Old 01-25-2014, 07:24 PM   #13801
IllwaukeeNA2.5
Member#: 330830
2010 Impreza2.5i 5dr
Obsidian Black Pearl
Originally Posted by DirknJirkn13 View Post
Thanks. I need ideas for a shift pattern sticker/badge.
just memorize haha. I probably have the best shift knob on here
IllwaukeeNA2.5 is offline   Reply With Quote
Old 01-25-2014, 07:26 PM   #13802
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
No...
fancyfootwork15 is offline   Reply With Quote
Old 01-25-2014, 08:13 PM   #13803
IllwaukeeNA2.5
Member#: 330830
Originally Posted by fancyfootwork15 View Post
No...
it's probably the same one your girlfriend uses
Old 01-25-2014, 08:14 PM   #13804
DirknJirkn13
Member#: 249696
2010 Outback Sport
I need one in there for other people driving my car who would probably looking for a clutch haha.
DirknJirkn13 is offline   Reply With Quote
Old 01-25-2014, 08:21 PM   #13805
IllwaukeeNA2.5
Member#: 330830
it does make it look like a manual haha. I only let my girlfriend drive the car now that it's on springs, on coilovers she scared me to death driving it alone
Old 01-25-2014, 09:43 PM   #13806
SCNEot
Member#: 344260
2009 Impreza OBS
Sage Green
More info por favor...
SCNEot is offline   Reply With Quote
Old 01-25-2014, 11:04 PM   #13807
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Lol. Kids these days.
Old 01-25-2014, 11:22 PM   #13808
Digital Dillon
Member#: 288727
2008 WRX premium
I want the same style with a cherry blossom inside or a piston style with extension would be cool and probably look a bit cleaner.
Digital Dillon is offline   Reply With Quote
Old 01-26-2014, 12:04 AM   #13809
IllwaukeeNA2.5
Member#: 330830
it was from my brothers drift car and he put it on as a joke
Old 01-26-2014, 01:34 AM   #13810
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Do like. Looks very clean dirkn
Steve2.5i is offline   Reply With Quote
Old 01-26-2014, 02:20 AM   #13811
ccalsubi
Member#: 264596
2008 Impreza 2.5i
obp
+1 more info
ccalsubi is offline   Reply With Quote
Old 01-26-2014, 02:39 AM   #13812
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Please...
JourdanWithaU is online now   Reply With Quote
Old 01-26-2014, 08:26 AM   #13813
DirknJirkn13
Member#: 249696
2010 Outback Sport
Thanks for all the likes! I don't have many pictures of the process but here's what I did. I started off buying a used 2011 wrx shift boot locally for cheap. Then I took apart the center console and removed the shifter surround. It is easiest when the car is in neutral.
I cut 4 long thin strips of acrylic sheet for the 4 edges underneath. Then I cut tabs into the leather that could be wedged between the underside of the shifter surround and an acrylic piece. Using Weld-on 16 acrylic cement I glued the acrylic to the plastic. I also used krazy glue for the corners to hold them down better. Here is a final shot of the underside and topside.
To install it, I removed the piece that shows the PRND so there was more room. Just disconnect the wire and pull up on it and it comes off.
I still have some work to do on it but for now it'll do. I want to see some of you other guys try this!
Old 01-26-2014, 05:49 PM   #13814
DirknJirkn13
Member#: 249696
2010 Outback Sport
Whelp Mikey couldn't tune my car today because my ECU was locked! What gives? Could it be from me resetting the ECU with my Bluetooth OBDII module?
Old 01-26-2014, 09:00 PM   #13815
P_Cat97
Member#: 366085
2010 Impreza 2.5i PE
Thanks for all the likes! I don't have many pictures of the process but here's what I did. I started off buying a used 2011 wrx shift boot locally for cheap. Then I took apart the center console and removed the shifter surround. It is easiest when the car is in neutral. I cut 4 long thin strips of acrylic sheet for the 4 edges underneath. Then I cut tabs into the leather that could be wedged between the underside of the shifter surround and an acrylic piece. Using Weld-on 16 acrylic center I glued the acrylic to the plastic. I also used krazy glue for the corners to hold them down better. Here is a final shot of the underside and topside. To install it, I removed the piece that shows the PRND so there was more room. Just disconnect the wire and pull up on it and it comes off. I still have some work to do on it but for now it'll do. I want to see some of you other guys try this!
+1 Awesome write up! I have been thinking of doing this since I got my car but didn't know how to go about doing it. Now that you posted that this might be next weekends project!
P_Cat97 is offline   Reply With Quote
Old 01-27-2014, 11:44 AM   #13816
gracker
Member#: 366251
2010 Impreza Premium
Spark Silver Metallic
Has anyone here put supertones in their 2.5i's?
gracker is offline   Reply With Quote
Old 01-27-2014, 12:10 PM   #13817
MikeMiranda
Member#: 355937
2010 Impreza OBS
Black on Black
My next mod
MikeMiranda is offline   Reply With Quote
Old 01-27-2014, 12:17 PM   #13818
Slacktron
Member#: 339342
2009 Impreza 2.5i
Yes... it was well worth it, although they look much better with a mesh grille (a la wrx/sti). I used the subimods kit, it comes with a bracket to get them in just the right position.
Slacktron is offline   Reply With Quote
Old 01-27-2014, 03:27 PM   #13819
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Yes, first mod I did. Sadly they werent as beefy as I had hoped. They are loud but in a more high pitched way.
Slow Scoobie is offline   Reply With Quote
Old 01-27-2014, 04:51 PM   #13820
P_Cat97
Member#: 366085
Originally Posted by Slow Scoobie View Post
Yes, first mod I did. Sadly they werent as beefy as I had hopped. They are loud but in a more high pitched way.
Has anyone put quad hella super tones?
Old 01-27-2014, 04:54 PM   #13821
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
What is the fascination with upgraded horns? Are you really using them that much that it makes a difference or are you just trying to look/sound cool by having them?
Old 01-27-2014, 06:37 PM   #13822
3043imprez
Member#: 306592
2008 Impreza 2.5i
Lightning Red
One of my headlight bulbs went out today...any suggestions on replacement bulbs that look cool?
3043imprez is offline   Reply With Quote
Old 01-27-2014, 07:07 PM   #13823
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
You are pretty much stuck with H11's or do the H9 hack.
Otherwise if you are that concerned about headlight output a proper headlight conversion is in your future.
Old 01-27-2014, 07:26 PM   #13824
3043imprez
Member#: 306592
2008 Impreza 2.5i
Lightning Red
Maybe in the summer when it's not single-digits outside... And since one is already out, will just do a quick bulb replacement this time around.
Old 01-27-2014, 08:06 PM   #13825
Geerolla
Member#: 264827
2011 2.5i 5D
The stock horn is pathetic. Hellas are well worth it, people actually listen when you honk. I have to use it frequently thanks to the high amount of idiots in my area.
Geerolla is offline   Reply With Quote
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
