Old 04-27-2013, 12:02 AM   #10301
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Originally Posted by fancyfootwork15 View Post
You can pop your airbag out yourself and then adjust the steering wheel if you need to.
I wonder if it would be too far the other way if I clocked it one notch? hmmm..
I don't know if I want to mess around with the airbag though. Those things scare me.
BWX is offline   Reply With Quote
Old 04-27-2013, 12:05 AM   #10302
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Scared me too.. Just disconnect the battery, pump the brakes and wait 15 minutes for good measure. I actually painted my airbag with plasti-dip.
fancyfootwork15 is offline   Reply With Quote
Old 04-27-2013, 12:27 AM   #10303
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
So when you say "pop"- What exactly does that entail? I never really looked at that closely, is there a fastener of any kind or...?
Old 04-27-2013, 12:48 AM   #10304
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Did you ask them to do anything specific, like get as much camber as possible or anything like that? I've never had an alignment yet (bought new in '09), it never needed it, although the steering wheel is a little off center from new, but that didn't bother me enough to get it fixed since my alignment always felt good otherwise.
I asked for as much camber as possible while being even. I'm pretty sure one side will go farther than -1.4. And zero toe since I daily the car.
I wouldn't move the steering wheel if it was straight when you got it. It's possible that your toe specs got knocked out of alignment.
But you should go in for an alignment. I think they're recommended every year or so.
JourdanWithaU is offline   Reply With Quote
Old 04-27-2013, 12:56 AM   #10305
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I got the car brand new and the alignment felt perfect to me, and feels the same now actually, but the wheel was cocked a little from day one.
Tire wear is good too. I will have to get an alignment though, because it has been four years, and even if it feels good, it's bound to be out at least a little by now. I have never hit a really severe pothole, I usually dodge them, but I hit a few over the life of the car.
And when they do the alignment, I'll tell them to fix the steering wheel with the tie-rod-end adjusters.
edit- Your left rear camber is 1.7 while your right rear is 1.3- Did you notice that? Where did you get it done?
Old 04-27-2013, 01:05 AM   #10306
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
I noticed that my rear camber isn't even. It irritates me to no end. But it's stock linkage and not adjustable. One of the reasons why I had gotten adjustable LCAs. But I can't compete with them in stock class.
Old 04-27-2013, 01:12 AM   #10307
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
I've also noticed since i lowered my car, it likes to go to the right ever so slightly. I've had it aligned 3 times from my guy when i lowered and raised it. Would it be the toe that's pulling the car to the right? wear seems pretty even right now
Navysesal is offline   Reply With Quote
Old 04-27-2013, 08:46 AM   #10308
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Sometimes you can't tell...theres a lot of variables ranging from tires pressures to tire wear and sometimes the balancing. Just gotta put your shades on and deal with it haha
BSP671 is offline   Reply With Quote
Old 04-27-2013, 10:10 AM   #10309
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
Or he can just turn the radio up... Fixes all the BS i hear from my car everyday lol
Silver08Waggs is offline   Reply With Quote
Old 04-27-2013, 10:25 AM   #10310
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
You remove the airbag by loosening the two T30 torx screws on each side of the steering wheel column. It then just pull out (towards driver) and you unclip the wires.
Old 04-27-2013, 01:11 PM   #10311
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Cool.. Good to know.. I don't know if I will ever attempt that or not though!
Here's a project I did last week. Didn't get a pic of the Alpine speaker mounted because a thunderstorm blew in suddenly. It was the fastest I ever reinstalled the door panel- it took about 30 seconds, then it started raining buckets.
Old 04-27-2013, 01:56 PM   #10312
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
I think I was more scared painting the airbag then taking it off, lol. It was either spray it for $20 (Torx screwdriver and plasti dip).. or source out a black airbag for probably $400+
I've never heard of that sound deadening before. Are you going to be amping your speakers? Your sound will be better on a stock HU, much better with an aftermarket HU, and awesome if you amp the fronts. I have 80 watts going to each front speaker right now (Focal 5-1/4" Coaxial, will be upgrading to components sometime i'm sure). The sound is fantastic with clear power going to them.
