Old 11-19-2007, 10:57 PM   #1
snailspins
Member#: 164652
05 STi
Default need help with width and offset.
i want to go with a 17x8 wheel. leaning towards Enkei RPF1
they come in a 45mm offset, will these fit with out rubbing or needing to roll my fenders? i read through the FAQ that is stickied but all it did is confuse me, so many contradicting posts. also whats the widest tire i could get away with on a 17x8
thanks in advance for all the help
snailspins is offline   Reply With Quote
Old 11-20-2007, 12:59 PM   #2
sharkmonkey
Member#: 118566
2005 WRX
I was looking at the same wheel this morning and found an offset calculator. Based on stock, the wheel is going to stick 11mm more inside the wheel well and 27mm outside than the stock setup. So you could simply turn the wheels one way and crawl under there and see what kind of clearance you had.
sharkmonkey is offline   Reply With Quote
Old 11-20-2007, 01:03 PM   #3
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Those would be fine. Depending on your suspension you might have some rubbing if you went with 245 size tires. 235 will fit fine, or a 245 if you do a minor fender roll.
waktasz is offline   Reply With Quote
Old 11-20-2007, 07:50 PM   #4
der3k
Member#: 131136
03 Turbo Honda Ep3
8in. wide FTW!
der3k is offline   Reply With Quote
Old 11-20-2007, 08:08 PM   #5
Hites
Member#: 138997
0000 Nothing
why waste your money on the enkei rpf1 when you can get the much lighter kosei k1 ts for much cheaper?
Hites is offline   Reply With Quote
Old 11-20-2007, 08:58 PM   #6
snailspins
Member#: 164652
05 STi
cause there is only a .6 lb difference and i buy the RPF1's for just over 100 bucks a wheel.
Old 11-21-2007, 05:38 PM   #7
kimball
Member#: 144465
2004 STi
black
See "Offset Help" on this page.
kimball is offline   Reply With Quote
Old 11-22-2007, 02:48 AM   #8
ranwck
Member#: 164250
Default Rota Tarmac 3
Hi, does anyone know Tarmac 3 from Rota 18 x 8 offset 48 able to clear Brembos brakes for the front?? Pls advice.
ranwck is offline   Reply With Quote
Old 11-22-2007, 07:40 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....disregarding all the rest of the stupidity and bull**** in this thread already
those wheels will fit just fine and will have no issues as they are specifically made for Subaru fintment...ya might need camber bolts in the back to adjust that if they are close and you are too low
I would put a 245/40 tire on them and be done with it and this thread.
Need help with Video and Sub options for STi roybfr Car Audio, Video & Security 3 02-09-2004 05:23 PM
need help with carfax and nj registration laws... kavu General Community 0 11-18-2003 12:03 AM
Anyone in the ny area need help with pulley and upipe install. ripGTS Tri-State Area Forum 2 01-14-2002 10:41 AM
need help with swaybar and kartboy endlink problem speedracer47 Brakes, Steering & Suspension 7 03-13-2001 06:29 AM
Need help with wheels and tires......Where are the experts? ARG Technical Forum Archive 20 06-28-2000 09:08 PM
