Old 11-16-2007, 08:40 PM   #1
hao
Member#: 32026
Default 2.5L Motor Swap - HELP! Need ECU GURU
My buddy and I have been working on his 02 WRX for 9 months now, swapping in a 2.5L Legacy motor to run properly in his 02 WRX with stock ECU and wiring harness. All tuning I have done thus far has been with Enginuity software. We have tracked down several boost leaks, discovered we had bad injectors, removed the TGV, disabled the AVCS, and found various exhaust leaks and fuel pressure problems. All gremlins which have not fixed the real problem.
The car pulls great from idle to around 4500 rpm, and then around 4500 the car just falls flat on its face. Engine loads and boost just drop off. Now I realized we were probably maxing the MAF values so I rescaled the MAF values to coincide with the Legacy GT MAF values. We have tried to trouble shoot everything we could but the problem still does not go away. I'm beginning to think its a limitation on the 02 ECU which is giving us problems.
Has anyone else been successful at doing a 2.5L motor swap into an 02-03 and run the stock reflash ecu? Sample log below.
Car:
2.5L Motor and Turbo from 2006 Legacy GT
Removed TGV valves
Disabled AVCS - STI Cams modified to run WRX Cam gears
ADJ Fuel Pressure Regulator
Fuel Rails to run Top Feed Injectors
Stock Injectors - only hitting 80% duty cycle
Walbro Fuel Pump
Headers, upipe, Turboback exhaust
Bigger TMIC
Log Files:
AFR EL RPM FP IAM TIMI Inj Dut Knock Air Pre MAF WG TPS
11.25 4.3 3924 100 14 4 61.15 4.5 15.96 142.25 42.35 100
11.25 4.33 4132 100 14 4.5 65.23 4.5 16.11 148.36 43.92 100
11.25 4.33 4266 100 14 4.5 68.26 4.5 16.25 154.76 43.92 100
11.25 4.33 4417 100 14 4.5 71.61 4.5 16.25 162.29 43.92 100
11.25 4.36 4646 100 14 13 46.36 3.5 9 101.49 43.92 100
11.25 2.69 4735 100 14 15.5 42.42 3.5 3.92 99.08 51.76 100
11.25 2.49 4838 100 14 16.5 42.32 3.5 3.05 96.94 67.45 100
11.25 2.42 4896 100 14 20 41.77 2.5 2.32 97.37 72.55 100
11.25 2.37 4970 100 14 21 41.35 2 2.03 96.51 72.55 100
11.25 2.32 5081 100 14 21.5 42.58 1.5 1.6 96.3 72.55 100
hao is offline   Reply With Quote
Old 11-16-2007, 11:42 PM   #2
hao
Member#: 32026
Post of Data Log
Code:
Air/Fuel Engine Load (2*g/rev)	Engine Speed (rpm) FI Pulse(ms)	Fuel Pump(%) IAM (IAM) Ignition(degrees) Injector(%) Knock(degrees) Manifold Relative Pressure (Corrected) (psi)	Mass Air Flow (g/s) Primary Wastegate Duty Cycle (%) Throttle Opening Angle (%)
11.37		2.82		3038		11.52		100		14		9		26.73		4.5		7.25		81.18		72.55		100
11.25		3.2		3301		13.57		100		14		6.5		34.34		4.5		10.59		104.57		72.55		100
11.25		3.83		3607		16.38		100		14		2.5		43.97		4.5		15.82		142.83		72.55		100
11.37		4.66		4010		19.97		100		14		3.5		60.7		4.5		18.14		151.84		69.8		100
11.48		4.55		4352		20.22		100		14		4.5		67.59		4.5		16.4		155.63		50.2		100
11.37		4.27		4678		19.2		100		14		5		69.64		4.5		15.38		139.12		42.75		100
11.71		2.98		4889		12.29		100		14		20		68.87		2.5		2.9		96.08		47.45		100
11.6		2.34		5064		9.98		100		14		22.5		40.68		2		1.31		95		60		100
11.6		2.24		5252		9.73		100		14		25		41.47		0		0.15		95.86		72.55		47.06
12.17		2.06		5078		8.7		66.67		14		11.5		38.09		0		-10.01		15.26		28.63		0
19.06		0.38		4164		0		100		14		13		0		4		4.64		112.34		0		66.27
11.25		3.2		3826		13.31		100		14		4.5		46.2		4.5		12.91		136.26		37.65		100
Old 11-17-2007, 12:54 AM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
After looking at the map and logs I do not think it is the ECU or the tune (though that huge timing jump at 6400 will not help you in the long run). It definitely looks like a mechanical issue, if I was going to guess I'd say the TGVs were snapping shut under load but you said you removed the TGVs.
I have tuned a 05 WRX with 2.5L swap, Element GT52 turbo and BigMAF intake with modded stock injectors and had almost no issues. so it isn't a limitation of the ECU. You need to consider things such as the inlet collapsing, TGVs snapping shut, things of that nature that would severly limit the engine's ability to breath.
Old 11-17-2007, 01:00 AM   #5
hao
Member#: 32026
Thanks Master2192. I have reduced the timing quite bit to smooth things out and reduce knock. But that still doesn't explain the strange condition. I will take a look at the mechanical suggestion you mentioned. I will post any new findings.
Old 11-18-2007, 01:00 AM   #6
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Your boost drops 13 psi within 200 rpm while you are full throttle.
Do you have an aftermarket blowoff? Is the stock one leaking? Do you have a silicon turbo inlet?
Smoby is offline   Reply With Quote
Old 11-18-2007, 02:31 AM   #7
hao
Member#: 32026
The car is running the stock BOV and we recently replaced the gasket as we discovered a leak a few weeks ago. The car does have the cheapy silicon turbo inlet pipe, which we be replaced next week. From what other people have told me, the non-reinforced silicon inlet pipe has a tendency to collapse.
I will keep everyone updated after we switch out the pipe. Thanks for all the input.
Old 11-21-2007, 08:25 PM   #8
hao
Member#: 32026
So I wanted to follow up and let everyone know we fixed the problem. It turns out the silicon turbo inlet hose was causing all the problems. The dreaded silicon hose was collapsing under full boost and would act as a restriction. We reinstalled the factory inlet hose and the car pulls great now.
Thanks to all who help me diagnose the problem.
Cobb AccessPORT 2.0 for the 2.5L motors Robson TXIC Private Classifieds 3 02-24-2009 12:00 PM
2.2L-2.5L na swap help needed ASAP!!!!!! impreza4show Subaru Conversions 14 08-20-2005 02:58 AM
miata motor swap day...need help Blindeye_03 South East Region Forum 43 04-28-2005 05:56 PM
do 1.8, 2.0, 2.2, and 2.5L cams swap? JonofScio Normally Aspirated Powertrain 1 07-11-2004 09:00 PM
NY/NJ: Partial turbo kit for 2.2/2.5L motors Paisan Private 'For Sale' Classifieds 5 04-29-2004 10:58 PM
