Old 11-19-2007, 02:38 PM   #1
98legwag
Member#: 160325
09 Legacy 3.0R
Default Maintance Question on 98 Legacy L
I went to get a free oil change today at the dealer and they said the timing belt, a/c drive belt need be replace. They also said the right rear O ring is leaking oil and theres a seal near the valves thats leaking oil as well.
My question is does this sound like a load of BS to you or is it normal stuff for a 9 year old legacy 2.2l with 91,XXX miles?
98legwag is offline   Reply With Quote
Old 11-19-2007, 03:31 PM   #2
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Timing belt should be changed every 60k miles on your car. Do you know when it was last changed? If it was at 60k miles like it was supposed to, you don't have to do it again until 120k. If you missed 60k, you're pretty far overdue.
You can visually inspect the AC drive belt for any cracks/wear - you only have to pop the hood to do that and verify.
If you have an oil leak you should be able to verify that yourself too - but you'll have to crawl under the car
jey is offline   Reply With Quote
Old 11-19-2007, 05:58 PM   #3
toysnyc
Member#: 164703
I went for a "free oil change" and they came back at me with a list of all these amazing things they were going to do to make my 96 L run better.
I would talk with some friends and get your car looked at by a recommended mechanic.
Free oil changes are never really free.
toysnyc is offline   Reply With Quote
Old 11-19-2007, 11:33 PM   #4
98legwag
Member#: 160325
09 Legacy 3.0R
Well I check the oil everyother time I fill the gas tank. It did look alittle lower than normal.
Old 11-21-2007, 02:05 PM   #5
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
I *think* you can safely go 90K between timing belt changes on the 97-99 2.2, but if the belt hasn't been changed yet, you are overdue for a new one. Since this is an "interference" motor, you are best off not questing it, and getting it done properly.
Everything else you can put off for a while. The timing belt on your car is a "must do" item, however.
I have 190K on my '96 Legacy 2.2 and no information on when, if ever, my timing belt has been changed. Yeah, I figure I am on borrowed time, but being a "non-interference" motor, I figure I can keep putting it off until it finally lets go.
Jonathan is offline   Reply With Quote
Old 11-21-2007, 06:03 PM   #6
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Perhaps, but Subaru recommends 60k, at least for 1998 - it's still that way when you check on Subaru.com too. And I know for sure because I have a 98 Legacy L
Old 11-22-2007, 12:32 PM   #7
98legwag
Member#: 160325
09 Legacy 3.0R
Well, I got the belts replace. I picked up my car 2 nights ago and when I went out to go to work yesterday...BAM 5 new scratches on the hood and driver's side fender. I have an "appointment" to take it back tomorrow and have them look at it. Im not leaving there till I get some money back or my hood and fender repainted for no cost. The time I was in before this for an oil change they spilled oil on the bumper cover and fender. Only reason I kept going there was the oil changes were "free."
Old 11-22-2007, 01:47 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
You've had the car back for 2 days, but the scratches are the dealer's fault? Good luck getting them to repaint those panels.
Old 11-23-2007, 12:30 AM   #9
98legwag
Member#: 160325
09 Legacy 3.0R
I noticed them the next morning and called immediately. All I know is they will never get another penny from me in the service department. Their sales department is a whole nother story. They are great.
05RS Intake Manifold on 98 Legacy EJ22 Zac86 Normally Aspirated Powertrain 8 11-19-2008 12:43 PM
04 STI suspension on 98 Legacy L wagon ? IllNastyImpreza Legacy Forum 19 07-11-2008 10:02 PM
Please help. JDM fogs on 98 Legacy vdubster79 Electrical & Lighting 2 06-23-2008 02:29 AM
Exhaust mid-pipe cracked on 98 Legacy Outback Zak Legacy Forum 4 03-30-2004 11:05 PM
STI Hoodscoop on 98 Legacy? Honkey3k Subaru Conversions 4 02-11-2004 11:14 AM