Old 04-27-2013, 07:09 PM   #10313
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Yup I have these speakers:
Alpine SPR-60
http://www.sonicelectronix.com/item_...ne-SPR-60.html
Front and rear- and I have a 5 channel amp, but running rear speakers off head unit, and bridging front and rear of the 4 channel amp to 120 watts per channel at 4 ohms and running the fronts off that. It sounds a lot better that way, I tried both ways. I was basically just upgrading from the Polk speakers I got right after I bought the car 4 years ago. They still sounded ok, but they were definitely on their way out. It's a rough life inside the door of a car. I was going to go with seperates, but I think these Alpines sound amazing and are definitely better than the Polks. The silk dome tweeter alone is worth the price. The super lightweight polymer frame and neodymium magnets are cool too. I think they will do better in the long run. They aren't going to rust, that's for sure.
And this sound deadener-
http://www.sonicelectronix.com/item_...VX-SDDK12.html
It works.. and it was the cheapest stuff at the time.
-this head unit-
Pioneer AVH-P3300BT
http://www.crutchfield.com/p_130P330....html?tp=20217
This sub:
Kicker Solo Classic 09S10C4
10" subwoofer with dual 4-ohm voice coils
http://www.crutchfield.com/p_20609S1...C4.html?tp=111
Running off the class D sub channel @ 2ohms and 500 watts.
MTX 5 channel amp
The amp is great when it works.. Very powerful and clean, but it has failed twice. It is discontinued now so they (MTX) just replace all the guts when it stops working properly. I think they got it right last time because it works great still. I wouldn't recommend it though, Id get something more reliable. I only paid $300 for it though. It's a lot of amp for that price.
Old 04-27-2013, 08:14 PM   #10314
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Installed my stoptechs this morning and I love them lol. For 99$ I'm very impressed and 100% satisfied . Its a significant upgrade from OEM. Gunna go on a spirited drive right now n see how they hold up.
Steve2.5i is offline   Reply With Quote
Old 04-27-2013, 11:14 PM   #10315
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
I picked up a used steering wheel from a wrecked 09 WRX for 50 bucks! Well... I have to reuse my own airbag. :-p
Fendyman is offline   Reply With Quote
Old 04-28-2013, 03:28 AM   #10316
zsniperz
Member#: 352610
Anyone know if these rain guards are stick ons or inserted into the window frame? Thanks
http://www.subarugenuineparts.com/pr...82ba94cfed60f2
zsniperz is offline   Reply With Quote
Old 04-28-2013, 04:13 AM   #10317
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Mine wernt stock but they had 3m double sided tape. I believe the stock ones may have small metal brackets on them in addition to the tape
KartRacer3 is offline   Reply With Quote
Old 04-28-2013, 10:42 AM   #10318
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
I have those and they are attached by 2 things to the car. Double sided tape and metal brackets.
Slow Scoobie is offline   Reply With Quote
Old 04-28-2013, 12:26 PM   #10319
zsniperz
Member#: 352610
Thanks guys, I was hoping it wouldn't have double sided tape. Did the install look clean?
Old 04-28-2013, 12:35 PM   #10320
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Yea the install looks clean but if you want them to be secure the double sided tape is the main adhesive the clips are just an extra added security
Old 04-28-2013, 12:54 PM   #10321
Claybay
Member#: 301059
2008 Impreza
What oil psi are you guys at? I just installed the pro sport gauges and I read 20 at idle!
Claybay is offline   Reply With Quote
Old 04-28-2013, 01:33 PM   #10322
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
13 at idle for me lol. It ranges from 13-95 psi for me and i have rotella
20 is normal, if you have zero its bad Lol. And IIRC above 110psi is when the seals start to leaks
Old 04-28-2013, 02:49 PM   #10323
Pickler
Member#: 301247
09 Impreza 2.5i MT
i didn't know our cars report oil pressure, do they report oil temp as well? I have an OBDII (scangauge 2) reader and i was wondering if i could get the codes for oil specs. So far I have AFR, load, volumetric efficiency, fuel trims, exhaust temps, coolant and all the other usual crap.
Pickler is offline   Reply With Quote
Old 04-28-2013, 04:53 PM   #10324
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Switched to rotella yesterday, no noticeable difference, same can be said for the 87 at the pump. Maybe 4 tanks, can't tell a difference.
Found a nifty bike accessory today that allows me to mount my bike while keeping the basket on.
Sellars21 is offline   Reply With Quote
Old 04-28-2013, 05:24 PM   #10325
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Run it for 4k miles then do an oil analysis.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
