Old 11-18-2007, 11:05 PM   #1
1quikwagon
Member#: 163825
1996 Leg Wagon Turbo
Default 96 Legacy L Automatic Final Drive for rear diff
Does anyone know what the final drive is for a 1996 legacy L automatic? I want to know because I am trying to find another automatic and I need to know what the final drive is.
Thanks.
1quikwagon is offline   Reply With Quote
Old 11-19-2007, 11:18 AM   #2
JaySVX
Member#: 164676
1994 Subaru SVX LSi
Barcelona Red
I believe it's 3.90, but i'm not entirely sure.
JaySVX is offline   Reply With Quote
Old 11-19-2007, 03:42 PM   #3
JaySVX
Member#: 164676
1994 Subaru SVX LSi
Barcelona Red
i was wrong. it's 4.11
Old 11-19-2007, 05:59 PM   #4
1quikwagon
Member#: 163825
Is there any manual transmission I can put in that would not require a rear differential swap? I know for the majority of the auto to manaul swaps you are required to change the transmission, and the rear differential.. but I am trying to avoid buying a rear diff.
Thanks guys, Brandon.
Old 11-19-2007, 06:06 PM   #5
JaySVX
Member#: 164676
1994 Subaru SVX LSi
Barcelona Red
There is a 4.11 manual tranny, i believe out of an outback. I'd have to check on it though.
Old 11-19-2007, 06:43 PM   #6
1quikwagon
Member#: 163825
You have been very helpful. Thanks
Old 11-20-2007, 07:04 AM   #7
JaySVX
Member#: 164676
1994 Subaru SVX LSi
Barcelona Red
Upon further research, you can just grab a manual out of a legacy between 91-99, and you should be good to go with no rear diff swap. Remember other key important things, though. You're going to need pedal box, clutch, and to be able to figure out the wiring. Important is the neutral switch, you're going to have to wire in brake and reverse lights, etc. Also I believe you'll need the cross member off the manual legacy, but i'm not positive on that one.
Old 11-21-2007, 05:09 AM   #8
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
IIRC the legacy manuals all have 4.11 gears. i think the imprezas have 3.90, and 4.11 mixed in here and there. and the 2wd manuals have 3.70 or something like that. dont get the rear diff from an auto legacy outback, its 4.44, from what ive read.
~Josh~
Old 11-25-2007, 02:13 PM   #9
ten80
Member#: 53625
00 16' FXT
Only some impreza wagons are 3.90, most are 4.11 (MT) and 4.44 (AT). Forester and outback are usually 4.44 as are BE/BH AT legacies. The specs can be found in the transmission tech documents if you can get your hands on them
ten80 is offline   Reply With Quote
fs tn: 4.44 complete final drive for wrx, Rear Quaiffe, driveshaft PlatinumRex Drivetrain 34 11-15-2008 02:38 PM
Final Drive identify?? Middle Diff broke?? Speed-Industries Transmission (AT/MT) & Driveline 1 03-11-2008 12:02 PM
is there a 4.37 final drive ratio front diff? greg donovan Transmission (AT/MT) & Driveline 1 08-18-2004 12:36 AM
'97 legacy outback 4eat final drive? RidinLow Transmission (AT/MT) & Driveline 0 07-10-2004 09:08 PM
