Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 11-20-2007, 09:49 PM   #1
Paranoid Fabrications
Vendor Sales Rating: (102)
Member#: 140712
2008 WRX STI
Default ScanGaugeII, Read and Clear those Cels for cheap
Yep, you know you guys want this fine piece of automotive OBD2 tool
This bad boy can do it all. well, almost. but damn, this thing can do a lot. check it out.
Now featuring Xgauge, lets you check
Horsepower
Fuel Trim
O2 Sensor values
and more
DIGITAL GAUGES Display 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
  • Fuel Economy
  • Fuel Rate
  • Battery Voltage
  • Coolant Temperature
  • Intake Air Temperature
  • Engine Speed (RPM)
  • Vehicle speed (MPH)
  • Manifold Pressure (not available on some vehicles)
  • Engine Load
  • Throttle Position
  • Ignition Timing
  • Open/Closed Loop
SCAN TOOL The ScanGaugeII allows you to troubleshoot your own car, read error codes, and the conditions present when the error occurred. You can also turn off the “Check Engine” light and avoid those costly trips to the mechanic.
  • Reads Trouble Codes
  • Reads conditions that set the Trouble Code
  • Clears Trouble Codes
  • Turns off the "Check Engine" light
  • Tells you when vehicle is "Ready" to pass OBDII testing
  • Make and store up to 10 rewritable special codes
    to send to the vehicle computer
TRIP COMPUTER Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
  • Maximum Speed
  • Average Speed
  • Maximum Coolant Temperature
  • Maximum RPM
  • Driving Time
  • Driving Distance
  • Fuel Used
  • Trip Fuel Economy
  • Distance to Empty
  • Time to Empty
  • Fuel to Empty
And since i cant take pictures worth a ****. here you go. stock photos
This bad boy has many different color options.
  • 7 Standard screen colors and a custom setting with 63 possible colors.
  • Backlight for night use
  • Both display and keys backlit
  • User settable Off, Low and High
Easy to Operate
  • Simple on-screen operation
  • 4 menu driven soft keys
  • User settable update rate (Slow, Normal and Fast)
  • A HOME key to quickly return to the start screen
User Settable Backlight Display Color
  • Big display - 50% larger than the original ScanGauge
Automatic Power Control
  • Automatic delayed power-down after engine shutoff
  • Automatic power-up when engine is started
  • Manual power-up with delayed power-down via HOME key
Non-Volatile memory
(stored information is not lost when disconnected)
  • User settings automatically saved
  • Up to 10 user commands can be stored and recalled
  • Today, Yesterday and Tank Trip data automatically saved
  • Vehicle settings automatically saved
Easy Installation - no Tools Required!
  • Cable detachable at the ScanGauge II. Can be connected on the back or side.
  • Easily move from vehicle to vehicle
  • Compact Size - just 4.8"W x 1.5"H x 1"D
has plugs on both the side and rear, so you can mount it anyway you want.
and even a very nice cord
I know you are expecting to pay 400 bucks for this, and damn, its worth it. but since we are all cool its yours for only
$163 shipped in all 50 states (plus Ca tax if you live here)
Please order from here.
BUY NOW
Yep, cheap eh.
Paranoid Fabrications is offline
Old 11-20-2007, 09:52 PM   #2
Member#: 140712
2008 WRX STI
this will read codes from any ODB2 car.
