Old 02-02-2013, 12:11 AM   #8951
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Originally Posted by Sellars21 View Post
And did you use the galley at the front of the block of the alternator or the towards the back on the passenger side?
The front one; it's easier to access. But you need an extension for the socket wrench and i believe a deep well socket to tighten the plug
Navysesal is offline   Reply With Quote
Old 02-02-2013, 12:26 AM   #8952
TravisM
Member#: 295506
2011 Impreza 2.5i Pr
Dark Gray Metallic
So I just went out to play in the fresh snow and some douche in a pt cruiser told a cop I was doing so. After 20 minutes the cop says I didn't see you otherwise you'd be getting some tickets.
TravisM is offline   Reply With Quote
Old 02-02-2013, 12:41 AM   #8953
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
What sender did you guys use? I hope not a sandwich type, herd bad things. And where did put it. I know of two location on the block other than the filter. I take it you both used a digital feed?
And the interior portion of the install looks like bitch from that pic.
I had a whole package picked out, but everything has to wait. I don't mod in the winter. Too cold.
Jordan what's the make on those gauges, are they passport as well, they match perfectly.
Jordan, how do you do a coolant temp? I already used one plug for my block heater, hope there's more than one.
I have my oil pressure sender on a sandwich plate. Seemed easier than going to a galley plug and I haven't had any problems.
For the water temp I got a hose adapter and put it in the upper radiator hose.
My gauges are Depo 7 color gauges. I got them because they looked like they would match the best and they match extremely well. I also ran the power from the stereo harness and the sender wires from the hole on the passenger side. Taking apart the dash really wan't that bad. Everything snaps apart and together really easily.
JourdanWithaU is online now   Reply With Quote
Old 02-02-2013, 12:42 AM   #8954
trishHUYNH
Member#: 248840
2011 Impreza
Satin White Pearl
For those with a rear sway bar, does the bend goes towards the car or towards the ground?
I took my car to get an oil change and told them about my rear squeaking and they pointed out that my RSB was upside down and the bend was pointing towards the ground.
Edit: I took a picture. Not a very good picture, but I'm just curious as to if it can be even installed upside down. I always thought it was a one way only kind of thing.
trishHUYNH is offline   Reply With Quote
Old 02-02-2013, 12:53 AM   #8955
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Front what I remember it points up to clear the exhaust. Dont quote me on that since im not 100%.
Slow Scoobie is offline   Reply With Quote
Old 02-02-2013, 04:31 AM   #8956
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Originally Posted by Slow Scoobie View Post
The rears aren't maxed out and have an inch of thread left and the fronts have about 5 threads left before max. Front 23.5inchs Rear 23.5inchs
Yeah my rears have about a lil over an inch left but can't thread down into the housing anymore. Don't really want to mess with the preload to go lower. Currently with the steelies I'm at 22.5" in the front and 23" in the rear but I haven't moved the car for a few months so the camber hasn't settled. What wheels were you looking to get?
BSP671 is offline   Reply With Quote
Old 02-02-2013, 10:18 AM   #8957
Cmac13
Member#: 312011
2009 impreza 2.5i
white
I've been in that situation before, people are stupid
Cmac13 is offline   Reply With Quote
Old 02-02-2013, 10:28 AM   #8958
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
+1. It you ever decide to do any hooning, it's best to do a quick run and get outta their
KartRacer3 is offline   Reply With Quote
Old 02-02-2013, 01:24 PM   #8959
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Or be well within the middle of no where.
OR at a sanctioned event. Of course.
Old 02-02-2013, 01:30 PM   #8960
theoutbackdream
Member#: 301179
2013 WRX Limited
Edit: I took a picture. Not a very good picture, but I'm just curious as to if it can be even installed upside down. I always thought it was a one way only kind of thing.=
IIRC, the bend is away from the ground.. So your RSB is upside down. lol
theoutbackdream is offline   Reply With Quote
Old 02-02-2013, 01:46 PM   #8961
trishHUYNH
Member#: 248840
2011 Impreza
Satin White Pearl
Just called the shop that installed it a year ago. It's going to be fixed Wednesday.
