#8876 | |
Member#: 331636
Vehicle:09 impreza paprika |
#8877 |
Member#: 301179
BAIC
Vehicle:2009 Outback Sport Sage Green Metallic |
#8878 |
Member#: 306592
Vehicle:2008 Impreza 2.5i Lightning Red |
#8879 |
Member#: 21542
Vehicle:2011 Impreza 2.5i Dark Gray Metallic |
#8880 |
Member#: 293006
SCIC
Vehicle:2010 Impreza 2.5i Newport Blue |
#8881 |
Member#: 293006
SCIC
So before I cave in n have to take my car to the stealership I figured I'd ask you guys first to see if anyone else had this problem. I'm at about 46k mi on the odo and have done all necessary maint'd up to date. When I'm driving in gear in 3-4th, I let off the accelerator and hear from the front of the car a sound that sounds similar to a loose belt (squeaking/squealing). I can't get it to do it 100% of the time and the noise isn't loud. If someone could point me in the direction of where i should check first? or things to check I'd greatly appreciate it. The stealership wants to charge me 125$ just to look at the damn car which is ****ing bs. I asked the san diego nasioc group on FB but 0 reply's.
Thanks in advance, steve |
#8882 |
Member#: 342985
Vehicle:2008 Impreza 2.5I Daily Driver |
Anyone know how to get the trunk unlock/gas door plastic piece removed from the driver carpet area? I unlocked it with my key and the plastic plate is off but won't pop out over the levers.
Any help would be appreciated, last step in removed my carpet! Edit- NVM, got it without taking that piece out. Carpet is officially out of the car, new carpet installed today and picking up seats on Friday. Complete interior transformation. Last edited by DownhillSubie; 01-30-2013 at 02:23 PM. |
#8883 |
Member#: 262503
Vehicle:2008 Impreza 2.5i |
Pull the plastic handles off.
#8884 |
Member#: 309412
International
Vehicle:2010 Impr. 2.0 Sedan WRB |
@sellars21:
The seats and the "plastic" around the shifter are standard. The 2.0R acropolis is, apart from the engine, similar to the WRX. |
#8885 |
Member#: 342985
#8886 |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
+1 on that. The only mods that I have so far as far as suspension/ handling is a rear 19mm swaybar (front 22mm not installed yet), and 17x8 wheels with 225-45 tires. It has made a pretty big difference in the body roll even without the front sway bar installed yet, and the wider tires help with overall grip.
#8887 | |
Member#: 153412
Vehicle:1998 Impreza wrxRS Black |
#8888 |
Member#: 236305
#8889 | |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
#8890 |
Member#: 305008
BAIC
Vehicle:2008 outback sport Newport Blue Pearl |
Lol 225s seem to work for me
![]() Out turned a wrx @outbackdream ;D |
#8891 |
Member#: 262503
#8892 |
Member#: 236305
#8893 | |
Member#: 301179
BAIC
#8894 |
Member#: 293006
SCIC
#8895 |
Member#: 292162
AKIC
Vehicle:2010 impreza 2.5i paprika |
#8896 |
Member#: 292162
AKIC
Yea I just lowered my car last weekend, and I love it, it took a lot of the body roll away; and also if you want to take a lot out, you should also buy a strut bar or sway bars
#8897 |
Member#: 336523
International
Vehicle:2010 Impreza 2.5i Maroon |
Alright, so I have put a lot of mods in my subie and was wondering what you guys think of suspension.
What will be installed later this year. Whiteline 20mm front sway bar STI 19mm rear sway bar kartboy endlinks Bilstein GTWorx sport kit with RCE regular springs Opinions are greatly appreciative. |
#8898 | |
Member#: 268328
BAIC
. I would recommend replacing the entire strut assembly, either coils or inserts both will help. Strut bars don't help the new chassis as much as it did on the GC, GD's (basically pre 08). 235's are the recommended size I'm pretty sure and the stock size of the Wrx tires. However on a 8" wheel I would take the 245's any day lol. |
#8899 |
Member#: 318639
NWIC
Vehicle:2010 Impreza 2.5i Spark Silver |
#8900 |
Member#: 301179
BAIC
| Thread Tools | |
| Display Modes | |
| 08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 7 | 03-24-2012 02:14 PM |
| Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
| 08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
| Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
| 08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
