Old 10-05-2013, 07:11 PM   #12201
MikeMiranda
Member#: 355937
2010 Impreza OBS
Black on Black
Yah didn't care to drive stick this time , if the tranny ever went I'd convert over to stick
MikeMiranda is offline   Reply With Quote
Old 10-06-2013, 04:54 AM   #12202
Rhefqab
Member#: 259892
2010 Impreza 2.5i
SSM
Quick question:
Does anyone else have problems with their Rally Armor mudflaps rubbing against their tires? It's usually only when there is weight in the back of my car. I just had to haul 4 tires and whenever i took a corner or hit a bump the screw/washer would rub on the tire.
Had this problem before and actually had to pull over and take the mudflap completely off. I have a 2010 2.5i sedan and i'm wondering if the wheel well cover is making it so my mudflaps are too close to my tires and if so how people worked around it..
Rhefqab is offline   Reply With Quote
Old 10-06-2013, 11:53 AM   #12203
theoutbackdream
Member#: 301179
2013 WRX Limited
Originally Posted by Rhefqab View Post
Quick question:
Never had issues with the mudflaps rubbing the tire, but it sounds more like you are Rubbing the ground and not your tires.
I have this issue, and I just let it go. But what I did was just take them off until I actually needed them for winter.
theoutbackdream is offline   Reply With Quote
Old 10-06-2013, 12:16 PM   #12204
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Quick question:
My rally armors kept hitting my exhaust. I got sick of the look and took them off.
fancyfootwork15 is offline   Reply With Quote
Old 10-06-2013, 01:04 PM   #12205
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Quick question: Does anyone else have problems with their Rally Armor mudflaps rubbing against their tires? It's usually only when there is weight in the back of my car. I just had to haul 4 tires and whenever i took a corner or hit a bump the screw/washer would rub on the tire. Had this problem before and actually had to pull over and take the mudflap completely off. I have a 2010 2.5i sedan and i'm wondering if the wheel well cover is making it so my mudflaps are too close to my tires and if so how people worked around it..
Rears hit the ground when karting around some fatties. Or entering near vertical driveways.
Sellars21 is offline   Reply With Quote
Old 10-06-2013, 01:05 PM   #12206
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
My tires don't rub my rallyarmors and I got like a half inch of clearance.
Slow Scoobie is offline   Reply With Quote
Old 10-06-2013, 01:53 PM   #12207
Rhefqab
Member#: 259892
2010 Impreza 2.5i
SSM
That's what I thought too, but then I went out and checked the washer was worn down and the screw was in contact with the tire...and burning hot... I think its and issue with the spacer they provided. Seems too big and kind of unnecessary especially if its going to cause contact w/ the tire when weight is added. (its been the inside screw thats been the problem)
Old 10-06-2013, 03:15 PM   #12208
theoutbackdream
Member#: 301179
2013 WRX Limited
jeez. what kind of tires are you running?
the spacer may be an issue, but its a first to hear. lol
Old 10-06-2013, 06:09 PM   #12209
Rhefqab
Member#: 259892
2010 Impreza 2.5i
SSM
Nothing aggressive. Just 215's wrapped around 17" wrx wheels on stock suspension. May just scrap the spacers because they just angle the tops of the mudflaps towards the tire. Tried to snap a quick cell pic to show what i am talking about. (again, only is a problem when hauling weight in the rear. Completely fine just cruising around town)
215/50/17
Old 10-06-2013, 06:32 PM   #12210
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
215/50/17
215/45 is the recommended tire size... That is about an inch taller than stock. But, removing the spacer should fix it!
Digital Dillon is offline   Reply With Quote
Old 10-06-2013, 07:17 PM   #12211
theoutbackdream
Member#: 301179
2013 WRX Limited
215/50/17
You shouldn't have a problem since stock OBS wheels are 205/50/17 (I had 235/45/17 stock WRX wheels, on the OBS, and no issues with clearing, or rubbing), and in the pic it looks like you have enough clearance.
It looks liek the inside of the flap it self needs to be secured. And if it isn't that, the metal bracket (assuming its RA UR), needs to be bend back towards the rear of the car. I would only assume this since you are clearing without weight, but once weight is in. The tire gets closer to the inside of the flap.
Old 10-06-2013, 08:50 PM   #12212
Rhefqab
Member#: 259892
2010 Impreza 2.5i
SSM
Yeah it's gonna be an easy fix. Was just wondering if anyone else was experiencing the same thing. Thanks everyone for your help and responses
Old 10-06-2013, 09:07 PM   #12213
theoutbackdream
Member#: 301179
2013 WRX Limited
Good luck! Let us know what fixed it!
Old 10-06-2013, 11:01 PM   #12214
SCNEot
Member#: 344260
2009 Impreza OBS
Sage Green
Im starting to want a fixed caliper in the front, 4 pots or something, maybe i can find a really good deal for calipers and hardware...
SCNEot is offline   Reply With Quote
Old 10-07-2013, 07:32 AM   #12215
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Quick question:
Not here.. Just 17x8 225-45
(need to paint screws, LOL)
BWX is offline   Reply With Quote
Old 10-07-2013, 12:38 PM   #12216
Gor3bash
Member#: 360838
Default pics of the new car
Washing the cars with my buddy... 2010 impreza limited and a saabaru 92x
Gor3bash is offline   Reply With Quote
Old 10-07-2013, 02:41 PM   #12217
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Went to get an alignment not a full alignment though... I told them just to zero the toe and leave everything else alone. Well now I have a ****load of rubbing and my axles hit the frame. Prior to the toe adjustment rubbing was minimal and there was zero frame/axle contact.
Old 10-07-2013, 02:58 PM   #12218
Digital Dillon
Member#: 288727
2008 WRX premium
They must have messed with the camber, and I'm not surprised by the axles... Go stiffer or notch it, your pretty slammed
Old 10-07-2013, 03:22 PM   #12219
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
10k springs upfront and full stiff. Also camber is exactly the same before and after according to the print out. Camber plates still maxed out. The top bolt in strut still has the lines matched up I drew on with a Sharpie. Rage just simply setting toe to zero threw everything off. FUUUCK!
Edit trying to avoid notching...or let my axles do it for me, I cringe everytime I hear it banging.
22.35" fender to ground all around
Old 10-07-2013, 03:24 PM   #12220
MikeMiranda
Member#: 355937
2010 Impreza OBS
Black on Black
Doesn't camber directly affect toe when either is adjusted
Old 10-07-2013, 04:20 PM   #12221
SCNEot
Member#: 344260
2009 Impreza OBS
Sage Green
No, not really, if anything it still stays in spec.
Old 10-07-2013, 07:22 PM   #12222
bidaci
Member#: 291519
2011 OBS
I believe camber will effect toe but toe won't effect camber.
bidaci is offline   Reply With Quote
Old 10-07-2013, 09:38 PM   #12223
SCNEot
Member#: 344260
2009 Impreza OBS
Sage Green
On the next alignment i work on i will let you guys know, helps to have a 20k dollar alignment rack in the shop
Old 10-07-2013, 11:28 PM   #12224
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Just messed with my toe, took some before and after fender to ground measurements. My ride height actually did change a bit but nothing drastic maybe 2 or 3/ 16ths of an inch.
Old 10-08-2013, 06:15 AM   #12225
SCNEot
Member#: 344260
2009 Impreza OBS
Sage Green
I like using the sensors to see all the measurements, very good method
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