here is a list of all the cars. (hope it copys over ok)
1994 Audi 100 2.8
1994 Ford Mustang 3.8
1994 Ford Cougar,Thunderbird 4.6
1994 Mercedes C220 2.2
1994 Mercedes C280,S320,SL320 3.2
1994 Nissan G20 2.0
1994 Toyota Camry,ES300 3.0
1994 Toyota T100 2.7
1994 Toyota Previa 2.4
1994 Volkswagen Corrado 2.8
1994 Volvo 850 Turbo 2.3
1995 BMW 750ci,850ci 5.4
1995 Chevrolet Blazer,S10 4.3
1995 Chevrolet Camaro 3.8
1995 Chevrolet Cavalier 2.3
1995 Chrysler Sebring 2.0
1995 Dodge Avenger,Neon 2.0
1995 Eagle Talon 2.0
1995 Ford Cougar,Crown Victoria,Thunderbird 4.6
1995 Ford Mustang,Windstar 3.8
1995 Ford Ranger 3.0,4.0
1995 GMC Jimmy 4.3
1995 Honda Accord 2.7
1995 Honda TL 2.5
1995 Honda NSX 3.0
1995 Jaguar AJ16(SC),XJS 4.0
1995 Jaguar V12 6.0
1995 KIA Sephia 1.8
1995 Lincoln Continental,Towncar 4.6
1995 Mazda Millenia 2.3,2.5
1995 Mazda Protege 1.5,1.8
1995 Mazda B3000 3.0
1995 Mazda B4000 4.0
1995 Mercury Grand Marquis 4.6
1995 Mitsubishi Eclipse 2.0
1995 Mitsubishi Expo,LRV,Summit 1.8,2.4
1995 Nissan Altima,240SX 2.4
1995 Nissan 200SX,G20 2.0
1995 Nissan Maxima 3.0
1995 Nissan Sentra 1.6
1995 Plymouth Neon 2.0
1995 Pontiac Firebird 3.8
1995 Pontiac Sunfire 2.3
1995 Rover New Model 4.0
1995 Subaru Legacy 2.2
1995 Toyota T100 2.7,3.4
1995 Toyota Camry 3.0
1995 Toyota Land Cruiser 4.5
1995 Toyota Previa 2.4
1995 Toyota Tacoma 2.4,2.7,3.4
1995 Toyota Tercel 1.5
1995 Volvo 850 2.3,2.4
1996 WORKS ON ALL EXCEPT: Ford, GM and Dodge trucks with diesel engines. VW TDI with a Black ECU
1997 WORKS ON ALL EXCEPT: Ford, GM and Dodge trucks with diesel engines.
Ford Explorer and Ranger - No Speed, Distance or Fuel Economy information (MPH, MPG, Miles driven).
1998 WORKS ON ALL VEHICLES EXCEPT: Ford Explorer and Ranger - No Speed, Distance or Fuel Economy information (MPH, MPG, Miles driven).
1999 WORKS ON ALL VEHICLES
2000 WORKS ON ALL VEHICLES
2001 WORKS ON ALL EXCEPT: Mercedes 300 Series.
2002 WORKS ON ALL EXCEPT: Jeep Liberty with the diesel engine does not report fuel use or trip functions and some of the gauges.
Mercedes 320 is not compatible.
2003 WORKS ON ALL EXCEPT: Jeep Liberty with the diesel engine does not report fuel use or trip functions and some of the gauges.
Mercedes 350 is not compatible.
2004 WORKS ON ALL EXCEPT: 2004.5 through 2005 Dodge Diesel Trucks.
2005 WORKS ON ALL EXCEPT: 2004.5 through 2005 Dodge Diesel Trucks.
Lotus Elise
2006 WORKS ON ALL EXCEPT: Lotus Elise
2007 WORKS ON ALL EXCEPT: Lotus Elise
Old 11-24-2007, 08:55 PM   #3
BlueRallyWrx
Member Sales Rating: (17)
Member#: 104876
2003 WRX, HEMI Jeep,
DD Honda Accord
Wow that does alot for such little money. Didnt know this little device existed. Something else to order
BlueRallyWrx is offline
Old 11-24-2007, 11:48 PM   #4
Eyedoc Orlando
Member Sales Rating: (1)
Member#: 146216
2007 Impreza 2.5i SE
Newport Blue Metallic
Did it go up? I thought it was $155?
Eyedoc Orlando is offline
Old 12-07-2007, 10:22 AM   #6
STiShawn
Member Sales Rating: (2)
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Shane, I remember reading (somewhere) that it has a lag on the live update info...is that true or was that an earlier iteration? I'd like to use this in leu of a boost gauge etc..
STiShawn is offline
Old 12-09-2007, 11:07 PM   #7
Member#: 140712
2008 WRX STI
you can set it to update it quicker, BUT, i wouldnt use it for a boost gauge.
anything else, sure, just not as a boost gauge.
Shane
Old 12-10-2007, 02:46 AM   #8
B16A2NR
Member Sales Rating: (69)
Member#: 88676
This wouldn't happen to have a basic clock function would it?
