Old 11-20-2007, 07:42 AM   #1
xwizard
Member#: 131748
2006 Impreza Wagon
Question Will subaru steel rims from 06 fit an 08
I just traded in my 06 2.5i Impreza Sportwagon for an 08 2.5i Impreza Wagon w/ Sport Package. I bought snow tires last year with subaru steel rims. I was wondering if the wheels will work with the new car.
xwizard is offline   Reply With Quote
Old 11-20-2007, 08:23 AM   #2
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
I believe, and don't quote me that the offset of the 05' and earlier wheels was different than the 06'. That being said, look on ther inside of the wheels, and read the offset and size info. They will probably be the same or really close.
If it was me, and I had the car and the wheels on hand, I would try mounting one of the front steel wheels, and check the fit. Mount it on the hub, push and turn, rim flat on hub, with NO lug nuts installed, and check for interferences (caliper, rotor, strut - check front and back of tire/rim). If this seems ok tighten down the lugs finger tight, check again for binding, caliper clearence, etc. if all looks ok sock it down, let it off the jack, check for fender clearance. If all thats ok, mount the others up, check rears for clearance, and drive.
2subiesinyard is offline   Reply With Quote
Old 11-20-2007, 05:16 PM   #3
xwizard
Member#: 131748
2006 Impreza Wagon
I'm not putting 2006 rims on an older car. I upgraded to 2008 Impreza. I found this: http://www.cars101.com/subaru/tiresa...s.html#impreza
It seems like both the 2006 and 2008 2.5i use the same tire and rims although I don't quite follow what P.C.D 100 (3.94) means:
2.5i- 16x6.5jj, offset 55 (2.17), P.C.D 100 (3.94), alloy
I'll just ask the dealer when I pick up the new car.
Old 11-20-2007, 06:46 PM   #4
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Pitch Circle Diameter 100mm (3.94in)
UkNuck is offline   Reply With Quote
Old 11-20-2007, 09:15 PM   #5
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Yes, remove one of your wheels. Look at the inside of the wheel, on one of the spokes. There should be, cast into the wheel, the bolt pattern and offset.
For example, on the 2006 WRX it says 5 x 100 and then 55 -- the offset.
Find yours, and then go wheel hunting.
Have fun!
Old 11-26-2007, 10:47 PM   #6
Captain Ned
Member#: 36144
2010 Legacy2.5GT Ltd
Graphite Gray Metallic
The 16" steelie listed on TireRack for the '08 Impreza looks to be the same one listed for the 06-07 Impreza, which means it's got a 50mm offset and it should fit the '08.
Captain Ned is offline   Reply With Quote
Old 12-21-2007, 10:15 AM   #7
xwizard
Member#: 131748
2006 Impreza Wagon
Thanks.
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
Is it my Wheel Bearing? & Will a hub from an 06 fit an 02? nayr924 Brakes, Steering & Suspension 0 06-01-2009 07:47 PM
Will an 07 STI rear sway bar fit an 08 sport sedan? shanky26 Newbies & FAQs 2 09-05-2008 06:54 AM
Will a SPT intake and heatshield fit an 08 Legacy GT? A7X Newbies & FAQs 0 05-05-2008 02:43 AM
