Old 11-19-2007, 06:11 PM   #1
toysnyc
Member#: 164703
Default Engine problem on 96L wagon Automatic
Help!
Since the weather has gotten a bit chillier, my 1996 legacy wagon is having some problems.
When the engine is cold, it idles really high and, as the engine warms up and the rpms decrease, it revs then lowers and gets real bumpy - blub, blub, blubby.
Then, CEL comes on and the car wants to accelerate.
I popped the hood while this was happeneing and saw a spark on the box connecting the spark plugs.
As the engine warms up and I drive the car, the engine starts to run smooth again.
I ahve heard of this issue with other Subaru owners but never anything about what it is, what causes it and how to fix it.
Can anybody out there provide some insight? I already called cartalk but they don't seem interested in responding.
toysnyc is offline   Reply With Quote
Old 11-19-2007, 06:30 PM   #2
JaySVX
Member#: 164676
1994 Subaru SVX LSi
Barcelona Red
The legacy 2.5litre has hydraulic lifters, the 2.2litre may as well. If that's the case, cold starting when it's chilly may cause issues with hydraulic pressure due to the fluid condensing in colder conditions. It would certainly explain why the engine would run smooth when the car warms up. This is a real long shot, but might be worth looking into. This is also the reason your not supposed to just start up and go, you need to give it a few seconds for hydraulic system to build pressure.
Go to an auto shop and have them pull the codes that your getting on a cold start. That should give you a place to start at least. You can also buy the testers at many auto shops for as little as $50 or as much as $100.
JaySVX is offline   Reply With Quote
Old 11-20-2007, 10:36 AM   #3
toysnyc
Member#: 164703
Thanks for that idea - I hadn't thought of it at all. I was thinking that it might have something to do with the sparkplugs or the cables. It really feels like the engine is mis-firing.
Old 11-20-2007, 01:21 PM   #4
jreb10
Member#: 157205
1998 Legacy L Wagon
"I popped the hood while this was happeneing and saw a spark on the box connecting the spark plugs."
I don't think you should be seeing a "spark". How old are your spark plug wires? Start up the car in darkness and see if the wires are arcing anywhere. If they are, you should replace them. I have heard that Subarus are quite picky about their spark plug wires and you should only use genuine subaru OEM wires.
jreb10 is offline   Reply With Quote
Old 11-20-2007, 04:20 PM   #5
toysnyc
Member#: 164703
THanks again. I just go the CEL read and it says that cylinder four is misfiring. MAkes perfect sense too. That is where the spark is - right at the terminal where the wire meets the terminal on the engine bloc.
How do I take taht wire out? Tried it and it is hard to get to and in there really tight.
Old 11-20-2007, 05:08 PM   #6
toysnyc
Member#: 164703
Just replaced them. Now I have to wait till tomorrow morning to see what happens.
A/C problem on '93 wagon Worknclassbug Legacy Forum 3 09-04-2007 10:08 PM
Engine Problems on 2.5rs farrell Normally Aspirated Powertrain 1 08-06-2006 06:46 PM
Automatic tranny problems 1984 turbo wagon boosted84wagonmonster 'Old School' Subaru Forum 1 03-11-2006 11:42 AM
Help! Air suspension problem - 1993/94 Legacy automatic station wagon 1993 Legacy Brakes, Steering & Suspension 9 12-15-2004 03:56 PM
Hesitation problem on 2001 RS automatic coloradobound Normally Aspirated Powertrain 6 08-20-2002 11:24 PM