B16A2NR is offline
Old 12-10-2007, 08:26 PM   #9
Member#: 140712
2008 WRX STI
sorry, none that i have seen.
Shane
Old 01-04-2008, 12:56 PM   #10
Member#: 140712
2008 WRX STI
Thanks for the orders, all orders have shipped. and i still have lots in stock
Shane
Old 01-09-2008, 10:23 AM   #11
scutzi128
Member Sales Rating: (6)
Member#: 149467
2004 STi
It would work with an 04 sti?
scutzi128 is offline
Old 01-09-2008, 10:16 PM   #12
Member#: 140712
2008 WRX STI
yes it will.
Shane
Old 01-11-2008, 01:30 AM   #13
Member#: 140712
2008 WRX STI
justs a heads up, i will be out all next week, so any orders that come in will be shipped out monday the 21st.
Thanks
Shane
Old 01-24-2008, 12:15 PM   #14
Member#: 140712
2008 WRX STI
bump it up. all orders have been shipped.
Thanks
Shane
Old 01-30-2008, 12:17 PM   #15
Member#: 140712
2008 WRX STI
Thanks again for the orders, all have shipped. bump for a great little gauge.
Shane
Old 02-08-2008, 02:17 AM   #16
sidwin
Member#: 168099
2004 impreza sti
wrb
any feed back from people running this in their 04 sti?
also what kind of sample size resolution for timing and boost? how many frames per second?
sidwin is offline
Old 02-08-2008, 01:20 PM   #17
Member#: 140712
2008 WRX STI
well, checking my manual it onlys says, fast, normal, and slow
normal seems to update maybe once a sec. but i wouldn't use this for a boost gauge.
i will try to get the actual numbers from then shortly
Old 02-14-2008, 10:55 AM   #18
Rudywrx04
Member Sales Rating: (7)
Member#: 134273
04 VF 48 P&P
289 WHP 275 WTQ
Hey there! Have already ordered your grounding kit. Could you pm me a price on this item shipped to 46614. Thank you!
Rudywrx04 is offline
Old 02-25-2008, 03:17 PM   #19
Member#: 140712
2008 WRX STI
you have a pm.
Old 03-10-2008, 04:32 PM   #20
Member#: 140712
2008 WRX STI
thanks for all the orders, they have all been shipped
still lots in stock and ready to ship
Old 03-12-2008, 06:43 PM   #21
DLC
out back
Member Sales Rating: (21)
Member#: 1964
05 OB XT LTD
Silver/Gray
I just found out about this widget today.
If I get one I know where to send my monies
DLC is offline
Old 03-15-2008, 07:47 PM   #22
Sparticus
Member#: 14620
2000 Impreza RS
Does the scangauge AFR work with a wideband O2?
Sparticus is offline
Old 03-17-2008, 01:44 AM   #23
Member#: 140712
2008 WRX STI
work with?
this reads from the ODB2 port.
Shane
Old 03-31-2008, 01:38 PM   #24
H-Dtech
Member Sales Rating: (5)
Member#: 139430
08 FSXT 5mt
WRB 1 of 300
does this come with any kind of mount, or is that something I would have to make myself?
H-Dtech is offline
Old 03-31-2008, 03:02 PM   #25
Sparticus
Member#: 14620
2000 Impreza RS
Originally Posted by Paranoid Fabrications View Post
work with?
Shane
I researched it and found out that I needed to know.
I hope you keep these in stock since I will be ordering one in the next couple of months from you.
Closed Thread
Must Read!, Hot Lcd Touch Screen For Cheap rocklandwrx Private 'For Sale' Classifieds 2 07-07-2004 06:59 PM
Using UTEC to read and clear CEL's? silverscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-25-2003 01:36 PM
Using UTEC to read and clear CEL's? silverscooby Engine Management & Tuning 1 06-24-2003 11:59 PM
Devices to Read and Clear CELs GoodFinder Texas Impreza Club Forum -- TXIC 5 10-31-2002 02:50 PM
Can someone around Irvine clear my CEL for me?? (Ryan?) wayoutwest Southern California Impreza Club Forum -- SCIC 7 10-17-2002 07:10 PM
