Old 11-17-2007, 08:02 PM   #1
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
Default How can I log with an Evo Tactrix cable?
I have an Evo tactrix left over from when my friend sold his Evo. I was told by Tactrix that I could still use the Evo cable to log my '02 WRX, but not to tune it. This is fine as I just want to do some datalogging. What software should I use? We've tried both Enginuity and Evoscan and neither are able to recognize the car. Is there something specific I need to be doing? The car has an EcuTEK reflash on it already...
N'CTRL is offline   Reply With Quote
Old 11-21-2007, 01:10 PM   #2
N'CTRL
Member#: 29871
Metallic
Bump... anyone?
Old 11-21-2007, 02:05 PM   #3
Freon
Member#: 88322
2009 BMW 135i
Sure you have the right COM port selected? Can you try another cable? You can even log with a Cobb AP v1 cable.
Freon is offline   Reply With Quote
Old 11-21-2007, 04:13 PM   #4
JenSVX
Member#: 59561
1994 SVX
Laguna Blue
Where/how can I change this.
JenSVX is offline   Reply With Quote
Old 11-21-2007, 05:03 PM   #5
Freon
Member#: 88322
2009 BMW 135i
The com port is listed on the top left of Enguinity logger. It's pretty darn obvious. You might want to check device manager to see what COM port your cable is using.
Old 11-22-2007, 02:07 AM   #6
JMS77
Member#: 136833
Open Enginuity, Open the logger Load a profiler...if you have one....if not pick a com port(prob 7 or 5) Start the car. See if the top right of Enginuity recognizes the ECU...if it says reading, than just use any view you like ans pick some of the check boxes for the desired logging parameters in the 1st box on the top left.
If that doesn't work, make sure you have the correct .xml Def files for Enginuity. They reside ion the program file for Enginuity. In fact, you should do this first, before you even get to the car.
(This step is only for FLASHING NOT Logging) Make sure you have both the green connectors together and the Blue jumper. USe EcuFlash for flashing.
Good luck.
JMS77 is offline   Reply With Quote
data logging with the AP v1 cable tobylazur AccessPort 3 02-13-2010 12:25 AM
Can you log with an ecutek flash? kilowhisky Commercial ECU Reflashes 2 04-22-2007 10:13 AM
How much of the interior of 2006 can be traded with an 04-05 Silverex04 Impreza Forum 3 12-15-2005 05:37 PM
How can you see if an AP is married to an ECU without hooking it up to a car? casurfballa Engine Management & Tuning 3 09-22-2005 07:17 PM
How to make a WRX owner smile with an EVO TnTWRX Texas Impreza Club Forum -- TXIC 23 07-24-2005 11:42 AM
