Old 06-27-2013, 08:08 PM   #11101
SCNEot
Member#: 344260
2009 Impreza OBS
Sage Green
I think I might go design a rally-esque 2.5i, any ideas for it? Should i start a new thread?
SCNEot is offline   Reply With Quote
Old 06-27-2013, 10:38 PM   #11102
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
I'm trying to decide on what to do about my oil consumption issue. Currently my oil intervals r at 5k mi and I'm consuming about 1.5-2qts (yes I do fill as I go to keep the levels up). I'm running Motul 5w30 full syn. As far as my driving characteristics I commute about 35mi round trip per day on top of what I have to drive at work/around town. There is lots of heavy traffic after work. I drive pretty spirited around town n do enjoy an occasional mountain run about 1-4 times a month. I live in southern california basically sea level.
So my question is should I : A. Use cheap oil/whatever is on sale and switch my oil intervals to 3750 OR B. Switch to a thicker oil ie rotella T6 5w40? I'm aware that its mostly used in Turbo applications rather then n/a.
I'm on top of all my maintenance and check my oil levels after every gas fill up. I've been surfing thru bobistheoilguy forums, here on nasioc, and I've decided to ask for help lol. Pretty much spent the last 2 hours reading n reading.
Any tips or advice is greatly appreciated.
Steve2.5i is offline   Reply With Quote
Old 06-27-2013, 11:38 PM   #11103
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
I like to maintain quality and consistency, so I'd go for 5w40 over the cheapest crap I can find.
I was running 5w30 Mobil 1 and it was disappearing at an alarming rate. Switched to 5w40 Pentosynth and it was working well. Although now I am starting to lose some of that too. I'm on the verge of going to Blackstone.
JourdanWithaU is online now   Reply With Quote
Old 06-27-2013, 11:43 PM   #11104
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Originally Posted by Sellars21 View Post
Light weight flywheel...go team information!!
Lightweight flywheel =
All day... Everyday.
Old 06-27-2013, 11:57 PM   #11105
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Mobil 1 is notoriously bad for Subarus. Blackstone is good stuff.
fancyfootwork15 is offline   Reply With Quote
Old 06-28-2013, 12:23 AM   #11106
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Indeed. My buddy has been using Mobil 1 in his '02 WRX for years without problems. I thought NA would be fine. I was wrong.
Just put in a request for a blackstone kit.
Old 06-28-2013, 12:52 AM   #11107
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
I just filled my kit today, should find out if my head gasket is really causing problems or just playing around. I'm also running rotella t6 5-40.
As for the flywheel. Some one else on here is running one, if I'm not mistaken. What would cause a cel. And I was looking to do this for the unspoken search for n/a power....dum dum dummmm.
Sellars21 is offline   Reply With Quote
Old 06-28-2013, 01:39 AM   #11108
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Cylinder misfire. With less rotational mass, the engine will rev faster than it expects and misfire.
Old 06-28-2013, 01:52 AM   #11109
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Sweet thanks for the help guys, 5w40 it is. Ill report back with an update if the consumption is abnormal. I also have my Blackstone kit sitting off to the side, I'm going to send it off this weekend after I do my oil change.
Old 06-28-2013, 03:04 AM   #11110
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
I used rotellas well. Started to leak from the drain plug. I'm guessing it could of been from different oil pressure than it was use to. Or my crush washer is uneven. But I'm doing my oil change the following day. So hopefully everything is ok
Navysesal is offline   Reply With Quote
Old 06-28-2013, 01:15 PM   #11111
pinglover71
Member#: 360733
2016 WRX
Crystal black silica
Originally Posted by s1eepR View Post
Yes. You can buy DEPO fogs (OEM replicas for less than half of the OEM price, and clearer too). Just pop out the black mesh things in place and bolt the fogs to the brackets. You will need to buy a stalk with a fog switch on it, or tap into the headlights...the messy way.
I was unable to read the text in red. It doesn't show up on my screen, maybe someone else can chime in.
Jokes aside, nothing. The amount of money spent in implementing turbos and superchargers will be a waste in power - money ratio.
Yes.
Thanks! Ok i'm a noob in this so thanks for the advice lolol
pinglover71 is offline   Reply With Quote
Old 06-28-2013, 02:50 PM   #11112
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Seems I might be getting a job soon. Excited cuz I might be close to finishing what I got in mind for the car
BSP671 is offline   Reply With Quote
Old 06-28-2013, 03:45 PM   #11113
PrezaDriver2011
Member#: 336356
2005 Wrx Wagon
Damn that's clean
PrezaDriver2011 is offline   Reply With Quote
Old 06-28-2013, 03:54 PM   #11114
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
What do you have in mind?
Trading it in for a WRX?
Old 06-28-2013, 04:01 PM   #11115
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Originally Posted by PrezaDriver2011 View Post
Damn that's clean
Thanks man.
Haha I wish. Lord knows how much money ima pour into a turbo car I do know my next project, Im gna want to bag it.
Old 06-28-2013, 08:52 PM   #11116
PrezaDriver2011
Member#: 336356
2005 Wrx Wagon
I'm looking for a front lip for my Scooby and I ordered one off eBay and was very disappointed with it. Now I'm looking for a fiberglass or something like it. Urethane one warp too easy
Old 06-28-2013, 09:38 PM   #11117
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Which lip did you get? Polyurethane lips do sag over time, but can be shaped back. Plus they can take a beating and doesn't crack as easily as ABS or fiberglass.
Old 06-28-2013, 10:08 PM   #11118
theoutbackdream
Member#: 301179
2013 WRX Limited
for starters..
theoutbackdream is offline   Reply With Quote
Old 06-28-2013, 10:44 PM   #11119
SCNEot
Member#: 344260
2009 Impreza OBS
Sage Green
Originally Posted by theoutbackdream View Post
for starters..
Lights, yes we need plenty of lights
Old 06-28-2013, 10:53 PM   #11120
PrezaDriver2011
Member#: 336356
2005 Wrx Wagon
I ordered the v limited one for the 08-10 impreza wrx. It fit fine but with the past few hot days of 100 it decided to sag. I might take it off and reshape but if have to keep doing that every time it gets hot then I might just remove it for good and save up for a better one
Old 06-28-2013, 11:43 PM   #11121
Sellars21
Member#: 304055
And I assume that would only worsen with the addition of a light weight crank pulley,
Would the pulley alone also effect the car in in a similar manner?
And if combined, could you tune this properly for an advantage?
Old 06-29-2013, 08:50 PM   #11122
SCNEot
Member#: 344260
2009 Impreza OBS
Sage Green
I would think it would be more ballanced but dont take my word for it.
Old 06-29-2013, 11:10 PM   #11123
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Yes.
Yes, but not as much. The pulley doesn't have as much inertia as the flywheel.
Possibly. I'm not sure.
Old 07-01-2013, 11:30 AM   #11124
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
I got a few pictures from the track day ill be posting up shortly
Silver08Waggs is offline   Reply With Quote
Old 07-01-2013, 11:58 AM   #11125
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
First batch
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
