Old 03-01-2013, 09:58 AM   #9601
09subi2.5i
Member#: 331636
09 impreza
paprika
Originally Posted by daigledangle8 View Post
My next project.
Catback?
09subi2.5i is offline   Reply With Quote
Old 03-01-2013, 11:17 AM   #9602
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Originally Posted by Sellars21 View Post
The rotella t6 in area is 5-40 and only found in the specialty/diesel section. Is this the same as what everyone uses? What's the diff between 5-40 and 5-30. What's more recommended for winter summer?
http://www.upmpg.com/tech_articles/motoroil_viscosity/
T6 is designed for Diesel engines, but it works extremely well in our gas engines.
JourdanWithaU is offline   Reply With Quote
Old 03-01-2013, 12:29 PM   #9603
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
Originally Posted by 09subi2.5i View Post
Catback?
I bought the catback from my friend for cheap.
I'm only going to be using the Y pipe/ axelback and I will be cutting off the resonator and welding it onto my current setup. Only reason why I'm not going to just bolt it up is because its 3 inches. I want to keep the 2.25 setup i have now.
Should change the sound a lot and make it deeper.
daigledangle8 is offline   Reply With Quote
Old 03-01-2013, 02:54 PM   #9604
09subi2.5i
Member#: 331636
09 impreza
paprika
Sounds cool me me know how It goes
Old 03-02-2013, 12:34 PM   #9605
isleep2.5
Member#: 346087
2008 impreza 2.5i
gray
Question help plz :)
hey was wondering if you found any mods worth the time or effort yet looking to upgrade mine and im kinda stuck on whare to start any help is apreciated, and BTW going for performance not look. and yes i know if i want power like a wrx i should get a wrx but pockets arn't that deep and this is what i have so i would like to work with this so thank you for any help you can give me greatly appreciated
isleep2.5 is offline   Reply With Quote
Old 03-02-2013, 12:51 PM   #9606
theoutbackdream
Member#: 301179
2013 WRX Limited
I am selling wrx sway bars well worth the money!
http://forums.nasioc.com/forums/show....php?t=2473124
theoutbackdream is offline   Reply With Quote
Old 03-02-2013, 01:04 PM   #9607
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Rear Sway Bar
Top of the list.
Also, don't underestimate the usefulness of a good set of tires.
Old 03-02-2013, 01:18 PM   #9608
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
This has been asked 9999x but ill humor u since u asked in the amazing 08 2.5i thread. 1 if u don't have deep pockets for a wrx then u most likely wont be able to afford Modding ur 2.5i due to it being expensive/lots of cash for very little gain. 2 money would be better spent suspension wise/ driveability ( summer tires, sways, springs, inserts, better brake pads, ect).
Tech works engineering makes EL headers, Delta has cams/springs/retainers ull want 1000-1500 grind, look at hybrid sticky for ur intake, hfc/2.25 catback, contact STiMikey for a open source tune (via tactrix cable/rom raider, n I'm sure that would put a smile on ur face.
Disclaimer : I'm pretty sure u can get away with cheaper EL headers ie: obx, Cobb, CNT. This is what my setup would be given the budget.
Throw a rear sway bar/endlinks on if u haven't yet.
K I think that's enough info from me now go do ur research n read then read some more.
Steve2.5i is offline   Reply With Quote
Old 03-02-2013, 01:20 PM   #9609
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Originally Posted by JourdanWithaU View Post
Rear Sway Bar
Top of the list.
From now on that will always be my first upgrade (tires) . Lesson learned.
Old 03-02-2013, 01:43 PM   #9610
DirknJirkn13
Member#: 249696
2010 Outback Sport
Anyone looking into the Shell Rotella T6 oil, here's a good deal: http://slickdeals.net/permadeal/9050...etic-motor-oil
DirknJirkn13 is offline   Reply With Quote
Old 03-02-2013, 05:05 PM   #9611
09subi2.5i
Member#: 331636
09 impreza
paprika
Some how got a test pipe welded in today for $60! Tuning ASAP now.
Old 03-02-2013, 06:39 PM   #9612
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Cheapest coils out there?
Sellars21 is offline   Reply With Quote
Old 03-02-2013, 06:43 PM   #9613
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Racelands. Coils are pointless unless you are spending big money. Struts and springs make way more sense.
fancyfootwork15 is offline   Reply With Quote
Old 03-02-2013, 07:41 PM   #9614
Sellars21
Member#: 304055
Ok, I'm a month or so away from having to replace my struts. I just need anything that's height adjustable. Most days I don't have anything in the hatch, but when I do I hate seeing sag.
I'm looking for adjustable height and stiff so i don't have to dial in every time i have stuff in the car. If I had the cash I'd put it on bags with an e-level system.
Old 03-02-2013, 07:46 PM   #9615
Sellars21
Member#: 304055
Is it unanimous that racelands are crap. Or does anyone like them?
Old 03-02-2013, 08:00 PM   #9616
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Cheap coils are fail.
Get some after market struts.
If you really want height adjustability, get the Ground Control kit.
Old 03-02-2013, 08:01 PM   #9617
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Do it once n do it right or not at all. You get what u pay for.
Old 03-02-2013, 08:02 PM   #9618
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
This. Or Konis and stiffer springs.
Old 03-02-2013, 08:07 PM   #9619
Sellars21
Member#: 304055
Are bc'a still in the fail zone?
Old 03-02-2013, 08:17 PM   #9620
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Depends. If you want coils just to say you have coils then that's a fail in itself. You are looking at $1,500+ for good coils. Then add your brutal salt filled winters in Canada and plan on replacing them in a few years.
OR, get quality struts and springs for the same look and ride quality...
Old 03-02-2013, 08:40 PM   #9621
Sellars21
Member#: 304055
After a few years of camping gear and dogs any strut spring combo will sag. Salt and winter will mess up any system. Just looking for height adjustable, to fix any sag brought on by transporting people and heavy objects.
Spending 1500 on a nice setup just to have it replaced due to salt and winter damage doesn't sound like fun. Different story if I lived in Florida.
Old 03-02-2013, 08:47 PM   #9622
imp2.5wag
Member#: 290211
2009 impreza 2.5i
SSM
How much would i be looking at spending on A descent Strut/spring combo? I'm looking to order either tomorrow or Monday. And what springs and what struts are you guys running and happy with. Thanks
imp2.5wag is offline   Reply With Quote
Old 03-02-2013, 08:54 PM   #9623
imp2.5wag
Member#: 290211
2009 impreza 2.5i
SSM
And I do want to have a noticeable drop stock height sucks!
Old 03-02-2013, 09:05 PM   #9624
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Konis for anywhere between $6-800 depending where you get them. Then springs are $200 give or take.
Old 03-02-2013, 09:45 PM   #9625
imp2.5wag
Member#: 290211
2009 impreza 2.5i
SSM
Thanks do you have a recommended vendor?
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