I'm never going to cheat on my mechanic again.
Old 02-02-2013, 04:55 PM   #8962
TravisM
Member#: 295506
Dark Gray Metallic
I thought I'd be safe in a huge unplowed parking lot set bak from the road past 11:00 pm. Oh well at least I didn't get ticketed.
Old 02-02-2013, 06:26 PM   #8963
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
I wish i could get to 22.5" in the front but i know for a fact the last 5 threads or so wont change the height a noticeable amount. Ive thought about taking one of the locking collars out but i don't have the balls... I currently have Rota G-Forces in the garage but Im gonna sell them and get some cheap wheels i can rock all year round like xxr's() Although id really love some work emotion cr-kai's...
Also i dont get how some people can get their subies so low on coilovers.
Like this STi
Doesnt the wheel touch the top of the fender? All i know is i would like to get lower but on some bumps my tires all ready hit the top of the fender.
Old 02-02-2013, 06:53 PM   #8964
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Drive very carefully.
There is some space in there.
I've gotten my car this low and it didn't rub.
But I don't think there's much space beyond that. The next step is to limit travel by either being on the bump stops (bad) or having springs so stiff that they never compress (also bad).
Old 02-02-2013, 07:00 PM   #8965
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Like this STi
Remove the fender-liner and their is tons of room
Digital Dillon is offline   Reply With Quote
Old 02-02-2013, 07:27 PM   #8966
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
I took em out a while ago.
Old 02-02-2013, 10:03 PM   #8967
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
I can't get away with that. Canadian salt covered roads eat metal. I have to get my car rust proofed twice a year. It drips oil 8 months of the year.
Sellars21 is offline   Reply With Quote
Old 02-02-2013, 10:14 PM   #8968
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Honestly, I think its the side skirts and front lip/beefier bumper that give it the added "illusion" that its lower. Yeah there isn't that much room there but there is ways to work around it. You can tub out the wells but not sure if you would like to go that route. Did you relocate your harness when you took out the liner? If not, I suggest you do that if your gna run low.
Just test fitted earlier this week and dang its gna be a tight fit lol. Just need tires but due to my financial situation and some parts that need replacement first, that wont be up until March or April.
Rears are cutting close to the wells and might need control arms or spacers to go lower and the fronts are really close to the coilover body, not that big of a deal.
Old 02-02-2013, 11:04 PM   #8969
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
They salt the roads here too I just clean my car often...very often. Also I wash the undercarriage with a power washer. Its rusted regardless damn you previous owner.
Old 02-02-2013, 11:29 PM   #8970
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Yea I knew the side skirts and lip make it appear lower just wish my car would appear that low. About that harness thing no I didnt because I wasnt aware about that until now whats it connected too.
Old 02-02-2013, 11:32 PM   #8971
Sellars21
Member#: 304055
Fortunately for me, previous owner had sound insulated and under coated the car before I got to it. Makes working on the car a pain in the ass though. I can't touch a thing without making a mess
Old 02-03-2013, 01:02 AM   #8972
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Well i rather be in your position knowing it was taken care of. Working on a car were everything is seized isn't fun either.
Old 02-03-2013, 06:10 AM   #8973
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Yeah, most likely you took out the liner because you were rubbing and it ate through? Its usually on the driver side and it basically holds all the critical wires for your car to run. I haven't relocated mine yet but it should be the same with most cars. You can just move it higher and zip-tie it into place.
Old 02-03-2013, 06:47 AM   #8974
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Are the wires critical?
I know one of the things in there is the hose for the rear washer fluid. I may or may not have rubbed through that hose.
Old 02-03-2013, 10:33 AM   #8975
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
I've seen on one of the threads here that their car wouldn't start cuz it rubbed through a starter relay or something like that. On my friends SC200 it rubbed through ,I guess it was an ECU feed , and fried the module. I just do it to be safe and not spend extra $$$ on stuff that could have been avoided.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
