Old 01-31-2013, 01:23 PM   #8926
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Originally Posted by DownhillSubie
Checked my ECM and that is fine, relay is fine, pump is fine. It must be a ground somewhere but knowone has a diagram showing what ground relays are for the ignition/ECM. I currently have my car running by installing a kill switch for my fuel pump so i'm manually turning my pump on/off before I start the car. Problem isn't fix 100% but my car is drive-able and now my car can't be stolen.
I will try that before trying a 3 ohm resistor.
You should do a little write up on the fuel pump kill switch. Sounds like something I would like go have.
Sellars21 is offline   Reply With Quote
Old 01-31-2013, 01:27 PM   #8927
DownhillSubie
Member#: 342985
Ha, have alot of things I could do a write-up on for this 2.5i MY08-10 platform vehicle already. Once i'm settled in and not running around doing all these things, just might.
DownhillSubie is offline   Reply With Quote
Old 01-31-2013, 01:30 PM   #8928
Sellars21
Member#: 304055
I think I just like the idea of more switches, to have your own start up procedure, because racecar
Old 01-31-2013, 01:37 PM   #8929
DownhillSubie
Member#: 342985
Screw racecar, my inspiration is cockpit of a Falcon50.
Old 01-31-2013, 01:39 PM   #8930
Aredilla
Member#: 292162
2010 impreza 2.5i
paprika
Because jetplane.
Aredilla is offline   Reply With Quote
Old 01-31-2013, 01:42 PM   #8931
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Originally Posted by DirknJirkn13 View Post
What suspension do you have?
Fortune Auto 500 coilovers.
Slow Scoobie is offline   Reply With Quote
Old 01-31-2013, 01:47 PM   #8932
DownhillSubie
Member#: 342985
Originally Posted by fancyfootwork15 View Post
You need to disconnect your battery and unplug both front seats. Plug them back in and then the battery last.
Have you done this before yourself Fancy, did it work 100%?
Old 01-31-2013, 02:14 PM   #8933
Rhefqab
Member#: 259892
2010 Impreza 2.5i
SSM
Default Front lip paint
Originally Posted by KartRacer3 View Post
I rattle-caned mine lol. Plus you feel better knowing that you made it that way
I am waiting for the weather to get a little better before I spray mine. Did you use any primer & clear coat or anything? Also, did you use factory paint or just a similar color?
Rhefqab is offline   Reply With Quote
Old 01-31-2013, 02:42 PM   #8934
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
I used Rustoleums "Metallic paint and primer primer in one". I used their Titanium Silver color. Before anything I wet sanded the entire thing since the quality wasn't perfect. It has some flakes in it which surprisingly matches very well to SSM. All I can say is take your time and do at least 3-4 coats. I rushed and ended up having to wet sand the new layer of paint
I noticed you have SSM too. You can pick up the same can at a local Home Depot or order it online lol.
KartRacer3 is offline   Reply With Quote
Old 01-31-2013, 03:23 PM   #8935
Sellars21
Member#: 304055
That reminds me, anyone do a oil pressure/ temp gauge. I'm thinking it would look good in the smy dual gauge hood
http://www.rallysportdirect.com/SMY-...Gauge-Pod-52mm
Old 01-31-2013, 04:08 PM   #8936
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Yes. I had the exact same problem you are having. I was in a rush to get it all back in and plugged in the battery before the driver seat.
fancyfootwork15 is offline   Reply With Quote
Old 01-31-2013, 04:18 PM   #8937
DownhillSubie
Member#: 342985
Well thank you, definately good to know. When I double checked... found out a connection wasn't plugged under the passenger seat.
Old 02-01-2013, 07:26 AM   #8938
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Originally Posted by Slow Scoobie View Post
Just snapped a photo of my Prez midway through a wash to get all the salt off.
You maxed out on your Fortune500's? Im already maxed on my Extreme Lows and the rear sits too high for my liking. Thought it could go lower but i guess its for the WRX kits that were taken into consideration. How high are you from ground to the top of the fender? Need to take some measurements tomorrow cuz its a little late.
BSP671 is offline   Reply With Quote
Old 02-01-2013, 12:32 PM   #8939
DownhillSubie
Member#: 342985
Any of you guys run Magnaflow Catback on your 2.5i's or know anyone who does?
Specifically this sytem... http://www.magnaflow.com/02product/s...ne=all&id=9771
It states that it mates up directly to the 08 Impreza WRX Sedan OEM cat, do any of you guys know if the OEM Cat on the WRX Sedan is the same as the OEM cat on a 2.5I sedan?
Only reason I ask is because the Tsudo Performance Catback a few of you run is stated to be ONLY for the WRX sedan model but you guys run it on your 2.5I sedans.
http://www.speed-element.com/servlet...muffler/Detail
Thanks guys!
Old 02-01-2013, 01:21 PM   #8940
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Thanks guys!
I recommend you start from the beginning of this thread and read everything. Almost all of your questions have been covered numerous times.
But to answer your question, yes. Any 08-10 wrx exhaust will fit your car.
Old 02-01-2013, 01:28 PM   #8941
DownhillSubie
Member#: 342985
Apologize to all you guys who know this car inside / out. I've been trying to get through all 358 pages, slowly.
Old 02-01-2013, 02:00 PM   #8942
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
I did mines, i used a prosport premium. What would you like to know my child? jkjk, ask away
Navysesal is offline   Reply With Quote
Old 02-01-2013, 03:19 PM   #8943
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
I've got water temp and oil pres.
The install was... fun.
JourdanWithaU is offline   Reply With Quote
Old 02-01-2013, 04:35 PM   #8944
Sellars21
Member#: 304055
What sender did you guys use? I hope not a sandwich type, herd bad things. And where did put it. I know of two location on the block other than the filter. I take it you both used a digital feed?
And the interior portion of the install looks like bitch from that pic.
I had a whole package picked out, but everything has to wait. I don't mod in the winter. Too cold.
Jordan what's the make on those gauges, are they passport as well, they match perfectly.
Old 02-01-2013, 04:42 PM   #8945
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
The rears aren't maxed out and have an inch of thread left and the fronts have about 5 threads left before max. Front 23.5inchs Rear 23.5inchs
Old 02-01-2013, 05:03 PM   #8946
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
I used the stock sender. The premium prosport give you a smaller sender that fits in the gallery plug area. I used the gallery plug, and Jourdan used a sandwich plate.
Yep mines electronic, there's nothing wrong with a sandwich plate, but if your gonna be running pressures and temp, might as well use the plate. You just need too make sure the plate is sealed correctly.
I actually didn't do what Jourdan did for the install of the power supply for the gauges; just hooked them up to the fuse box. And the prosport has a daisy chain so i can just hook up the power from my oil pressure gauge
Old 02-01-2013, 05:32 PM   #8947
Sellars21
Member#: 304055
I figured pressure and temp because most electronic galley senders have two hookups anyway.
I didn't know about being able to use the stock sender. I though it was just a yes/no sender because we do not have a stock gauge?
Old 02-01-2013, 06:06 PM   #8948
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
I meant the sender prosport gives you lol, sorry
Old 02-01-2013, 07:52 PM   #8949
Sellars21
Member#: 304055
And did you use the galley at the front of the block of the alternator or the towards the back on the passenger side?
Old 02-01-2013, 07:54 PM   #8950
Sellars21
Member#: 304055
Jordan, how do you do a coolant temp? I already used one plug for my block heater, hope there's more than one.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
