Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 11-17-2007, 12:34 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Boost controllers with the Apexi Power FC
Since I practically can't search for boost on this forum, I'm gonna give up searching and just ask people. What are you using to control your boost with your Power FC. To my understanding, the Power FC can't control the stock solenoid over stock settings. I'm using a Perric EBCS and I seem to be having the same problem. It seems like my 16g won't go over .9 bar. So now I'm considering other options. I know I can get the boost controller for the Power FC and there's also the AVCR and HKS EVC. If a manual boost controller is my last option, what other options do I have before that?
scoobyimprza is offline   Reply With Quote
Old 11-17-2007, 06:49 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
if your going to set it and forget it the hallman mbc is steadier than my proflec b ever will be
Old 11-17-2007, 10:34 PM   #3
kbahus
Member#: 70256
2000 STI V2 Swapped
I run a Perrin mbc and it is ok. You just have to be careful as it will change with the weather. Set it under a hard load too. The AVC-R is popular if you want to go ebc, or just order the add the boost control kit to your Power FC. I am currently getting my Prologger setup which is an ebc, wideband, and failsafe in one unit. Havn't tried the boost control yet.
kbahus is offline   Reply With Quote
Old 11-18-2007, 01:38 AM   #4
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
You can control boost as high as 21psi with a PFC and stock solenoid.
When you go into the boost setting, raise the duty cycles hight, as well as target boost. It will overshoot the target boost, but do to high dudy cycles it will have a hard time bringing boost back down.
Its like tricking the PFC, but it works, and works very well.
snowman4us is offline   Reply With Quote
Old 11-18-2007, 11:06 AM   #5
99WRXEJ20
Member#: 34545
1999 GC8
74f
I got the power-fc boost control kit. Works very well.
99WRXEJ20 is offline   Reply With Quote
Old 11-19-2007, 10:38 AM   #6
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Intersting snowman, I'll have to play around with it.
I'd love to get the boost control kit, but it's $$$.
anyone have the Apexi power FC manual in english? 2slofouru Other Engine Management 39 06-19-2009 09:05 PM
Apexi Power FC Boost Control - Apexi Kit or MBC? suby25 Pre-2002 Factory Turbo Powertrain 3 09-10-2008 03:00 AM
Do I need a manual boost control with the VF30? WildWolf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-24-2007 04:44 PM
Anyone who knows about the Apexi Power FC? scoobyimprza Subaru Conversions 7 05-04-2006 03:46 PM
Boost control with the FP Green Big Turkey Engine Management & Tuning 14 03-16-2004 12:34 AM
