Old 11-25-2010, 08:02 PM   #1276
SUBIESROCKUKNOW
Member#: 214464
2008 Impreza 2.5i
Satin white pearl
hey JourdanWithaU wut type of exhaust is that? it lloks good i want sumthing like that on mine.. i got the SPT 08 WRX on mine
SUBIESROCKUKNOW is offline   Reply With Quote
Old 11-25-2010, 10:13 PM   #1277
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
It's a SRS N1 3" Catback. In the pictures above and below it is on extra long hangers.
The extra long hangers were great when it came to where the tip was in relationship to the bumper but the flange that is nearest to the rear diff hung too low and I scraped it a lot.
I recently swapped out the hangers for the stock hangers and then this happened.
I just can't win...
JourdanWithaU is offline   Reply With Quote
Old 11-27-2010, 12:53 AM   #1278
SUBIESROCKUKNOW
Member#: 214464
2008 Impreza 2.5i
Satin white pearl
Aww man what happend there did it melt or burn it.. y don't u go see a muffler shop n see what they can co
Old 11-27-2010, 10:24 AM   #1279
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
I bottomed out and the tip smashed the bumper. I plan to get a lip kit deal to cover it up. When the lip goes on, the muffler will be adjusted at the same time.
Old 11-27-2010, 06:22 PM   #1280
SUBIESROCKUKNOW
Member#: 214464
2008 Impreza 2.5i
Satin white pearl
It looks good though bro.. I've bottomed out before but no damage to the bumper
Old 11-28-2010, 12:45 PM   #1281
Stiman1
Member#: 87043
2006 sti
Aw/gold
Since we're saving for a house, another free mod:
I painted the moustache flat black:
Was thinking of painting this (Chrome) next... what do you think?
Stiman1 is offline   Reply With Quote
Old 11-28-2010, 01:28 PM   #1282
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Do it!
Old 11-29-2010, 09:28 AM   #1283
Geerolla
Member#: 264827
2011 2.5i 5D
Nice mod! I almost like that better than the sport grille I was thinking about getting.
Geerolla is offline   Reply With Quote
Old 11-29-2010, 12:01 PM   #1284
BlueMolecule
Member#: 210006
I bought paint to do the same. is it necessary to scruff and prime the plastic chrome first?
BlueMolecule is offline   Reply With Quote
Old 11-29-2010, 12:25 PM   #1285
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
YES! I didn't do any prep (like an idiot) on my trunk trim (and my grille) and the paint is chipping off very easily.
Old 11-29-2010, 04:00 PM   #1286
SUBIESROCKUKNOW
Member#: 214464
2008 Impreza 2.5i
Satin white pearl
^^ u always gotta prep b4 u paint bro
Old 11-29-2010, 09:51 PM   #1287
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Yeah yeah yeah yeah. I don't know why I didn't prep.
Old 11-29-2010, 10:24 PM   #1288
shakermaker
Member#: 254535
can someone expand on "prep"?
Does this involve sanding?
I want to do this: (like above)
shakermaker is offline   Reply With Quote
Old 11-29-2010, 10:37 PM   #1289
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Clean it, Mask what you don't want painted, sand it, clean it (again), Spray a coat of primer, Let it dry, Spray a coat of the color you want and let dry (repeat for a couple of coats), Spray clear coat and let it dry (if desired), Remove masking.
There are some videos on YouTube that go into a bit more detail, but that's the gist of it.
Old 11-29-2010, 10:38 PM   #1290
SUBIESROCKUKNOW
Member#: 214464
2008 Impreza 2.5i
Satin white pearl
clean it up real good i use water n sum alcohol pads.. No sanding just scuff it up with a scotch bright pad u can gettem at homedepot.. clean it once after u do that I used alcohol pads to get any fine particles I missed.. prime it let it dry then paint let it dry then clear coat.. I also used latex gloves doing this so the oil on ur fingers wont be seen
Old 11-29-2010, 10:58 PM   #1291
shakermaker
Member#: 254535
thanks guys
Old 11-29-2010, 11:10 PM   #1292
SUBIESROCKUKNOW
Member#: 214464
2008 Impreza 2.5i
Satin white pearl
No problem good luck with ur DIY mod post sum pics after ur done
Old 11-30-2010, 06:46 PM   #1293
Stiman1
Member#: 87043
2006 sti
Aw/gold
You can remove the moustache only (it's 4 screws) so you don't need to mask anything.
