Old 11-16-2007, 06:11 PM   #1
ZR2_S10
Member#: 83865
2005 Saab 9-2X Aero
Midnight Blue
Default Fueling - I'm Lost
Mods found here:
http://saab92x.com/viewtopic.php?pid=218635
Despite what some say, I have had great luck with Braden's XPT maps. Ran his Stage 2, and now his 2.5
I have not had any 'good' luck getting my fueling in order, and am begining to belive that I have some kind of mechanical issue.
With the stock airbox, the fueling is 'closer' but not perfect.
I am WAY too rich in boost.
I have the injector scalar at 485 (not what he had it set at) but have the SPT intake, which the map was not tuned for.
Is there any reason why at idle (with the 485 scalar) the AF Learning would be around +2 and my AF L (b),(c),(d) would all be around -8.
At WOT, above ~10psi my AFR is around 9.6 (LC-1) but the map is calling for 10.8.
I'm lost. I have moved the scalar up and down, no real change in AFR.
ZR2_S10 is offline   Reply With Quote
Old 11-17-2007, 12:16 AM   #2
JMS77
Member#: 136833
Bump the scalar value up to about 535 and raise the latency value about .02 points at 14v. Then let everything warm up...you know the drill.... and do a pull logging AFR. Let me know what happens.
JMS77 is offline   Reply With Quote
Old 11-17-2007, 02:21 AM   #3
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
I agree with jms77. Your injector scalar is too low.
However, if AFR learning B, C, and D are all the same and yet AFR learning A is very large positive (which it will be after you correct your scalar) then you might have an exhaust leak before your front O2 sensor. Check your headers thoroughly.
mickeyd2005 is offline   Reply With Quote
i'm lost, confused, can't think... touch Off-Topic 3 08-15-2003 02:03 PM
Just installed GFB bov! I'm lost and concern. willow Bay Area Impreza Club Forum -- BAIC 1 07-12-2003 03:33 AM
I'm lost David D North West Impreza Club Forum -- NWIC 0 11-22-2002 10:10 PM
I'm lost! 8Complex Mid West Subaru Owners Club Forum -- MWSOC 3 09-05-2002 12:24 AM
I tried doing a search but i'm lost... GremLan7 Car Audio, Video & Security 2 08-13-2001 07:54 PM
