Old 08-03-2013, 02:27 AM   #11501
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
Originally Posted by fancyfootwork15 View Post
Considering the Koni damper rate is probably better than any 1k coilover, id say your ride would worsen.
Yeah, maybe I'll look into doing a ground control conversion they recently came out with an 04+ impreza so maybe I'll shoot an email. I'm mainly looking to go little lower so that might be best bet
Silver08Waggs is offline   Reply With Quote
Old 08-03-2013, 02:34 AM   #11502
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Man that wiring sounds like a huge pain in the ass. I routed mine through the front fender into the grommet under the driver side wheel well liner. That was a much easier than what you just described with half the dash out! It was a very fat 4 gauge wire too.. that grommet is big and relatively easy to get to inside and outside.
BWX is offline   Reply With Quote
Old 08-03-2013, 07:21 AM   #11503
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Koni and Ground Control is a game winning combination. I'm planning to get on of their kits once the season ends.
JourdanWithaU is offline   Reply With Quote
Old 08-03-2013, 08:01 AM   #11504
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
I removed most of the dash just looking for another grommet on drivers side. I didn't have to do it. It's not so bad now. Wire comes from battery, similar to yours and now runs along the firewall. Two wires enter the cabin, the other wire was coming from passenger side A pillar on the outside anyway. Up to the passenger side of rack and basket setup.
Sellars21 is offline   Reply With Quote
Old 08-03-2013, 09:17 AM   #11505
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
So what your saying is keep the konis sell the h&r springs and get the ground control coilover conversion?
Old 08-03-2013, 12:46 PM   #11506
premier00000
Member#: 251060
2008 Impreza Outback
I'll be selling my KSport coilovers soon, they're a little rough because of the winters up here and they took a bit of work to get everything loose but everything moves fine now.
premier00000 is offline   Reply With Quote
Old 08-03-2013, 05:37 PM   #11507
Cmac13
Member#: 312011
2009 impreza 2.5i
white
For everyone whose running coilovers, what brand, how are they for everyday driving(i do about 18k miles a year) and what about for when you hit the track or twisty roads? Kinda thinking of getting rid if the konis and going coils... Have kw v1, tein, or either bc br or bc inverted in mind let me know what you coilover users think... Thanks!!!
I'm running tein super street with the camber plates, the ride is stiff but my only compliant would be they don't go low enough
Cmac13 is offline   Reply With Quote
Old 08-03-2013, 05:47 PM   #11508
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Shorter coilover springs, shorter shock bodies, droop the spring, lower profile tires (friend went from a 245/45/17 which is a pretty tall tire to a 215/40/17 on his new rims dropped him almost another inch)... My only complaint about coilovers for our cars is non of them have rear camber plates or atleast not any that I know of.
Also I heard the inverted BC's blow out faster than the normal BC's but dont quote me on that.
Slow Scoobie is offline   Reply With Quote
Old 08-03-2013, 06:00 PM   #11509
MikeMiranda
Member#: 355937
2010 Impreza OBS
Black on Black
I'm running feal 441 coilovers which have been great for daily driving
When I lowered mine that was my main concern that there wasn't any toe/camber adjustment in the Rear I ended up buy the spc camber & toe kit which set me back $500 or so
MikeMiranda is offline   Reply With Quote
Old 08-03-2013, 06:01 PM   #11510
premier00000
Member#: 251060
You're correct. And that's because the struts really have no control over camber anyway.
Old 08-03-2013, 07:13 PM   #11511
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Yes. Maybe grab some camber plates, but that's up to you.
What do you need a rear camber plate for?
Old 08-03-2013, 07:26 PM   #11512
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Same thing I said.
fancyfootwork15 is offline   Reply With Quote
Old 08-03-2013, 07:58 PM   #11513
bgate21
Member#: 354404
Does anyone know if the Wrx bumpers and sideskirts bolt up to 2.5i's?
bgate21 is offline   Reply With Quote
Old 08-03-2013, 08:33 PM   #11514
Gdspliff
Member#: 348014
2010 2.5i
Orange
The bumper does bolt up but the side skirts don't you need to modify your side panel under the door to clip the side skirts to the panel so they don't drag
Gdspliff is offline   Reply With Quote
Old 08-03-2013, 08:40 PM   #11515
theoutbackdream
Member#: 301179
2013 WRX Limited
Narrow body wrx bumpers should fit, since it is the same body as the 2.5i with more styling.
theoutbackdream is offline   Reply With Quote
Old 08-03-2013, 08:45 PM   #11516
Gdspliff
Member#: 348014
2010 2.5i
Orange
Side skirts don't fit with out modification I know since I've did my narrow 2.5i with all the wrx add ons besides the read wing which I went with Sti just cause I like the big rear wing not the little deck lip
Old 08-03-2013, 10:33 PM   #11517
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Oh I dont know....maybe to adujst camber. Positive camber I want more of it. I know I would need control arms for that, but I dont want to drop that much money. I know even if there were rear camber plates for our cars they wouldn't do anything because of how the back portion of the suspension is designed.
Old 08-04-2013, 01:52 AM   #11518
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
The rears are shocks.
I saw some super expensive Msi rear camber plates on rallysportdirect the other day.
Why do you need more positive camber? Are your tires wearing to much with your current setup slowscoobie?
KartRacer3 is offline   Reply With Quote
Old 08-04-2013, 01:52 AM   #11519
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
You know they won't do anything. But you want them anyway?
I think he's saying he wants to get positive to negate all the negative camber that happens naturally.
Old 08-04-2013, 01:55 AM   #11520
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Gdspliff- you mean attach them to the car? Lol. I'm pretty sure the wrx sideskirts use oem clip in spots to attach, which our cars do not have (at least on the US models)
Old 08-04-2013, 03:04 AM   #11521
Gdspliff
Member#: 348014
2010 2.5i
Orange
Yeah buddy thank you I had to make holes so I had somewhere for the clips to go and then I painted those holes black to make sure rust doesn't develop quick since I live in New England aka Mass Hole and our plow drivers suck at plowing and sanding the streets I try not to use my car too much I use my 04 wrx since my 09 2.5i is on bags
Old 08-04-2013, 04:08 AM   #11522
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Hit the nail on the head with that one. Since he's lowered, the natural negative camber may be too much. Causing clearance issues and other stuff.
BSP671 is offline   Reply With Quote
Old 08-04-2013, 04:49 AM   #11523
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Same reason why I had my adjustable control arms. With the height I was at, my rear camber would have been almost -3 degrees. Used the adjustable arms and brought it to -1.
Old 08-04-2013, 07:37 AM   #11524
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I was thinking about getting the '09 WRX narrow body bumper with that lip looking think molded into it at one time.. Anyway, I did notice that it would fit, except the wheel well liners also either need to be replaced, or modified to fit correctly. They are different on those cars, they are a different shape on the bottom front.
Old 08-04-2013, 12:27 PM   #11525
DownhillSubie
Member#: 342985
Posting up my Magnaflow Catback for 08-10 2.5i/WRX sedans. PM me!
http://forums.nasioc.com/forums/show...9#post40338649
DownhillSubie is offline   Reply With Quote
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