My only prep was washing with dish detergent and scrubbing with a 3M pad. I put 1 layer of primer and about 5 coats of flat black.
Good luck
Old 12-01-2010, 10:50 PM   #1294
Thio
Member#: 47700
2011 GH 2.5i
SSM
Hello!
I have been surfing this forum for a while, but recently I dove into a Silver 2.5i 5MT hatch, no options whatsoever. I didn't wanna drive a small front-drive econobox around that has one of the lowest safety ratings currently on the road, hahaha. I'm glad to have this car as it's my first time driving an AWD car In addition, it is one of the safest cars out there =D
Anyways, I noticed the rev's hanging, and I thought FLZ_Boy's explanation makes the most sense:
Originally Posted by FLZ_Boy View Post
I believe that the extra revs/holding or revs are to “somewhat” to help rev match your gear into relation with the speed of the car. Although, it really doesn’t do a great job at it (and it gets rather annoying if you do try to rev match during road courses). Subaru was better off leaving off this feature/annoyance, because it helps beginning manual drivers (less change to stall). However, it becomes harder to rev match for more experienced manual drivers (and sometimes causes more undue stress to the clutch and tranny).
I’m sure some of you 5-Speed manual experience the revs holding when you switch to higher gears also. I feel that the holding of revs just put more undue stress to the clutch and tranny and just accelerating clutch wear.
When I slow to crawling speed and push in the clutch while in gear, I sometimes would just shift to neutral to bring down the revs as it appears that the bumping of revs occur while you have the clutch pushed in, car is moving, and your in gear.
Or I can be totally wrong about this feature and Subaru just doesn’t have a great throttle by wire.
One trick I found that could help bring the rev's down from that "hang" is when you shift from whatever gear you're in to neutral first, then wait for the rev's to drop until it appropriately matches the rev's for the next gear. That's one way to drop the rev's. Mind you, this is dangerous when doing it in fast-moving traffic as the 1-2 shift could take some time while traffic is continuously accelerating, unless you accelerate fast enough to compensate for the time to shift from 1st to neutral to 2nd.
Just thought I would contribute since there might be other 5MT owners wondering the same thing. And anyways, I'm learning a lot about what other 2.5i owners are doing out there, so that's always awesome
Hope to contribute more and be a part of some discussion in the future
Thio is offline   Reply With Quote
Old 12-02-2010, 10:50 AM   #1295
BlueMolecule
Member#: 210006
Welcome to the thread thio
What you are describing is double clutching downshift. It works for me I use alot except when in a situation where I need to get into low gear quickly to accelerate. It makes deceleration smoother when you get it right. I wonder if the hanging revs are due to advanced ignition timing, cause you get a bit of a rev bounce after letting off throttle.
Old 12-02-2010, 10:58 AM   #1296
BlueMolecule
Member#: 210006
Nm. You are talking about shifting up. Yea I just leave the clutch pushed in until the revs are in good range 2200-2500rpm? It helps if you back off throttle before pushing in clutch. Never tried double clutch up shift. I'll try it on commute home.
Old 12-03-2010, 01:24 AM   #1297
ryandsouza
Member#: 247034
2008 Impreza 2.5i
Bought the premium wheels off someone on nasioc. Loving that I have actual rims now granted its no crazy change. Although winters coming up so I might through the steelies back on.
ryandsouza is offline   Reply With Quote
Old 12-05-2010, 08:59 PM   #1298
Stiman1
Member#: 87043
2006 sti
Aw/gold
So I painted the chrome the same flat black; it looks OK just not the same impact as the grill imo. I also think it will look better with the dark summer wheels instead of my winters which I just put on.
Old 12-13-2010, 04:09 PM   #1299
SUBIESROCKUKNOW
Member#: 214464
2008 Impreza 2.5i
Satin white pearl
Lookin good.. good job
Old 12-14-2010, 12:30 AM   #1300
Thio
Member#: 47700
2011 GH 2.5i
SSM
Hi,
Thanks for the welcome
I tried this and I'm starting to get the hang of it. It seems much safer than letting the car coast in neutral while the engine revs fall. Thanks again
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
