have? That kind of stuff doesn't usually come up for sale around here
Cmac13 is offline   Reply With Quote
Old 12-18-2012, 04:34 PM   #8069
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Only reason why I haven't bought a lw pulley is because of what others have said bout it causing problems
Steve2.5i is offline   Reply With Quote
Old 12-18-2012, 04:51 PM   #8070
ccalsubi
Member#: 264596
2008 Impreza 2.5i
obp
New pics
ccalsubi is offline   Reply With Quote
Old 12-18-2012, 04:54 PM   #8071
Tentonted
Member#: 303864
2008 Impreza 2.5i 5d
Does a pulley really help that much to have to sweat about it messing up the engine? Afaik you cant even see it.
Tentonted is offline   Reply With Quote
Old 12-18-2012, 05:12 PM   #8072
Digital Dillon
Member#: 288727
2008 WRX premium
White? Ship it to me! I've been looking on eBay for one and their is a few but, they are damaged more than the one I currently have
Old 12-18-2012, 06:54 PM   #8073
Cmac13
Member#: 312011
2009 impreza 2.5i
white
It's blue, my car is white as well but I just thought it seemed like a good deal and a good thing to have down the road, I can't say I've seen one for sale locally before
Old 12-18-2012, 06:55 PM   #8074
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
I mean it's only like $130 for the most expensive one being Cobb (I think). As long as it doesn't weigh too light than it will be fine.
Old 12-18-2012, 07:00 PM   #8075
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
What blue are we talking about here?
fancyfootwork15 is offline   Reply With Quote
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
