Old 04-04-2013, 05:54 AM   #10001
.HaVoK.
Member#: 229726
'09 2.Slow
Originally Posted by fancyfootwork15 View Post
Listen to a CD or the radio and see if it happens.
I have a stock HU if you wanna buy mine.
Do you think its the HU or a fuse issue? If its the HU going, I'll probably end up upgrading to a better one. Thanks for the offer though.
.HaVoK. is offline   Reply With Quote
Old 04-04-2013, 06:14 AM   #10002
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
If it was a fuse, the radio would shut off, not just the speakers. I wonder if it would do it with just the radio on or a different source selected, like a CD or something. Maybe it has something to do with your ipod cord or something.. Maybe it is shorting out.
You have to test it with a different source like everyone is saying. if it does it with a different source (unplug the cord, don't just switch to a different source and leave plug in)... if it still does it, then it cannot be blamed on the ipod cord.
BWX is offline   Reply With Quote
Old 04-04-2013, 10:14 AM   #10003
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
Anyone in here using an after market oil cooler? If so how do you have it set up, which brand, and any pictures?
Silver08Waggs is offline   Reply With Quote
Old 04-04-2013, 01:25 PM   #10004
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
I'm starting to hear a thump in the driver side trunk area now. I only hear it when i go over bumps or potholes; pretty much anything that makes the car go up and down lol
I'm running coils, so i check that and everything is fine. I was thinking it may be because the control arm is hitting my exhaust. Since i did lower it again, but by only a 1/4 inch
Any suggestions?
Navysesal is offline   Reply With Quote
Old 04-04-2013, 05:31 PM   #10005
.HaVoK.
Member#: 229726
'09 2.Slow
Hmm...Will do so. Also, the ipod is connected to the cigarette lighter in front of the shift knob and is transmitted through FM. I'll try just the radio or CD.
Old 04-04-2013, 05:53 PM   #10006
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Any suggestions?
Could just be the suspension "clunking" around. I'm starting to hear a similar noise on the passenger side trunk area . Could be swaybars, endlinks, new bushings, brake lines, tophats. Basically anything that can move or be hit/moved by other various components.
KartRacer3 is offline   Reply With Quote
Old 04-04-2013, 10:10 PM   #10007
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Oh well I thought it might be connected with a cord. If you are transmitting to an FM station, then essentially, you are just listening to the radio as far as the head unit knows. So... yeah, not sure what the hell is going on there.
It sounds like maybe your head unit is crapping out internally. I suppose if it was losing power for a millisecond, then the power is back on, maybe it could cause such a symptom, but I doubt it. You could pull the head unit, check the connections, check the grounds really good, etc.
I have an extra one too, LOL.. but I think I may keep it to put back in the car if I ever sell the car and want to kepe my Pioneer head unit.
Old 04-04-2013, 10:10 PM   #10008
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Any suggestions?
Whats your dampening at?
BSP671 is offline   Reply With Quote
Old 04-05-2013, 01:17 AM   #10009
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
The rear was at 2 clocks from hardest, but now is 5 from hardest
Old 04-05-2013, 01:24 AM   #10010
theoutbackdream
Member#: 301179
2013 WRX Limited
Any suggestions?
Sway bar loose?
theoutbackdream is offline   Reply With Quote
Old 04-05-2013, 02:38 AM   #10011
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Just get under there and try to replicate the sound is all I can say...bounce it up and down if you have to...maybe you so low its hitting teh bump stops lol
Old 04-05-2013, 06:48 AM   #10012
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
That's exactly what i was thinking lol, that or I'm hitting my fender liner. But my shocks have little to no travel. I'm pretty sure something is loose and its smacking my undercarriage.
It might possibly be my sway bar; fingers crossed Lol
Old 04-05-2013, 08:28 AM   #10013
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
I would think if its a something loose it would make a thump followed with a slight rattle. But if its just one solid thump then maybe the wheels hitting something when the suspension travels. Or it could be the bodies in the hatch just rolling around? Haha
Old 04-05-2013, 02:47 PM   #10014
Demon5689
Member#: 351698
2008 Impreza 2.5I
Spark Silver
hey i just changed the radio in my impreza a couple of days ago
i put a kenwood bt65u single din and it works great
my friend showed me i didnt even need to take out the dash panel the vent piece around the radio poped out in like 30 seconds and the radio was changed quick
Demon5689 is offline   Reply With Quote
Old 04-05-2013, 03:00 PM   #10015
DirknJirkn13
Member#: 249696
2010 Outback Sport
You took out the dash? Like the entire top piece? Haha
DirknJirkn13 is offline   Reply With Quote
Old 04-05-2013, 09:23 PM   #10016
Imprezzedwitsubies
Member#: 216116
2015 BRZ Limited
14' Triumph America
'Splain
Imprezzedwitsubies is offline   Reply With Quote
Old 04-05-2013, 09:34 PM   #10017
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Why on earth would anyone take off more then just the bezel?...
fancyfootwork15 is offline   Reply With Quote
Old 04-05-2013, 09:43 PM   #10018
premier00000
Member#: 251060
2008 Impreza Outback
I had to, it had clips holding it to the lower piece on the bottom... (and it made running everything for my Sirius and Bluetooth receivers easier)
premier00000 is offline   Reply With Quote
Old 04-05-2013, 10:35 PM   #10019
Demon5689
Member#: 351698
2008 Impreza 2.5I
Spark Silver
Yes from what I see on the forums you have to unscrew one screw and the silver trim pops out and from there you pop out the vent bezel
My friend showed me a way for me not to unscrew anything but the radio
And no trim comes out except the one around the radio
Old 04-05-2013, 10:44 PM   #10020
08PrezaDave
Member#: 243064
2008 Impreza 2.5i
Newport blue
Default Update with wheels
I know there will be haters......but oh well.
08 2.5i in satin black. Still have to finish fender work, wetsand, and shoot another coat.
Eibachs with no camber adjustment
XXR 527 18x8.75 20 offset in chromium black
215/40ZR18
rolled and pulled rears "alot"
rolled and pulled fronts (I need to drop the front another inch or so to level it out)
08PrezaDave is offline   Reply With Quote
Old 04-05-2013, 10:45 PM   #10021
08PrezaDave
Member#: 243064
2008 Impreza 2.5i
Newport blue
Damn photobucket
Old 04-05-2013, 11:39 PM   #10022
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Lol no that's just the normal way to do it. Bottom right hand corner has a flat head sized slot in it that you can get a panel tool or screwdriver in to pop it loose.
Old 04-05-2013, 11:40 PM   #10023
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Originally Posted by 08PrezaDave View Post
Damn photobucket
Looks dope.
Old 04-06-2013, 12:16 AM   #10024
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Damn photobucket
Interesting lol, looks super clean
Oh that's right, i forgot about that guy from last week
Old 04-06-2013, 01:27 AM   #10025
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Damn photobucket
Me likey. Moar pics! What tires you running?
Slow Scoobie is offline   Reply With Quote
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
