Old 02-15-2013, 10:49 AM   #9176
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Originally Posted by lazyimpreza
kartracer: thanks for the reply, saved me some money on spending on bushings.
hmm master cylinder brace, gotta research about that
jourdanwithaU: are ou on coilovers?? looks pretty damn low
also to the guy who put in WRX exhaust...is it just for sound or was there a performance increase? why not put an aftermarket piece there instead?
Most aftermarket exhausts are 3" straight through and with a naturally aspirated car that size exhaust will move your torque curve higher in the RPM range which is far from ideal for a car that most likely spends it's time under 3500 RPM's. My butt dyno didn't notice any power gains but the throttle responce was slightly improved.
Digital Dillon is offline   Reply With Quote
Old 02-15-2013, 10:53 AM   #9177
s1eepR
Member#: 335330
2008 Impreza 5DR
I'm not sure if you're talking to me, but I put 2012 WRX exhaust on my 2.5i for appearance and sound.
s1eepR is offline   Reply With Quote
Old 02-15-2013, 11:44 AM   #9178
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Not anymore. I switched to Koni inserts and stock springs. The picture is deceptive since it was taken mid corner so there's a lot of body roll making it look lower than it is.
Here's a slightly better shot showing the actual height.
It probably sits a little lower than stock just because the Konis are hydraulic while the stock shocks were gas filled.
JourdanWithaU is offline   Reply With Quote
Old 02-15-2013, 12:08 PM   #9179
lazyimpreza
Member#: 319024
thanks for the reply guys, im still learning as i go.
lazyimpreza is offline   Reply With Quote
Old 02-15-2013, 12:42 PM   #9180
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Can you get those whiteline RSB mounting braces separately? Are they just listed as a WRX part?
BWX is offline   Reply With Quote
Old 02-15-2013, 12:57 PM   #9181
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Any reason for the switch?
Sellars21 is offline   Reply With Quote
Old 02-15-2013, 12:57 PM   #9182
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Yep, KBR15.
http://www.whiteline.com.au/product_...t_number=KBR15
MSRP, $79.90.
I've seen them in silver and gold. IDK if you can pick the color though.
I had BC BR Coils which weren't very good.
What I really want (and what I should have gotten instead of the BC's) is a Koni/Ground Control set-up. Konis and stock springs for now is just a simple transition since I couldn't afford the Ground Control stuff before the season started. My car will stay relatively unchanged until the last event in August or so. Maybe I'll stay in Stock class for the Slush series too though. Depends on how much rubber is left on these pizza cutters.
But I can say that my current set-up is extremely close, performance wise, to my old set-up.
The stuff that changed;
BC BR coilovers -> Koni shocks w/ stock springs
18x8 Rota P45 -> 16x6.5 OEM Premium Alloy
235/40/18 Toyo T1R -> 205/55/16 Dunlop Direzza ZII
The tires are mind boggling. The ZII's are about 2 inches narrower and provide about the same level of grip.
The next event where I'm scheduled to run in the morning, I'm going to bring the Rota/Toyo set and do a second run on those to see what kind of times I can put down.
Old 02-15-2013, 02:18 PM   #9183
Sellars21
Member#: 304055
Yep, KBR15.
MSRP, $79.90.
What specifically was it about the bc's that weren't very good?
Old 02-15-2013, 03:29 PM   #9184
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
The dampening was no good and the springs were too stiff. If the surface was completely smooth they were fine. But any kind of bump and they just completely **** the bed. The car car would also tripod a lot.
Old 02-15-2013, 05:39 PM   #9185
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
These are just as good, slightly cheaper as well.
http://www.rallysportdirect.com/GTSp...-STI-2008-2011
KartRacer3 is offline   Reply With Quote
Old 02-15-2013, 10:57 PM   #9186
Sellars21
Member#: 304055
Was there no was to make the setup any softer? Also never thought our cars could tripod with it being heavier with a longer wheel base than most civics and other compacts. Could you feel the "tripod" effect, or were you told by others? I'm guessing this only happened on autox.
