Old 11-18-2007, 11:06 AM   #1
emyselfandi
Member#: 83701
Default 95 legacy fan just stopped working????
i'm in need of some help here... The heater/ac fan just stopped working.. I've checked the fuses and they all seem fine. I checked both the fuses inside the car and in the engine bay. I checked everything related to a/c, heater, fan, etc. They all look fine. Has anyone else had this problem? Prior to it not working the fan worked fine. I'm not sure what could have caused it or where to start looking...
It's a 95 legacy LSI. Any input would be appreciated. Thanks, Tim
emyselfandi is offline   Reply With Quote
Old 11-19-2007, 12:33 AM   #2
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Maybe the coolant temperature sensour went "Bad" ?
EDIT: Opps ! You didnt mean the radiator fan... you really meant the "blower motor" ?
If its the blower motor itself you could try replacing it with a new one... or you could try giving your older blower motor 12 volts, and see if it spins when voltage is applied directly to the terminals. My GUESS is the motor has likely seized up...
2nd EDIT: Many blower motors use a series of resisters along with the fan switch positions so that depending on the switch setting the fan blows at low, medium, medium high, or high speeds. Sometimes the blower motor itself maybe fine, but if the resisters melt down and no longer conduct electricity, then no mater what the switch setting, the blower motor, if it isnt getting any voltage, wont be blowing any air through the ventilation system. In this situation, maybe it might make sense to replace the burnt out resistors.
Jonathan is offline   Reply With Quote
Old 11-21-2007, 01:26 PM   #3
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Any progress to report ?
Computer Help. DVD drive just stopped working. Xzinum Off-Topic 1 02-28-2005 11:50 AM
My low beam HIDs just stopped working, troubleshooting help please. trail*of*dead Electrical & Lighting 17 01-07-2005 09:30 AM
CD Player just STOPPED working! Help!!! CrazyMike13 Car Audio, Video & Security 0 12-22-2004 01:26 PM
Basslink just stopped working... criz Car Audio, Video & Security 6 12-02-2004 08:50 AM
95 legacy rear defrost won't work! lj17 Legacy Forum 10 10-31-2004 09:45 AM
