Old 11-18-2007, 06:20 PM   #1
STI05
Member#: 76649
08 Z06
Victory Yellow
Default Cannot get DeltaDash to read USB port
I installed deltadash. It worked great - ONCE!!!!
I data logged my car, unhooked everything, brought the laptop inside and then plugged the dongle in (USB) so I can access deltadash. I saw my logs and discussed them with my tuner.
It is the weekend and my tuner has a life as I would expect so I have to come here and see where I can get.
Anyway, I started the laptop again. I then plugged in the dongle into the USB port and then into the car and turned the key to on. I then started delatdash - and it says Disconnected and .... looking at Com1 or whetever it states in that header at the top.
So I'm like "what gives?" It just worked!!!
I uninstalled the drivers and reinstalled - nothing - I disabled the Com1, and delatdash jsut starts immediately in Demo mode.
What in the world can I do to fix this?
STI05 is offline   Reply With Quote
Old 11-18-2007, 06:22 PM   #2
STI05
Member#: 76649
08 Z06
Victory Yellow
I need to add:
The device manager shows the Ecutek Usb Vehicle interface (without any symbols - no ! or ?) and the DSKey (sp?) as well - I knwo they are installed and the device is seen by the computer - just not by deltadash
Old 11-18-2007, 07:15 PM   #3
STI05
Member#: 76649
08 Z06
Victory Yellow
OK, I uninstalled everything - all Ecutek software as far as I can tell. I'm pretty much fed up with spending my Sunday in my garage so I took my laptop, Ecutek CD and USB cable into the house.
I plan on installing everything again, step by step per the instructions, as I did once before when everything worked fine - just once though.
I have a question since the first time I installed everything it went so smoothly I don't know the answer to this question:
When I perform the installation, I should not plug anything in. Put the CD in the laptop - install the drivers which is really just the DESKey software. Then install delta dash. Then plug in the dongle and then install the drivers for that as well which includes the USB driver for the dingle and the DESKey drivers. Then I should be able to start deltadash and see the USB interface - correct?
Please someone give me some advice before I go postal over here.
Lastly, when I had clicked on the Help, License something - I don;t remember exactly, it came up with a screen that showed who I bought it from, the car its for and a code. It also stated zero licenses. Does that zero license mean anything? I mean I paid for this POS why would it state zero?
Thanks in advance.
Old 11-20-2007, 03:40 PM   #4
dynamix
Member#: 122603
have you tried on the ecutek forums?
dynamix is offline   Reply With Quote
getting ready to read Atlantis Found -=C=- Off-Topic 7 02-08-2005 11:12 AM
STi ver5/6 swapped GC8's - able to read ODB2 port? Llama Subaru Conversions 5 07-29-2004 11:48 PM
Can't get DeltaDash to configure for LM-1 WBO2 Red Rocket Engine Management & Tuning 5 04-30-2004 11:39 AM
Cannot get in to update member info?! brat General Forum Archive 1 01-27-2001 12:40 AM
