Old 01-24-2002, 12:34 AM   #1
knightsnke
Member#: 9461
Default oil flushing a myth?
I was wondering if flushing the oil out after a oil change is worth it. Meaning after you empty out all the old oil put in a liter or 2 of new oil let it drain out then close the oil drain and fill the new oil up? thanks all
knightsnke is offline   Reply With Quote
Old 01-24-2002, 02:35 AM   #2
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
A far better way to flush the lubrication system is to refill the engine with oil, after draining the old oil, then run it a few miles, THEN change the oil & filter. I do this ever 10,000 miles and it makes the oil system quite clean. Cheap thrill, all it cost is about 4 quarts of oil - maybe $3-4.
Alan is offline   Reply With Quote
Old 01-25-2002, 03:34 AM   #3
Jung918
Member#: 10969
THey sell oil flushes at pep boys... You simply add the oil flsuh to your old oil and let it run for like 5 minutes and then drain it... But i hear that with synthetic oil that it really is not nessecary...
Jung918 is offline   Reply With Quote
Old 01-28-2002, 01:28 AM   #4
Joelk
Member#: 7790
2009 wrx
Diesel fuel works well also. Seriously... Fill your engine up with that, run it for a few SECONDS, then drain it out. It does a very good job of removing any build-up. I don't think you'd ever need to do this unless the engine has been sitting for a LONG time, probably a technique best used on lawnmower engines anyway....
Joelk is offline   Reply With Quote
Old 01-28-2002, 11:59 AM   #5
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
The safest bet is to just change your oil frequently. As far as the diesel fuel suggestion - do it at your own risk. Fuel dilution of oil can be a major concern due to viscosity modifications and possible interaction with the additives/byproducts in the oil.
jhuang76 is offline   Reply With Quote
Old 01-28-2002, 02:07 PM   #6
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Be careful when using oil flush. If your engine has pretty high mileage and lots of sludge, using an oil flush might dislodge a big piece of sludge or deposit which could clog an oil gallery.
AMSOIL makes a pretty safe synthetic oil flush:
1) http://www.amsoil.com/products/aef.html
2) http://www.pecuniary.com/synthetics/engineflush.html
In fact, it is recommended that you use this flush before switching from conventional motor oil to AMSOIL synthetic motor oil.
Richard
Richard L. is offline   Reply With Quote
Old 02-27-2002, 08:14 AM   #7
Frederf
Member#: 15622
2002 WRX SW
Sounds like a good idea... but what do you mean only costs 3-4$? A full treatment of engine oil costs me at least 25$!
Frederf is offline   Reply With Quote
Old 02-27-2002, 10:46 AM   #8
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Well, if you are changing your own oil - as I do - then the extra cost of putting in 4 quarts of new oil after draining the old oil is $3-4. One does not need premium or synthetic to run through the engine for 10 minutes. Then the "cleaning oil" is drained and tossed, the filter is changed, and you've got a really clean engine inside.
Old 03-25-2002, 10:03 AM   #9
shortlid
Member#: 10297
2003 Legacy GT Sedan
Silver, 4EAT, 42k
Default don't
Motor flush is just Kerosene and it can damage newwer enginbe seals!! It is only for Fire trucks that never get up to operating temp for like 10 years of life!
shortlid is offline   Reply With Quote
Old 03-25-2002, 07:08 PM   #10
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
I can tell you one thing for shure...
if you buy an old cheep junker with high miles for playing with
DO NOT use any type of over the counter "engine flush"
you may/will remove sludge that was keeping the motor happy
also if any thing chunky comes makes it to the pickup it might clog it too.
this is only a problem on cars that people used Old Pensoil on or neglected badly...
I think they reformulated the mix in the 90's...
Also... Using a Synth. (like Mobil1) in an old jallopy does wonders for creating leaks in engines you never knew you had...
GLwagon is offline   Reply With Quote
Old 03-25-2002, 07:16 PM   #11
hotrod
Member#: 14141
2002 Impreza WRX
Default drain it hot, no flush
Waste of time , money and oil.
The safest way to do it is to not change the oil until the engine is hot. Run a couple errands (ie go buy the oil and filter). Come home drain the oil immediately, and let it drain for several minutes. I wait until it stops dripping.
The thin oil will drain almost completely, without any risk of oil contamination of the new oil, or any of the problems with rinsing out seals so they leak.
Modern oils especially the synthics are very good detergent oils. The habit of using a flush oil orginated many decades ago when lots of people used non-detergent motor oils, so gunk would collect in the bottom of the oil pan, and in the cylinder head valleys.
Larry
hotrod is offline   Reply With Quote
Old 03-26-2002, 01:46 AM   #12
Sam2
Member#: 15265
2002 WRX Wagon
WR Blue
Default Re: oil flushing a myth?
Not sure you got simple answer. Just put oil in top and let drain out bottom does nothing really because its not going though the engine really, just draining to the pan.
Agree most else said here. High miles engine is best left alone.
Kerosene is cheap effective flush, $1 gallon as good as anthing you'll buy $2 quart. For most part, nowadays, none of this needed. Gas, oil, and engines all cleaner than in 1960.
Change oil. If oil is black as tar at 1000 miles, then change it again, repeat short change intervals as and if needed.
Sam2 is offline   Reply With Quote
Old 03-26-2002, 01:50 AM   #13
Sam2
Member#: 15265
2002 WRX Wagon
WR Blue
> This is only a problem on cars that people used Old Pensoil on or neglected badly...
Even worse.... Quaker State....
(both old high content parrifin wax oils)
Drain and refill A/T tranny oil in-between each full tranny oil flush? dcwrx2 Service & Maintenance 8 02-25-2009 05:30 PM
Engine oil flush in a 00RS, yay or nay??? Rallly2000 Normally Aspirated Powertrain 16 08-15-2008 01:24 PM
25,000 miles and switching over to synthetic oil - do i need an engine oil flush? anthonyrb98 Service & Maintenance 1 04-25-2005 07:21 PM
Oil Flush Idea Sideshowbob Service & Maintenance 17 02-12-2005 10:57 AM
Oil Flush? blitzpb Service & Maintenance 2 01-28-2004 01:30 PM
