Old 11-21-2007, 01:55 AM   #1
CaliforniaDistraught
Member#: 122834
2003 WRX
Default Tire & wheel dilemma
I am currently running 18X8 Rota Torques on my 03 WRX, with Kumho Ecsta SPT tires; size 235, 40. The rest of my suspension is stock, for now.
Lately I have been participating in more Autox and track days.
I realize that high performance / competition tires are expensive in the 18" size. The 18" wheels are also heavy.
I am considering a few options
1) use my OEM 16x6.5 wheels for autox/track use
I would squeeze a 225 Falken RT615, michelin pilot sport cup, or other sticky tire on there
this combination would provide a greater bang for the buck than the kumho SPTs I currently run on the rotas combined with a weight savings.
2) trade my 18" rotas for some 17x7.5 or 17X8 rotas
This would lighten up the 4 corners of the car a little bit
I could also run a 235 or 245+ tire, but at a slightly higher cost and weight
I would most likely end up with the RT615s on a 17" wheel, instead of a better tire such as the pilot cups or ecsta v710s on the 16"
My question is:
Will I miss the width of a 235+ tire if I go with the OEM 16" wheels & run a 225 tire?
Will the 17" diameter provide an advantage over the 16"?
I am not concerned with the effect aftermarket wheels have on the SCCA/ NASA classification of my car.
Also, what effect does a changing wheel diameter have on a suspension setup?
If I had lowering springs or coilovers, would a change from 16" to 18" wheels in between events have a negative effect on the setup?
If other info is needed to help answer my question please let me know.
Thank you
-A
CaliforniaDistraught is offline   Reply With Quote
Old 11-21-2007, 06:11 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....17 x 8........245/40 or 255/40 will almost certainly be the cheapest/easiest/lightest combination....there are several good, light 17 x 8 wheels that are available
http://www.edgeracing.com/wheel/1859/
....but the stock suspension is pure garbage and you will see that once you start to upgrade it
Unloading Tires & Wheels, 15 to be exact. Help! & studs. myvisiondiving NWIC Private Classifieds 10 01-10-2009 05:08 PM
WTB: 195/65/15 All Season Tires or tires & wheels CHEAP! styng88 MAIC Private Classifieds 5 02-07-2008 10:14 AM
NNJ tire & wheel mounting & balancing rommel Tri-State Area Forum 3 11-15-2007 02:42 PM
Tire question for OT - screw the Tire & Wheel guys! dr_wheel Off-Topic 36 11-30-2005 04:39 PM
FS locally: Stock muffler for $10 & 13inch tires & wheels yuji Southern California Impreza Club Forum -- SCIC 4 07-29-2001 06:23 PM