Old 02-15-2013, 11:29 PM   #9187
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
I think it was inherent to the design. They're short stroke coilovers and they utilize a stiff preloaded spring. Because of this they didn't offer a lot of droop and the car wasn't heavy enough to compress the springs enough to make it all work.
Here's a shot from the install. Koni on the rear and BC on the front. Notice how much further the rear wheel droops compared to the front.
And it wasn't so much that the car would tripod on course. I don't think a tires ever left the ground. But I could feel the loss of traction and ultimate loss of power and the open diffs just let all the power go to the spinning wheel.
The most actual lifting occurred on the street. There was almost no driveway that I could pull into and not lift a rear wheel. If I stopped while the wheel was off the ground, it would spin for a bit before TCS would kick in and get the car moving again.
Old 02-16-2013, 11:47 AM   #9188
09subi2.5i
Member#: 331636
09 impreza
paprika
Hey guys so I've been callin around shops to see if I could delete my second cat. Everytime I go somewhere I either get quoted ridiculously high for them to replace that whole section of pipe, or call a Midas for them to tell me they won't do it anymore because its illegal. Please help me I know there are some of you with these
09subi2.5i is offline   Reply With Quote
Old 02-16-2013, 12:33 PM   #9189
Digital Dillon
Member#: 288727
2008 WRX premium
Should cost like $50 at a hole in the wall shop but yes, it is illegal to remove emission equipment.
Old 02-16-2013, 12:45 PM   #9190
s1eepR
Member#: 335330
2008 Impreza 5DR
What about the axleback resonator? I'd like to delete that for a slightly louder exhaust but I don't want it sounding like a fartcan. Anyone care to chime in on cost/ effectiveness?
Background: 2012 WRX Exhaust on my 2.5i
Old 02-16-2013, 12:53 PM   #9191
09subi2.5i
Member#: 331636
09 impreza
paprika
I keep getting told that that whole section needs to be removed and replaced
Old 02-16-2013, 02:30 PM   #9192
theoutbackdream
Member#: 301179
2013 WRX Limited
just do a straight pipe from axelback like navysesal did. sounds really nice imo.
theoutbackdream is online now   Reply With Quote
Old 02-16-2013, 02:32 PM   #9193
theoutbackdream
Member#: 301179
2013 WRX Limited
iirc, the second cat is the connection between the header and mid pipe, so deleting it Will in fact need to replace that section of piping.
Old 02-16-2013, 03:45 PM   #9194
09subi2.5i
Member#: 331636
09 impreza
paprika
That sounds too loud for my liking. No mufflers?
Old 02-16-2013, 05:15 PM   #9195
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
If anyone is interested I will be selling my front lip very soon. Switching it up
Bayson R (from an STI)
Its already cut to fit out bumpers and plasti-dipped for a matte finish
I would prefer someone close to me as shipping this thing would be difficult.
PM me if interested
daigledangle8 is offline   Reply With Quote
Old 02-16-2013, 06:45 PM   #9196
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Essentially swapping out the big muffler for a straight pipe. It's not that loud at all.
Remember you still have the cat and resonator up front.
You get the crackle and pop too
Navysesal is offline   Reply With Quote
Old 02-16-2013, 06:48 PM   #9197
09subi2.5i
Member#: 331636
09 impreza
paprika
You mean a muffler delete? Or taking out that last muffler before the y pipe?
Old 02-16-2013, 07:12 PM   #9198
theoutbackdream
Member#: 301179
2013 WRX Limited
its not much louder than a quad tip sti exhaust....
also Im talking about a 2.5" pipe.. not any bigger.
Old 02-16-2013, 08:10 PM   #9199
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Originally Posted by JourdanWithaU View Post
Yep, KBR15.
MSRP, $79.90.
Sweet! I'll definitely be picking up one of these in the spring.. whichever is in stock/cheaper.. probably..
Old 02-17-2013, 12:46 AM   #9200
Sellars21
Member#: 304055
PM me if interested
Xxr 527's? With at sti wing. Wicked look, props.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 03:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 12:57 PM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 10:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 03:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 03:35 PM
