Old 01-30-2013, 10:23 PM   #8901
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Originally Posted by theoutbackdream View Post
Sorry, Wheel bearing.
sweet thanks imma jack it up this weekend. I isolated the sound to the rear left (driver side).
Steve2.5i is offline   Reply With Quote
Old 01-30-2013, 10:24 PM   #8902
theoutbackdream
Member#: 301179
2013 WRX Limited
Good luck!
theoutbackdream is offline   Reply With Quote
Old 01-30-2013, 10:39 PM   #8903
DownhillSubie
Member#: 342985
You guys know a way to clear airbag code? With Euro cars we have Vag-Com which does more then your standard $100 Analyzer. Does Subaru have a computer diagnostic tool like this?
DownhillSubie is offline   Reply With Quote
Old 01-30-2013, 10:42 PM   #8904
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Default Nj
Just snapped a photo of my Prez midway through a wash to get all the salt off.
Slow Scoobie is offline   Reply With Quote
Old 01-30-2013, 10:44 PM   #8905
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Disconnect your battery. Reinstall the seats.
fancyfootwork15 is offline   Reply With Quote
Old 01-30-2013, 10:56 PM   #8906
DownhillSubie
Member#: 342985
Trying to avoid that since I don't have the radio code for this car.
Did some searching on NASIOC and found someone who said this...
Are all the SRS plugs on the seats re-connected ? Try the trick in this thread..
It should clear the light automatically.
You are referring to the airbag light on the gauge cluster right the red one ?
Make sure Fuse 6 & 11 are in and the fuses are not blown.
Other than that the srs system should see all the plugs connected and clear it on its own...If you have to take it to dealer have them check the codes/clear the codes. If all the codes return right away or you get DTC 25 and 61 than you have an open connection somewhere.
"You are referring to the airbag light on the gauge cluster right the red one ?
Other than that the srs system should see all the plugs connected and clear it on its own...If you have to take it to dealer have them check the codes/clear the codes. If all the codes return right away or you get DTC 25 and 61 than you have an open connection somewhere."
Hopefully it clears when I re-check all the connections when I swap my black seats over the weekend.
Slowscoobie, love the murdered out look and I usually hate that.
Old 01-30-2013, 11:09 PM   #8907
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
What radio code are you referring too? OEM radio just resets and you select all your settings again. Same goes with mine and my girls Pioneer double dins.
Old 01-30-2013, 11:39 PM   #8908
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Well its not really supposed to be murderd out. I will be putting white wheels (taking much longer than anticipated)l on later this year these are just my winter wheels. Also if I ever see you ill be sure to through you a wave.
Old 01-30-2013, 11:44 PM   #8909
DownhillSubie
Member#: 342985
Wait, Subaru's don't have a 4 digit security code that needs to be entered after the battery is disconnected?
Slow.. if you don't plan on slapping a snowboard rack on those bars.. i'd be glad to buy them off you.
Old 01-30-2013, 11:52 PM   #8910
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Trust me... No thief would want to steal our OEM radio.
Fendyman is online now   Reply With Quote
Old 01-30-2013, 11:56 PM   #8911
DownhillSubie
Member#: 342985
Still suprised, considering its a 2008 car. Figured all vehicles have a radio with security code. Wouldn't mind slapping the OEM Radio/Navigation unit out of a newer WRX into my Impreza.
Guess the radio code is alittle more important in my Audi since it's worth about $800, haha.
Old 01-31-2013, 12:00 AM   #8912
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
A new wrx radio is essentially the same exact crap that you currently have. Go aftermarket.
Old 01-31-2013, 12:12 AM   #8913
DownhillSubie
Member#: 342985
Really? I coulda sworn when I looked in the window of a newer 2011/12 WRX sedan it had the same size radio except it was a 6" screen that had built in Navigation.
Old 01-31-2013, 12:42 AM   #8914
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Saddly I use the bars I got a Yakima bike attachment. I just dont feel comfortable leaving it on the rack in my area.
Old 01-31-2013, 06:17 AM   #8915
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
The nav is an option. They go for generally $500+ used on here.
Old 01-31-2013, 08:40 AM   #8916
DownhillSubie
Member#: 342985
Gotchya, thanks for all the information on here dude. Should have pictures by next week to add.
Old 01-31-2013, 09:10 AM   #8917
Aredilla
Member#: 292162
2010 impreza 2.5i
paprika
Does anyone know if you can get side skirts for a 2010 2.5i?
Aredilla is offline   Reply With Quote
Old 01-31-2013, 09:14 AM   #8918
DirknJirkn13
Member#: 249696
2010 Outback Sport
What suspension do you have?
DirknJirkn13 is offline   Reply With Quote
Old 01-31-2013, 09:28 AM   #8919
Aredilla
Member#: 292162
2010 impreza 2.5i
paprika
So low. After lowering mine, I want to go more low haha
Old 01-31-2013, 10:10 AM   #8920
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
08-10 WRX side skirts
Digital Dillon is offline   Reply With Quote
Old 01-31-2013, 11:42 AM   #8921
DownhillSubie
Member#: 342985
Disconnected battery, still has an airbag light. Damnit.
Old 01-31-2013, 12:51 PM   #8922
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
I might have missed it somewhere, but did you get your car up and running after the pump issue, or was it something else?
Sellars21 is offline   Reply With Quote
Old 01-31-2013, 01:06 PM   #8923
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
You need to disconnect your battery and unplug both front seats. Plug them back in and then the battery last.
Old 01-31-2013, 01:06 PM   #8924
Aredilla
Member#: 292162
2010 impreza 2.5i
paprika
Aight thanks man!
Old 01-31-2013, 01:18 PM   #8925
DownhillSubie
Member#: 342985
Checked my ECM and that is fine, relay is fine, pump is fine. It must be a ground somewhere but knowone has a diagram showing what ground relays are for the ignition/ECM. I currently have my car running by installing a kill switch for my fuel pump so i'm manually turning my pump on/off before I start the car. Problem isn't fix 100% but my car is drive-able and now my car can't be stolen.
I will try that before trying a 3 ohm resistor.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
