Old 11-16-2007, 11:44 AM   #1
SubyWRXSti
Member#: 79008
2006 Blitz STI
WRB INGS+1
Default Aggressive set up on Zerosports's car
I have been reading that Subaru's wheel bearing goes to poop very fast if you run aggressive wheel set up.
However, I just found out not long ago that Zerosports's car runs advan RS with +22 offset. Just wondering what are the modification needed to the car if such an aggressive set up is desired?
They run their car in Timeattack events which is way harsher than regular DD.
And also, I'm not sure why is it running such set up is bad for the bearing probably need some mechinical engineering background to explain it.
Any Idea?
SubyWRXSti is offline   Reply With Quote
Old 11-16-2007, 03:50 PM   #2
WAYGONE1
Member#: 139073
Go to Tire racks web site i think they have a guide on this stuff. Im not sure u could run a 22 without a wide body, that would push the wheel out really far.
WAYGONE1 is offline   Reply With Quote
Old 11-16-2007, 04:44 PM   #3
waktasz
Member#: 86356
2015 s1000r
wheelie monster
The Zerosports car is an STI right? Much better wheel bearings on those.
waktasz is offline   Reply With Quote
Old 11-16-2007, 08:51 PM   #4
TurbojonLS
Member#: 38772
2 Cars, No Bling
Plus, its a race car. Which means it gets lots of attention, and frequently has parts replaced.
TurbojonLS is offline   Reply With Quote
Old 11-16-2007, 11:54 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...d000000000000000000000000000d...
race cars and street cars usually share at least ONE part.....the car that they LOOK like
Old 11-17-2007, 12:17 AM   #6
moonlightspoon
Member#: 62164
2001 2.5RS
As said above, they probably can replace them very often and use either stock STI or maybe even some kind of aftermarket bearing. Running the stock bearings on my RS for 106,000 miles is no big deal with the correct offset, but I'm sure they spend the time and money to tear down and rebuild the suspension every 1,000 track miles or whatever with new hardware.
moonlightspoon is offline   Reply With Quote
Old 11-17-2007, 04:10 PM   #7
jdmdave
Member#: 116197
06 sti obp
sqc # 177 , lisc # 32
their show cars are stis, their track cars are wrxs.
jdmdave is offline   Reply With Quote
Old 11-17-2007, 09:10 PM   #8
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
^wrong, they all start life as a spec c. I japan you can order them anyway you want. So Zero/sports uses the 5 speed ra with a stock center diff, but a 20k lsd. The 5 speed is about 65lbs lighter than the 6. So when everything revolves around weight savings they use the 5. The Zero/sports car is WAY lighter than a regular street version. This is why their bearings are ok+ I agree with the above posts that they have a WAY more advanced service schedule. Most race teams, even grassroots guys, retorque and inspect EVERYTHING after and before a race. So in the time attacks, were all their worried about is 1 FAST lap, the wheel bearings would get replaced before each event. my .02
scby rex is offline   Reply With Quote
Old 11-19-2007, 01:09 AM   #9
jdmdave
Member#: 116197
06 sti obp
http://www.zerosports.co.jp/concept/index.php#
go to the either the btz601r(there current t/a car), the btz301-r , or btz201
and read the chasis codes.. which are gda.
gda is wrx in japan, gdb would be sti. (spec c or other wise)
once again their track cars are wrxs do some research before u tell people there wrong
edit oh and all spec cs come with six speeds.. no gd chasis sti comes with a 5 speed from the factory
Old 11-19-2007, 08:38 PM   #10
scby rex
Member#: 104878
02 wrxbastardchild
Yes they do, have you seen the zero/sports car inperson of ever watched option video featuring the zero cars? YOU do your research. I study the hell out of the zero cars. They use the spec c chassis as it is the lightest and they order it with the 5 speed. Yes you can order it like this in JAPAN. US sti owners for the most part have no clue the options that arent on the US spec "STi". Ok sorry to the OP, now back OT
Old 11-19-2007, 10:00 PM   #11
David Glasscock
Member#: 25033
06 sti my $$ pit
05 xt my DD
Any Idea?
i saw you leaving topfoods on sat, wish i would have gotten there sooner to check out the car. i noticed the wing i really liked it, i just need to see it up close now, so show me your car..
