Old 08-06-2013, 07:44 PM   #11551
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Originally Posted by ajracerfan View Post
My headlights are getting kinda gross , but only on top. Any pointers?
Meguiars Plastx.. then wax them every couple weeks.
The only way to truly correct that is to sand them and respray a clear on them.
fancyfootwork15 is offline   Reply With Quote
Old 08-06-2013, 08:31 PM   #11552
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
+1! I just got the 3M headlight sanding drill bit and used the plastx on my bros 04 STI and a friends '02 RS and it did magic.
KartRacer3 is offline   Reply With Quote
Old 08-06-2013, 11:45 PM   #11553
premier00000
Member#: 251060
2008 Impreza Outback
Either I need a good buff and wax, or just a lot of dirt and mud...
premier00000 is offline   Reply With Quote
Old 08-07-2013, 01:41 AM   #11554
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
^awesome...
Do wheels rub when you turn?
Fendyman is offline   Reply With Quote
Old 08-07-2013, 01:56 AM   #11555
kreitz3
Member#: 100242
What light bar on that OBS?
kreitz3 is offline   Reply With Quote
Old 08-07-2013, 08:07 AM   #11556
premier00000
Member#: 251060
Nothing rubs at all, and I have the Rally Innovations light bar. Which is for sale and currently still on the car.
Old 08-07-2013, 08:28 AM   #11557
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
looks GREAT. Why do you get rid of the bar? Also, what's the tyre size you're running?
Old 08-07-2013, 08:46 AM   #11558
premier00000
Member#: 251060
I haven't got rid of the bar yet, that pic is from yesterday afternoon.
And I'm planning on getting a custom light bar and skid plate made that fits my needs. It will be larger diameter and thickness bar. And it will match the custom roof rack I'll have built at the same time. I've already gotten a price for all of it and it sounds like a pretty good deal.
And the tires are 205/75-15
Old 08-07-2013, 02:13 PM   #11559
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Light bar installed today. It's pretty bright.
Sellars21 is offline   Reply With Quote
Old 08-07-2013, 02:56 PM   #11560
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Nice! Is that a 20"?
Old 08-07-2013, 03:14 PM   #11561
subyski
Member#: 202642
08 Impreza,80Vette
68 Impala, 15 SantaFe
Where are you running the wires from the light bar into the cabin?
subyski is offline   Reply With Quote
Old 08-07-2013, 03:33 PM   #11562
Sellars21
Member#: 304055
24", I needed something that would fit without obstruct the bike fork mount
Under the rack, into the rail trim, along the windshield and under the plastic trim into the engine bay. From there to power and switches inside.
Old 08-07-2013, 04:27 PM   #11563
premier00000
Member#: 251060
24", I needed something that would fit without obstruct the bike fork mount Under the rack, into the rail trim, along the windshield and under the plastic trim into the engine bay. From there to power and switches inside.
Is that speaker wire??
Old 08-07-2013, 04:40 PM   #11564
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Should probably at least wrap that with black electrical tape or run it through the roof somehow.
Old 08-07-2013, 06:56 PM   #11565
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Originally Posted by premier00000 View Post
I disabled my DRLs today because the bulbs I put in there kept blowing, I guess they didn't like the low voltage all the time.
Nope they dont. A solution is to use fogs as DRLs instead, it's a simple rewire...
Old 08-07-2013, 07:10 PM   #11566
premier00000
Member#: 251060
I use my Hella 500FF fogs if I need some extra light during the day.
Old 08-07-2013, 07:12 PM   #11567
Bluefoton
Member#: 141373
2008 2.5i-hatch -
^ can't argue with that. The car is raised? There's surpisingly little clearance with the fender in the back for wider tires
Old 08-07-2013, 07:18 PM   #11568
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
My high beams only ever last a couple years because of that issue.. but I like having DRL, and I have no fogs, so I just keep replacing them when they fail. They actually dim a little bit over a two year period, so having fresh ones in there all the time is nice. I use Osram Silverstar Ultra highs, and H11 to H9 mod lows. I think I may change to the 9011 instead of 9005 high soon, non-tinted, but anyway..
My bro was in my car a couple weeks ago at night , and he is used to his Mazdaspeed3 Bi-Xenon HID headlights or Acura TL HIDs, and he was very impressed with my setup. It is probably just as much about perfect aim as the actual bulbs, but they are impressive, especially the high beams.
BWX is offline   Reply With Quote
Old 08-07-2013, 07:25 PM   #11569
premier00000
Member#: 251060
Fender clearance is easily adjusted with a fender roller and a little bit of time. My fenders are actually pulled out about an inch or so on each side... From when I was lowered and running +32 offset and 245 tires.
Old 08-07-2013, 08:14 PM   #11570
Sellars21
Member#: 304055
Yeah it is, I researched it and its the same as long as the gauge an contain the power output. I needed speaker wire so the power and ground were basically one cord and low on bulk. It's also a 14 gauge, plenty for an led bar.
It's just a prototype for now, I'll have everything hidden as a final result. I will also waterproof everything in the process for maximum lifespan.
Old 08-09-2013, 01:16 AM   #11571
ccalsubi
Member#: 264596
2008 Impreza 2.5i
obp
New to me volk le37-t
ccalsubi is offline   Reply With Quote
Old 08-09-2013, 01:52 AM   #11572
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Specs please!
Old 08-09-2013, 02:01 AM   #11573
ccalsubi
Member#: 264596
2008 Impreza 2.5i
obp
Nothing fancy 17x7.5 +48
Old 08-09-2013, 03:00 AM   #11574
theoutbackdream
Member#: 301179
2013 WRX Limited
cannot wait to see on your car!
theoutbackdream is offline   Reply With Quote
Old 08-09-2013, 02:54 PM   #11575
ccalsubi
Member#: 264596
2008 Impreza 2.5i
obp
Wheels are on!!
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
