Old 11-16-2007, 02:20 PM   #1
jcayos
Member#: 94471
2003 WRX
Default Connector?
I am going to tune my own(ecuflash with tactrix cable) car after all, my question is, after tuning it do I unplug both connectors(white and green)? And what process is used to do a reflash? Thanks.
jcayos is offline   Reply With Quote
Old 11-16-2007, 02:29 PM   #2
wage0052
Member#: 127556
2006 WRX
RomRaided.
Yes..
wage0052 is offline   Reply With Quote
Old 11-16-2007, 02:30 PM   #3
rebizap
Member#: 79402
'05 STi
Hey go check out http://www.scoobypedia.co.uk/
Then go to the ecu section and start reading. It will have the step by step instructions for reflashing and specific instructions for ecuflash.
rebizap is offline   Reply With Quote
Old 11-16-2007, 03:07 PM   #4
WeldingHank
Member#: 98645
2002 WRX Wagon
i usually leave my flash-block connected 24/7. and just connect/disconnect my test-modes. I also have my test-mode connectors on a toggle switch.
WeldingHank is offline   Reply With Quote
Old 11-16-2007, 03:34 PM   #5
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
My toggle switch is mounted in one of the blank plates (I dremmeled a hole for it) and looks clean. It is a flat black rocker switch and matches the interior. I used one female and one male spade connector to attach to the green flash connectors instead of splicing into the wires in the car.
gabedude is offline   Reply With Quote
Old 11-16-2007, 03:48 PM   #6
WeldingHank
Member#: 98645
2002 WRX Wagon
I mounted mine in the exact same manner, and wired it exactly the same. but my switch is Green.
Test mode connector - Read memory connectors renhoek Pre-2002 Factory Turbo Powertrain 5 04-28-2007 03:17 AM
Green test connector and white connector...AP Q styng88 Mid Atlantic Impreza Club -- MAIC 6 03-06-2006 02:08 AM
FS: Injector connectors for aftermarket connectors. Safir Mid West Subaru Owners Club Forum -- MWSOC 0 04-06-2005 01:15 PM
Mysterious extra connector? (no, not the diagnostic connector question) satrya Forester Forum 11 11-06-2003 02:43 PM
A larger "T" connector lowers boost... What does a smaller "T" connector do? Cjchaps Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-29-2002 02:40 PM