David Glasscock is offline   Reply With Quote
Old 11-20-2007, 03:14 AM   #12
jdmdave
Member#: 116197
06 sti obp
well if u know so much about the zerosports cars can u answer me why a company that has been tuning subarus for long then u have owned one, made the major mistake of listing all their btz timeattack cars as wrxs (gda chassis) and there czs cars as gdbs. apparently u know more on this subject then me. so please enlighten me
oh and even if they were spec cs.. why would they list as gdas. all spec cs regardless of how they are ordered are chassis code gdb.
and please correct me by showing me some proof that the spec cs come with 5 speeds.
to the op i am sorry for the thread jack
Old 12-21-2007, 04:11 PM   #13
ayobreezie
Member#: 117855
2003 O.O
AWP
Applied Model Codes:
1.8L (NA-Impreza): 5 (ie: GC5 is a 1.8L Impreza Sedan)
2.0L (pre-MY01 WRX): 8 (ie: GC8 is a 2.0L Impreza WRX Sedan)
2.0L (MY01+ WRX): A (ie: GGA is a 2.0L Impreza WRX Wagon)
2.0L (MY02+ WRX STi): B (ie: GDB is a 2.0L Impreza WRX STi Sedan)
2.2L (NA): C (ie: GFC is a 2.2L Impreza Wagon)
2.5L (NA-Impreza): E (ie: GME is a 2.5L Impreza Coupe)
2.5L (NA-Legacy): 6 (ie: BE6 is a 2.5L Legacy Sedan)
2.5L (XT): 9 (ie: SG9 is a 2.5L Forester XT)
2.5L (STi): F (ie: GDF is a 2.5L Impreza WRX STi Sedan)
3.0L (H6): 9 (ie: BE9 is a 3.0L Legacy Sedan)
ayobreezie is offline   Reply With Quote
Old 12-21-2007, 04:30 PM   #14
leafpyle
Member#: 143017
1999 Impreza 2.5RS
I know, when referring to ADVAN RGs that the offsets range from +47 to +22. The +22 is known as "GT-R offset".
EDIT: This thread could use some pics:
http://www.jtuned.com/content/templa...d=585&zoneid=1
leafpyle is offline   Reply With Quote
Old 12-21-2007, 05:36 PM   #15
EarlQHan
Member#: 90215
SO HOT. Anyways, back on topic. You have an 06 which means you have 5x114. If you want the GTR face your best options would be the 17x9.5 +35 or 18x9 +29. You will need to run an aggressive alignment, meaning -2 or less (-3 all around should do it). You will need to run skinny tires, probably no wider than 245 (depending on how much you pull the fenders). You will probably have to roll the front and cut the rear lip. And you will need stiff springs to keep the tire off the fender (coilovers make height adjustment, stiff spring rate, and camber setting easy). It's not hard, but body work and low offset seems to be enough to scare off pretty much all Subaru owners.
EarlQHan is offline   Reply With Quote
Old 12-30-2007, 09:17 PM   #16
YCT
Member#: 122167
2008 Mazda CX-9 GT
Liquid Platinum Metallic
man thats sexy
YCT is offline   Reply With Quote
Old 12-30-2007, 09:27 PM   #17
scby rex
Member#: 104878
02 wrxbastardchild
If you want to see a 5spd in the z/s cars watch option video #14 as "Tarzan" Yamada runs it around tsukaba
OR the modified mag issue with the z/s sti in in.
08 WRX wgn aggressive set up 18x9, +35 offset, 245x40x18, cobb springs. to do or not? yurka89 Tire & Wheel 3 11-02-2009 11:30 PM
Anyone Have a Video Recording System Set Up in There Car? MacintoshMan Car Audio, Video & Security 6 11-05-2008 09:59 PM
best top mount set up on a budget?? Silver_Fox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-08-2004 02:35 AM
Current set up for TXS car? Gman094 Interior & Exterior Modification 2 05-11-2003 10:40 PM
What is the best set up on Tec3 ChAi Engine Management & Tuning 2 03-21-2003 12:48 PM
