Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 06-13-2013, 10:42 PM   #10901
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Originally Posted by BSP671 View Post
Yep for 850 you could buy some racelands and have some change to spare. ISC's run around that price range if im not mistaken and for a little more, you could buy a brand new set of BC's.
Offtopic, Okay so I ordered shorter shock bodies so I could go lower in the front without hitting the CV boots. So in the mean time I tried drooping the coilovers in the front. I was honestly surprised I thought I would get alot more drop out of drooping. I did some before and after measurements and for 3/4inch of droop I only got 1/8th inch drop.
Slow Scoobie is offline   Reply With Quote
Old 06-14-2013, 05:49 AM   #10902
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
I think drooping 3/4" is very modest. The stuff that I've seen is pretty crazy where the preload is pretty much non existent. Like once the car is up in the air, there is so much play where the spring is like 3 inches from the perch lol. The BC extreme lows have a lot of pontential to get lower. I guess its just out of preference really. The only big problem to me, is the dang fronts with an 18" wheel and lack of room to work with.
BSP671 is online now   Reply With Quote
Old 06-14-2013, 09:44 AM   #10903
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
I've never had the chance to be hands on with coils. But when you talk about droop. Is that distance the wheel travelled in in the air relative to where it sits on the ground?
Sellars21 is offline   Reply With Quote
Old 06-14-2013, 09:51 AM   #10904
IllwaukeeNA2.5
Member#: 330830
2010 Impreza2.5i 5dr
Obsidian Black Pearl
If you can move the spring up and down that much, you'll be low but the ride will be horrible. Every bump would be so hard because there's nothing there, just the shocks until it hits the springs. My coils are drooping a tiny bit now and you can tell the difference while driving. Not worth it at all
IllwaukeeNA2.5 is offline   Reply With Quote
Old 06-14-2013, 11:40 AM   #10905
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Heres some shots taken over the weekend. These are straight out of the camera because I cant photoshop to save my life lol
Old 06-14-2013, 12:51 PM   #10906
IllwaukeeNA2.5
Member#: 330830
cleannnnnnnn. Wheel/tire specs????
Old 06-14-2013, 01:01 PM   #10907
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
That looks like a pretty aggressive fender roll.
What's going on with the front bumper?
JourdanWithaU is offline   Reply With Quote
Old 06-14-2013, 01:14 PM   #10908
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
18x9.5+34 with 225/40's gna try to change the stance with spacers and moar lows as soon as I get a job lol
It is pretty agressive with a flat roll and pull...camber is maxed out on the plates, bolts and still rubs.
The front bumper tabs wont hold the bumper flush to the fender anymore cuz it kept coming off everytime I scrape. Need to get those quick release thingys
Old 06-14-2013, 11:29 PM   #10909
IllwaukeeNA2.5
Member#: 330830
Redic. I don't think you can go any wider haha. My 9's even made me need a good rolling in the front and rear, and I still have rubbing problems with my camber plates all the way negative. Good luck!!
Old 06-15-2013, 12:23 AM   #10910
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Lol I originally wanted to go 10" but I wouldnt be able to go as low as I wanted. I just need some aftermarket camber bolts and possibly some notched plates for the fronts.
Old 06-15-2013, 12:37 AM   #10911
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
The problem im running into is the tires rubbing the inner portion of the fender during turns. Rubbed through to bare metal :/
Old 06-15-2013, 01:18 AM   #10912
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Whats your alignment specs? I had the same problem but I tweaked the camber as much as posible and played with the caster. Still need to get a real alignment though.
Old 06-15-2013, 03:27 AM   #10913
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
I have no idea lol, I tried using an app for measuring degrees so I could atleast have an educated guess for the camber. Problem is I cant find a decent app. Also I screw around so much with my suspension I dont see it worth being worth getting an alignment. At least not until I get it sitting how I want. I know I can pound on the inner fender with a hammer to push it back but I dont feel like it.
Old 06-15-2013, 09:00 AM   #10914
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Damn, they really do got an app for everything haha. From my experience, you'll never really get it to where you want. There will always be room for "improvement". Just gta be content with it lol. Got any more pics of your setup?
Old 06-15-2013, 11:39 AM   #10915
IllwaukeeNA2.5
Member#: 330830
Even with my 9's and fenders rolled alot, I have issues with hitting the inner fender on turns and my turning radius isn't too good either. The only fix is TONS of camber. (-5,-6 or so)
This was before I got my camber adjusted, went lower in the front and had them rolled. They rubbed so bad especially on turns (Still an issues now)
Old 06-15-2013, 01:34 PM   #10916
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
My 9"s don't rub.
Old 06-15-2013, 08:00 PM   #10917
SCNEot
Member#: 344260
2009 Impreza OBS
Sage Green
What lip is that? Do you have a link for it?
SCNEot is offline   Reply With Quote
Old 06-15-2013, 08:27 PM   #10918
Sellars21
Member#: 304055
How are you guys adjusting the rear camber? I don't have the ability to adjust as stock, but need to straighten it up.
Old 06-15-2013, 11:53 PM   #10919
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Bayson R for the STI...all over ebay
The rear cambers naturally. So the lower you go, the more it gives negative camber and vice versa. You can adjust your camber through rear control arms.
Old 06-16-2013, 12:33 AM   #10920
IllwaukeeNA2.5
Member#: 330830
My 9"s don't rub.
But what size tires are you running? I have 225/45 so its a higher sidewall
Old 06-16-2013, 12:35 AM   #10921
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
I actually took my goldies off and put the steelies back on. I'm selling the tires whivh are 235/45/17 Michelin pilot sport a/s plus. So thats the reason behind no moar pics :/
Old 06-16-2013, 12:56 AM   #10922
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
235/45/17 Star Specs. And they run a little wider than most tires.
And I drive like a nancy.
Old 06-16-2013, 04:13 AM   #10923
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Go 18's....but im guessing your selling them to go for a lower sidewall...
Old 06-16-2013, 10:53 AM   #10924
IllwaukeeNA2.5
Member#: 330830
You don't rub because you aren't that low I'm tucking tire all the way around, when I get a smaller sidewall tire I'll be even lower without issues
Old 06-16-2013, 04:05 PM   #10925
evanrussell
Member#: 358520
Has anyone upgraded their steering wheel? I'm looking to possibly get audio controls in my 09's steering wheel
evanrussell is offline   Reply With Quote
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
